Question about Delta Monitor 13 Series Chrome Trim Tub/Shower with Dual-Spray Showerhead
The faucet is dripping. I want to replace the washers. The problem is how do I remove the handle? There are no set screws on the handle. I don't want to pry if off and do damage. Help!
  • 377 Answers
This is probably a good place to start looking:
http://www.masterplumber.net/delta/monitor.htm
Posted on Sep 15, 2010
  • pwillitz Sep 17, 2010
    THANK YOU VERY MUCH FOR THE RATING YOU GAVE ME!!!
    It s greatly appreciated and I am happy I was able to offer you some assistance.
Faucet is leaking
Hi Cindy you don't say where it leaking from so:
If you have a dripping that won't completely turn off then the stem washer needs replacing. If it is leaking at the handle then the "O" ring is bad.
I suggest you just replace both.
Under your sink turn off the two water supply knobs
remove the handle. Either a screw on top or and allen screw under and on the side then pry up. this maybe hard so wiggle it.
now take a crescent wrench and unscrew the stem
you see a washer screwed to the bottom. Most likely a "OO" size and a rubber "O" ring around the stem.
Take it the stem to your hardware store and have the give you a repair kit. very cheap
replace both and reinstall.
I it has 2 handles do both sides
Its easy.
Hope this helps Mike
Jan 17, 2016 | Moen 87530 Touch Control Single Handle...
How to fix a leaky Moen faucet that leaks at the spout ,which is separate from the handle?
These faucets can leak in three different places:
  1. Internally at the valve seat
    You'll see water dripping from the spout. This means the rubber washer is worn or damaged. To replace the washer, remove the decorative cap from the handle. Remove the retaining screw and pull off the handle. Remove the decorative cover, called an escutcheon, if there is one. Unscrew the packing nut counterclockwise. Unscrew the valve stem and remove it. Remove the screw that holds the rubber washer in place. Because these washers come in many shapes and sizes, you'll want to take the old one to the hardware store and buy an exact replacement. Be sure to buy two washers so you'll have one for the other valve. Replace the washer and reassemble the faucet.
  2. Around the handle
    If you see water coming from below the handle, the packing nut is leaking. Older faucets have a string-like graphite packing material wrapped around the stem. Newer faucets use an O-ring. First try tightening the packing nut clockwise... about one-half turn. If this doesn't stop the leak, remove the packing nut and replace the packing or O-ring; then reassemble the faucet. If the valve is using the graphite packing material, it might be a clue that you should shop for a new faucet.
  3. Between a pivoting spout and the body
    The spout might be held in place with a packing nut, similar to the faucet stem, or it might have a nut at the top of the spout. In either case, remove the spout and replace the packing material or the O-ring seal. Then reassemble the faucet.
Single lever faucets also are known as "washerless" faucets. They are easier to repair than compression faucets after you determine what type of faucet you have. There are three types of washerless faucets: ball, ceramic disk and cartridge.
Leaks are evident in two places... dripping from the spout and seeping from around the spout where it joins the body of the faucet.
Leaks from the spout indicate that the ball, disk or cartridge is leaking. To repair, turn off the water to the faucet, then remove the handle. The handles on ball-type faucets are held in place with a setscrew that requires an Allen wrench to loosen. Ceramic disk and cartridge-type handles usually are held in place by a screw hidden beneath a cap.
On ball and ceramic disk-type faucets, remove the ball or disk and replace the seals. You can buy replacement kits for these faucets at the hardware store or home center.
On cartridge-type faucets, remove the spout and pull out the retainer clip that holds the cartridge in place. To remove the cartridge, pull on the cartridge stem with a twisting motion. If it resists, install the handle so you can a better grip on the cartridge to pull it out. Take the cartridge to the hardware store or home center and purchase an exact replacement kit.
Reassemble the faucet according to directions.
Leaks at the spout-to-body joint indicate an O-ring failure. Disassemble the faucet as described above. Remove the spout sleeve and replace the O-rings. It's a good idea to replace these seals if you have the faucet disassembled for repair of the ball, disk or cartridge.
