Question about West Bend (58036) 36-Cup Coffee Maker
Can one add milo into the hot water inside the west bend coffemaker to dispense instant beverages?
  • eanglinbee Sep 12, 2010
    i am using a westbend 100 cup stainless steel coffeemaker, the heating coil is not exposed to the heated liquid.the milo added to the hot water will be consumed within 30 minutes. it will hardly be sitting in the coffeemaker. do you think it will work? i don't have access to other types of instant beverage dispensers in southern philippines.
  • 11,800 Answers
Yes, you can add it if some conditions are met:
- the Milo is in powder form, the chunkier one will most surely clog the unit.
- it will not stay in there for more than 1 hour, otherwise the grease/butter molecules from the milk will coagulate and clog it.
 - the water temperature isn't set too high (close to the boiling point) or the sugars will caramelize and deposit on the taps clogging them.
Finally you must clean it very thoroughly after every use.
Posted on Sep 12, 2010
  • West Bend Master
  • 1,711 Answers
There are special milk beverage heater which is consist from a double well container and they work like the bain marie works. Under the fist container their is a water layer with heating element. With this way it is secure that in the primary container since you dont have the element you can clean it perfecty good so the hygine standards are secured. Also with the heating of the water first and then the heat to transfer to beverage it secure that their will not burn the beverage and the temperature will be mor stable.
So in you case if you use milo the problems you have is that it will be very dificult to clean afterwards the container under the element and the element is self. Also the delivery tap will be very difcult to be cleaned from dry milo beverage. All these they can clean much more easier with coffee or tea.
I have water in the bottom of my Beverage air kegerator
Water in the bottom of Kegerator - Dispense Forum ' Discuss Keg ...
www.micromatic.com/...kegerator.../kegerators-kegerator.../5907-water-i...
Jul 18, 2009 - I have a Beverage Air 2 with front ventilating compressor. When I .....Also I do refrain from opening my kegerator door between kegs. I have ... need some help with BM23 - Dispense Forum ' Discuss Keg Beer ...
Aug 1, 2013
New To Me Bev Air BM23
Jul 16, 2012
Beverage-air condenser / thermo
Dec 31, 2009
Beverage Air BM23 Door Not Sealing
Aug 3, 2009
More results from www.micromatic.com
Kegerator leaking water inside - Home Brew Forums
Dec 28, 2015 | Beverage Air Refrigeration DD58C-1-B - 59...
Where can I replacement filters for a 100 cup West Bend coffee maker?
The West Bend Large Capacity Coffemakers do not use replacement filters. The manual for the West Bend 33600 Large Coffee Urn is available here:
http://www.westbend.com/supportdata/L5613B_LargeCapacityUrns-All.pdf
Use an electric perk or regular grind coffee in the percolator basket rather than a 'drip' or finely ground coffee that would require a filter.
If you require a new basket, please see the West Bend on-line replacement part site here:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=946&secid=87&linkon=subcategory&linkid=125
Mar 19, 2011 | West Bend 33600 Coffee Maker
I have my Mom's 193909WB coffeemaker, It runs like a top! How do I clean it?
Here are the cleaning instructions directly from West Bend's instruction manual. Good luck!
Cleaning Instructions
1. Unplug coffeemaker and allow to cool before cleaning.
2. Clean basket, stem and cover in hot soapy water with a dishcloth, rinse and dry. Coffee stains on underside of cover or stem may be removed by scouring with a damp cloth and a non-abrasive cleanser.
3. Clean inside of coffeemaker by filling with hot water until about one-third full. Add small amount of liquid dishwasher detergent and wash with a dishcloth or sponge. Then clean the heating unit well (where stem fits) with a scouring pad, to remove coffee residue. Twist pad inside heating unit well to clean thoroughly. IMPORTANT: If heating unit well is not kept clean, coffeemaker will not perform properly.
4. After cleaning inside of coffeemaker, drain and rinse inside. Clean faucet by letting clear water run through it into sink, while moving faucet handle up and down. Drain water from inside of coffeemaker and dry.
