Question about Neptune Home
I have a neptune solo electric shower 8.5kw which is installed but when we turn it on it does not get very hot and is only luke warm when you put it on full heat,is there a set up procedure once its installed?
emissionwiz
  • 76164 Answers
SOURCE: heater does not blow hot air on full heat setting
the problem is caused by the motor that operates the air temp blend door motor in the heating ducts, it blends air between AC and heater core tro give desired outlet temp.
Posted on Dec 12, 2008
  • 68 Answers
SOURCE: Single handle Pioneer shower faucet
its the mixing slide in there its stuck u can take it apart at the handle it pulls out shake it if it doesnt move its bad. what happens is over time sediment gets in there and seazes it up. if you take it apart and its not stuck then its ur mixing valve on your boiler is bad good luck
Posted on Dec 21, 2008
SOURCE: moen posi-temp for shower pressure
There is a little "o" ring in the shower inlet that is designed to collapse as the pressure increases, limiting flow. You can safely remove this and then have un restricted flow.
Posted on Feb 24, 2009
SOURCE: water in shower not very hot
It could be possible you require more water volume, so take off both panels on youur water heater and check what temp. they are at.
I know I discovered the hard way there are 2 heaters and 1 of mine was low,good luke.
Posted on Mar 27, 2009
SOURCE: TRITON Trance electric shower
I have a triton trance shower not working with power and water both connected properly! low pressure light coming on and nothing happening????
Posted on Mar 09, 2010
Warm water in shower and cold in sink
How long has this been like this? Have you replaced any faucets, or have you installed a new water heater recently?
Jan 17, 2013 | Home
I have a ruud ruudglas pacemaker electric hot water heater. model number pem52-2b. first person to ake show in the moring has hto water for about 5mins and then it turns luke warm . when you wati about 10...
sounds like thermostat but element can be checked with a multi-meter, turn power off at fuse panel, pull one wire of element put multimeter on both screws on element using continuity setting should show continuity or beep as most do if not its burned out and needs to be replaced
Dec 01, 2012 | Water Heaters
My gas shower is either luke warm or very hot whats wrong
If all the other faucets work, then the problem is the mixing valve in your shower. You will need a new shower fixture.
Apr 10, 2012 | Bosch Water Heaters
My oil fired hot water heater provides only sporadic hot water. For example, when I am home alone it takes 2 minutes to get luke warm water in the shower, then it is only warm for a few minutes, then...
It sounds like your thermostat on the water heater isn't working properly. try turning it up higher and if this doesn't work I would have a service techy look at it.
Mar 24, 2011 | Water Heaters
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
How do you adjust temp. water luke warm? This is a single handle. Hot water set at 145.
These type faucets have anti scald dial setting that if you remove the handle you can gain access to it.
Just remove handle and mark or remember where it is and pull it out and reinsert it about 1/4 turn counter clockwise.
It has got marks on it and looks like a little gear.
May 19, 2010 | Danze & Single Handle Tub And Shower...
Hot water on bathroom faucet won't get hot only luke warm
That is a type where the water is mixed inside the valve and the valve has gotten worn or loose inside. Replace it or take it apart to see what isn't working properly.
Apr 12, 2010 | American Standard Bath Faucet Ceramix...
Mira Sport shower running luke warm
Your hot water must come from your coil in boiler and not from a seperate hot water heater - more then likely furnace hasn't been on for heating your house nor has it been on for any draw of hot water. You have to wait till it goes on and brings the water temperature up to your setting or get a hot water tank put in or a new type wall mounted gas instant hot water unit.
Mar 14, 2010 | Home
Rheem 40 gallon wh installed 12-13-06. Have
Was the tank full and all air out of lines before turning power onto it. If it's not full it will blow the new elements you just put in.
If the bottom one is good you get like luke warm then it will start cooling off.
If the top one is good it will be a burst of real hot then cold.
Dec 18, 2009 | Water Heaters
Water in shower not very hot
Mar 25, 2009 | Pegasus Technologies Home
Home Logo
90 people viewed this question
Top Neptune Home Experts
JonSnell Electronic
JonSnell Electronic
Steve Waclo
Steve Waclo
Are you a Neptune Home Expert? Answer questions, earn points and help others
