Error code PE - Washing Machines
  • 15,935 Answers
PE error.
Pressure sensor error. Cause: the sensor switch assembly is out of order.
Check the pressure switch -the system that determines correct water level in the drum.
If its giving an incorrect indication to the program timer machine will either overfill, refuse to fill or refuse to spin.
Its an air operated diaphragm switch triggered by rising air pressure induced by the entry of water into an airtight vessel attached to the base of the drum.
It tells the program timer that the water has reached the correct level, allowing it to proceed to the water heating stage in the cycle.
Power off.
drag machine out onto the floor.
remove back cover and top cover.
The pressure switch is a round item about 3 inches across with several wires and a thin rubber pipe attached.
It generally sits just under the top cover. Disconnect the thin rubber pipe from the switch and blow down through it to clear any blockage.
Switch itself may be faulty but its more likely the pressure pipe or the vessel attached to the other end of the pipe is blocked.
Some machines have the pressure vessel integrated as part of the filter unit, with a pressure chamber moulded into the top of the filter body.
Remove the pressure vessel, put a small nut or screw in it, fill it with water and shake vigorously till any crud or residue is removed.
Refit all parts, check that joints and connections are water tight.
Also check the filter itself - generally located behind a panel at the foot of the machine.
Some are obvious like little square hatches and some are hidden behind the trim panel at the foot of the machine.
Once panel is removed the filter should be visible. Its generally a circular plastic fitting which unscrews in an anticlockwise direction.
Some hotpoint, indesit and ariston filters are located in the big black sump hose
(the one that leaves the bottom of the outer drum and connects to the pump).
Power off.
remove back cover or tip machine up at an angle.
Locate sump hose, remove the tensioner clip by squeezing the tabs together with a large pair of pliers or vise grips.
Remove the hose.
Take out filter and clean. Be prepared for spillage of water.
May help if the machine is tilted backwards at an angle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Lg wf-t1022tp gives a PE error code.
Try this first before replacing any parts or disassembling your LG washer:
- Unplug the washing machine for 1 minute.
- Plug the washing machine back into power.
- Restart the wash cycle.
- The washing machine may now have cleared the PE error code, if not see below...
You will need to check the wiring harness that connects the water level pressure sensor to the main control board.
- Check for a loose wire harness, a damaged wire harness, or a burnt faulty wire.
- Check that you get continuity through the wire harness by checking it with a multimeter.
- If the wire harness from the water level pressure sensor to the main control board is found to be faulty, replace it.
- If you get continuity and the wiring harness is securely connected to both the water level pressure sensor and the main control board, then proceed to the step below...
LG WASHER PE ERROR CODE - FIX METHOD #2
Water Level Pressure Sensor Switch Is Faulty And Needs To Be Cleaned Or Removed And Replaced.
Most commonly, if the wire harness is secure, tight, and not damaged, the part that needs to be checked is the water level pressure sensor.
- First check to be sure the water level pressure sensor is not caked with hard water or other debris.
- If the water level pressure sensor is not clean, the PE error can display.
- Remove the water level pressure sensor from your LG washer and clean off any hard water or debris.
- Clean out the tube that connects to the
- If you found the water level pressure sensor was caked with debris and you have cleaned it, replace it back into the washer and run a test.
- If the washer runs without the PE error code displaying, the washer is fixed and the PE error has been cleared.
- If you find that the water level pressure sensor is faulty, remove it and replace with a new OEM part.
lg-electronics-washing-machine-water-level-sensor-pressure-switch-hth0u4ums0hor52ud1sodlv4-2-1.jpg
Replacing the water level pressure sensor simply involves locating the sensor in your LG washer. Remove it from the washer and replace it with a new genuine LG washer part. Test washer to be sure the PE error code has cleared and the washer is now working properly
Mar 20, 2017 | LG Washing Machines
Washing machine LG TR9103AEP IE error what does it mean ?
LG Top Load Washer-Understanding Error Codes - YouTube
? 2:17
www.youtube.com/watch?v=ZdoJVqFKye4
Sep 17, 2013 - Uploaded by ExperienceLG I have LG Washing machine and I tried to start it and came up with PE Error code and I ... I Can see IE OE and other error codes But Not PE.
Aug 04, 2015 | LG Washing Machines
ERROR CODE PE
The error code PE indicates that the half load motor is defective.
Jan 02, 2015 | Washing Machines
I get an error code PE on Samsung washer WA5451washer
PE error code is a pressure sensor code, and more than likely the sensor will need to be replaced. Try unplugging the unit for about 5 minutes and see if it will clear it out. If not, will need to replace pressure switch and hose (switch looks like a little UFO under the console, pretty easy job.
Nov 11, 2013 | Samsung WA5451ANW 4.7 cu. ft. Top-Load...
I get a PE error code
I get PE error code in whirlpool white magic F65
Aug 12, 2012 | Washing Machines
Error PE on model wm2016cw, is this an easy fix?
Error Code PE mean Pressure sensor Error code
Check wiring connection to the pressure sensor; to solve it replace pressure sensor. The sensor repair is simple and straight forward.
Additonal details could find in this link: LG_Knowledge_Base
Hope this helps.
Aug 02, 2011 | LG Washing Machines
I get a "PE" error
As you said in the question you are washing machine is showing error "PE" it's not a big problem you are washing machine is just fine.PE means error signal due to low voltage .Machine resumes functioning after the voltage comes back to normal.Thanks for your question.
Jun 19, 2011 | Washing Machines
Whenever i given its shows error peep sound ,its indicate error worrd -PE
Hello, LG Washing Machine Error Code "PE" -Pressure sensor error code -Check wiring connection to the pressure sensor. -Replace pressure sensor The sensor repair is simple and straight forward. If this helps please rate me thanks..
Jun 08, 2011 | Washing Machines
I have a LG WD-1018C that won't work and has PE on the screen and I can't find the manual to fix it. Can you please tell me what PE means. Thanks
The error code "PE" stands for pressure sensor error. This is typically caused by a malfunctioning water pressure sensor switch.
Mar 09, 2011 | LG Washing Machines
"PE" error message on LG Dishwasher LD-12AS1 LD-12AW2
The PE error code indicates that the machine has a water pressure sensing error. Check and clean the filters on both sides of the inlet water line. Good luck!
Sep 13, 2007 | Dishwashers
Washing Machines Logo
198 people viewed this question
Top Washing Machines Experts