5. Clean outside of coffeemaker with a damp cloth and dry with a soft cloth. Do not use abrasive metal scouring pads or cleansers on outside of coffeemaker as scratching will occur.
DO NOT WASH COFFEEMAKER PARTS IN AN AUTOMATIC DISHWASHER.
Special Cleaning Instructions
To Remove Mineral Deposits: If coffeemaker is used daily, a special cleaning every 2 weeks OR every week if used for heating water, is necessary. Fill coffeemaker with 1 quart each of water and white distilled vinegar. (If a white mineral buildup has formed on inside of coffeemaker, use an additional 2 cups of vinegar.) Place stem and empty coffee basket in place, secure cover onto coffeemaker and plug in. Allow coffeemaker to complete perking cycle, then let stand for 10 to 15 minutes. Unplug and drain coffeemaker. Allow to cool and follow general cleaning instructions.
To Remove Discoloration: Inside of the coffeemaker can discolor when used for heating water, which is normal. To remove/lighten discoloration, fill coffeemaker with water to the level of discoloration (at least to the 12 cup level, but not past maximum cup level). Place stem and empty basket in place. For every 12 cups of water added to coffeemaker, add 2 teaspoons cream of tartar to basket. Secure cover onto coffeemaker, plug cord into coffemaker and then into outlet and allow coffeemaker to complete perk cycle. Let stand for 15 to 20 minutes or until discoloration is lightened. Unplug cord and drain coffeemaker. Allow to cool and follow general cleaning instructions.
Do not use baking soda to clean coffeemaker, as it will discolor inside metal.
After frequent use, coffee residue may collect inside faucet. To clean, unscrew top half of faucet. Move a small brush up and down through faucet. Insert brush through opening inside coffeemaker to clean faucet connection. Rinse and replace top half of faucet.
Jan 11, 2011 | West Bend (58036) 36-Cup Coffee Maker
I add water but it won't pump the water
check the heating element , with a test meter, hot water does not boil up to the cup if there is no heat ....
Mar 16, 2010 | Jura Capresso 454 10-Cup Coffee Maker
I have been losing water pressure in my single lever kitchen faucet, and I don't get really hot water.
It sounds like a clog internally. Sometimes o-rings, or just debris (like scale) in the water will cause a blockage. If you decide to "operate" on it, make sure you shut off your water supply. If it's old, you may not be able to buy spare parts and should consider a full replacement.
Jun 26, 2009 | West Brass Chrome INSTANT Hot Water...
New Westbrass water dispenser does not have the lines marked "red" or "blue" as described in the directions.
This faucet is the hot only version so it has two copper lines and one Santoprene rubber line. The copper line directly under the handle is the inlet from the wall - the second copper line attaches to the hot water tank by the corner. The Santoprene line attaches to the middle of the hot water tank. This faucet cannot be installed without the hot water tank.
Jun 13, 2009 | West Brass NEW Oil Rubbed Bronze Instant...
Strong plastic odor in West Bend coffeemaker
oh yes. This must be a new machine. I would recommend pouring and draining boiling water in the maker several times. You can also use vinegar, but again it has to be rinsed and refilled and rinsed again with boiling hot water.
Jun 11, 2009 | West Bend 56860 10-Cup Coffee Maker
Nut in oil tank of 1991 toyota corrolla is stuck
You might want to repost this because it is listed in the plumbing section. You will probably get more answers on the car side.
Mar 20, 2009 | West Brass NEW Oil Rubbed Bronze Instant...
No water at outlet
plidded up inlet is what it sound like, or too low like you said
Jan 11, 2009 | West Brass NEW Oil Rubbed Bronze Instant...
Manual or instructions
http://www.focuselectrics.com/supportdata/L5750_CocoaLatte_CM300_ALL.pdf
Downloads complete manual as PDF. I lost mine too.
Sep 21, 2008 | Back to Basics CM300 Coffee Maker
West Bend (58036) 36-Cup Coffee Maker Logo
53 people viewed this question
Top West Bend Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
Paul Bade
Are you a West Bend Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
