Question about Kenmore Dryers
Kenmore Electric Dryer (model#110.67902791.....series 90) will hum will started, but will not turn on when the start button is released. I have already check the thermal fuse and it is good. I also check the switch next to this (not sure what it is called) and it is good. I was thinking it could be a motor relay, but I coudn't find one in the control panel. Any thoughts what it could be or what to check? Thanks.
    Habit-Forming:
  • 84 Answers
Your switch in the motor is gone,you'll have to replace the motor
Posted on Sep 12, 2010
  • bobvjr Sep 12, 2010
    Can I test the motor once I get it out? I am thinking I may be able to hook up to 120VAC to check, but I am not sure of the terminals to power up.
4 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: On the Kenmore series 90 electric dryer, where is
The Thermal Fuse is located on the air blower housing. Its a small white plastic component with two wire leads.
The Thermal Cut-Out (TCO) is located on the outside of the heater box on the end opposite the heating element terminals.
The reason I mention both these components is because some people confuse the two and use the words interchangeably. There is a difference between the two components and what they do.
DOUBLE CHECK YOUR SYMPTOMS:
If your dryer does not run at all, check your Thermal Fuse.
If your dryer runs, but does not heat you need to check the Thermal Cut-Out.
If you have any questions, please post back and let me know what symptoms you are having. Please include your complete model number (located on a nameplate around the door opening) so that I can determine how your dryer is configured. I hope this is helpful to you.
Posted on Jan 08, 2010
  • 1073 Answers
SOURCE: Electric Dryer Starts, runs, warms, stops (Kenmore series 90)
you have a bad motor that needs to be replaced
Posted on May 06, 2008
Maytag317
  • 1136 Answers
SOURCE: Kenmore 90 series model 110 60902990 wont heat
There are a few things you can check. You will need a voltage/ ohms meter. First thing you should check is that you are getting 240 Volts too the dryer. If the dryer is getting voltage, then you will need to check the heating element first. Remove the lower front panel usually held on by 2 1/4" screws. The element is located on the right side of the dryer (Looking at the front). Unplug the dryer, check continuity on the 2 terminals on the element, if there is continuity, the element is ok. Next you will need to start checking the thermostats. There is one thermostat and one safety stat on the side of the element housing. Both of those should have continuity also. If all three os those parts are checking out ok, you wil need to check the safety attached to the blower duct work directly below the drum. The easiest way to get to that safety is to remove the lint screen duct.Two 1/4" screws hold that on.
These are the most probably causes of your dryer not heating. Please contact me if you need more info.
If this helps you and you need to order the defective part, let me know and I can ship you the part also.
Hope this helps.
Vic
Posted on May 08, 2009
Have a Kenmore 90 series gas dryer. When I press the button to turn it on, it makes a noise but won't start
Assume the buzzing quit when you release the start button. Open the dryer door and slowly rotate the dryer drum in a counterclockwise (CCW) direction. Rotate the drum 2-3 revolutions and then shut the door and see if it will start. If it continues to just hum and not start could indicate a voltage issue, motor issue or a friction issue. Open the door again and locate the door switch plunger in the upper or lower corner on the hinge side of the drum opening. Hold the plunger in while someone begins rotating the drum counterclockwise. While turning the drum counter clockwise and holding the door switch plunger inwards press the start button. If it starts, there is likely a friction problem or motor problem. Check the blower fan and motor for any obstructions.
Jan 09, 2011 | Kenmore Dryers
Press the start button on dryer, it hums but wont turn. With 2 people pressed the start button again, held the door switch, reached in turned the drum, it hummed stopped humming then no more nothing....
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Dec 27, 2009 | Dryers
Kenmore electric dryer shuts off after 5 minutes and won't restar
when you try to start it again do you hear a humming comeing from the motor? can you jump start it by turning the drum while holding the start button? If you say yes to these questions you have a bad motor.
Jun 21, 2009 | Dryers
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Kenmore 90 series won't start timer ticks
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dec 03, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Kenmore Dryer 90 Series will start but suddenly stop...
what starts and stops? the entire dryer or maybe the drum? Do you do anything to make it restart other than pushing the start button? This initially sounds like a temperature switch is opening and resetting after it cools. If you can describe the problem a little more in detail it would help.
Jan 27, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
383 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