Sep 10, 2011 | Moen Plumbing
The faucet drips and I cant figure out how to make it quit.
It can be repaired without taking entire valve out of wall. First shut water off and remove handle. Next you will see a collar that will screw off to remove the cartridge below is a link for a single handle moen faucet. Check it out to get an idea. If you know your model you can research on line ,but they are close enough to give you an idea.
Once appart replace washers or o -ring's. Pay attention to how you take it appart for easy reinstallation.
http://www.moen.com/shared/pdf/t2703pt.pdf This link is aparts breakdown of a single handle faucet.
http://www.moen.com/shared/pdf/t2703pt.pdf This site is installation instructions.
http://www.efaucets.com/detail.asp?Product_Id=T2703 This site you can enter you faucet model to retrive information.
Jun 19, 2010 | Moen & One Handle Tub & Shower Faucet
I have an 11 year old, single handle shower control that when turned off has dripping. I have taken off the handle, etc and am at the wall. What is the next step or steps?
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
Dec 21, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Foremost 2 valve victorian tub faucet, dripping slightly. Can I change the washers and if so, how?
yes you can. First turn off water meter, or your going to get really wet. Pull handle, under that should be a packing nut, remove that. Now you should be able to remove stem. At bottom of stem should be small screw holding down all or part of a flat black washer. This is what needs to be replaced. Put back together in same order. All done, should be no more drip.
Sep 21, 2009 | Plumbing
Kitchen taps drip and leak.I do not want to replace with new but would like to sort these problems.
dependent on the type of faucet, you need to replace (a) the washers, (b.) the spring and seals or (c.) the gasket. They all serve the same purpose. 1. turn off the water supply to the faucet. 2. double handle? (a)remove the center cap (b) then remove the screw holding the handle down (c)next unscrew the valve stem retaining nut (normally it is the one right above the faucet body). (d) pull the valve stem out, if there is a small rubber piece held down by screw remove the screw, replace the washer. if there is a rubber gasket wrapped around the stem, remove and replace it, if nothing is on the stem look into the faucet body you should see 1 or 2 small rubber pieces these are the seals the springs are right below the seals. Remove and replace springs and seals. 3. single handle? remove the handle retaining screw, normally covered by hot/cold indicator symbol, unscrew valve stem retaining nut, pull the valve stem and replace either the gasket or springs and seals.
Aug 28, 2009 | Home
Been using shower for a couple of years .when fifished showering it will not shut water off all the way felt like stem was stuck not going back to close of water supply.After forcing it back all the way it...
First determind what side is dripping(hot/cold) then turn off water to entire house unless you have separate shutoff for shower behind wall. take a screw driver remove handle then use channel lock pliers to remove stem on the bottom side of the stem there will be a screw with a rubber washer on it you must remove the screw and replace the washer them re assemble Oh go to home depot and buy a the assorted pack of washer for faucets and stems find one that fits the pack cost about 4.99 best to change both rubber seal washer on hot and cold sinc e you have the water off
Jul 02, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Kitchen sink keeps dripping...how and what do I need to do to stop the dripping
Is this a single handle faucet or a double handle? If it's a single handle, you have to turn the water off then remove the handle. The set screw for this should be under a little plastic plug under the handle near the base of the handle. After you remove the handle, remove the housing cap to expose the valve ball. Under the valve ball are 2 small circular washers and springs. Pull them out and replace them. If it is a cartridge style faucet like a Moen, then you remove the u shaped retaining ring and pull the cartridge out.
If it is a double handle faucet, remove the handle and using a pair of pliers or a crestent wrench remove the stem. You will find the washer at the base of the stem held on by a screw. It could also be a washerless stem and in that case you will need to replace the whole stem.
If you have anymore questions, just respond to the post and I will get back to you as soon as I can.
Mar 22, 2009 | American Standard Plumbing
Delta Monitor 13 Series Chrome Trim Tub/Shower with Dual-Spray Showerhead Logo
349 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
