Question about Whirlpool Duet GHW9150P Front Load Washer
What does an F 35 code mean? - Whirlpool Duet GHW9150P Front Load Washer
  • 15,935 Answers
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
What codes 12. 33. and 35. mean on a 1991 Jeep wrangler 2.5L?
code 12-- battery has been disconnected once in so many ignition cycles.
code 33 is ac compressor clutch.
code 35 is radiator fan relay circuit issue. Does the radiator fan work ok?
Are you having problems with your vehicle? What kind of problems?
Apr 16, 2017 | Jeep Cars & Trucks
What does a code 35 with a double beep mean?
Hello,email the Manufacturers website with your Model No + Trip Code & ask for advice on getting it fixed.I hope this helped,who better to ask than the Manufacturers.Via Fixya.com.Colin
Sep 14, 2014 | Pride New Jazzy 600 Power Wheelchair by...
Engine codes for a 1998 plymouth voyager
okay, 1998 voyager these are not obd2 codes, these are genric codes, you used ignition to get these .
these codes are for older models that use codes like these 12 35.
the newwer obd 2 use codes like po 013. i will try to see what i can find, also the engine size is important.
okay here we go, the first code is 12, this code means the battery was dead or dissconnected.
the next code 35. this code means loss of prime, code # 11
means internal transmission failure.
the code 55 means gear ratio error.
these codes would tell me that you have transmission problems. this may mean internal trans failure and a rebuild or replacement transmission is needed or shift pack needs replacing. anyhow i would have a shop check this out, these van are known for transmission problems. hope this is helpful good day
Feb 03, 2013 | Plymouth Voyager Cars & Trucks
What does the fault code 35 mean on a freightliner truck
Flash Code 35 indicates that the engine Oil Pressure Sensor/Engine Oil Pressure Sensor (OPS/EOP Sensor),input to the ECM/ECU has exceeded 95% (normally > 4.75 volts) of the sensor supply voltage.? This is more then likely a faulty oil pressure sensor or wiring to sensor issue
Nov 02, 2012 | Cars & Trucks
DTC Code 35 - 93 Grand Prix
Generally speaking, code 35 is a problem with the idle air control valve.
The valve is mounted on the side of the throttle body and controls idle speed by how much air is allowed into the intake manifold.
Sep 14, 2012 | 1993 Pontiac Grand Prix
I have a 1993 Chevy Silverado 1500. trouble codes 22, 35, & 37. what do they mean?
code 22 throttle position sensor low voltage
code 35 EGR
code 37 doesnt exist but im getting a code 37 also
Nov 08, 2011 | 1993 Chevrolet K1500
What do the trouble codes 33, 35, & 5 mean for a 1992 Dodge Spirit?
Code 5 = Battery Low Voltage
Code 33 = Air Injection Reactor Switch Solenoid
Code 35 = Idle Switch Open
Nov 18, 2010 | Dodge Spirit Cars & Trucks
My check engine is on and the codes that I get are 35 & 55 - what do these codes mean
code 35 is a problemin the cooling fan relay it is either open or shorted code 55 means end of code output,or to say there are no more codes. Ray
Nov 09, 2009 | 1995 Dodge Intrepid
Computer codes 34 & 35
You can find out at a part store by either asking somebody or looking through a Chiltons/Haynes book on your make, model, and year.
Jul 08, 2009 | 1990 Pontiac Grand Prix
Error code
Problem: The Digital Panel is Reporting Code 34-1, 34-2, 35-1, 35-2 or 36-2 Cause: The copier is having a problem with the fusing unit.
Solution:
  1. This is occasionally a false alarm. Try turning the copier off for about 10 seconds and turning it back on. If the code doesn’t clear, please call 1-800-877-2679 for service.
Sep 02, 2008 | Office Equipment & Supplies
Whirlpool Duet GHW9150P Front Load Washer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
