Question about LG Washing Machines
Has code le on display - LG Washing Machines
  • 15,935 Answers
LE indicates a fault with the motor on the appliance.
Is this a new installation?
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
Has a large load size been used with a gentle wash setting?
Gentle wash cycles such as Perm Press, Delicates, Hand Wash, and Wool/Silk should only be used for smaller loads. Because the cycles are more gentle while tumbling and spinning, too many items in the drum can register as an issue with the motor. In this instance reset the unit and run a test rinse and spin cycle.
Has the washer been overloaded?
Single bulky items or large loads can add extra weight to the drum and place stress on the motor. Remove some of the clothing and restart. If the issue is still present after a few items have been removed, unplug the washer for 30 minutes to allow the motor to cool and then restart the cycle.
NOTE: Make sure the drum is not overloaded
Are there soap suds visible in the drum?
Over-sudsing is the main cause of LE error codes. Using non-HE (high efficiency) detergents or too much detergent will cause stress on the motor. In addition, detergent residue can also cause leaking and odor. Follow these steps to resolved an LE error code caused by over-sudsing.
Step 1: Unplug the washer and allow the unit to sit for 30 minutes to give the suds time to dissolve.
Step 2: Plug the washer back in and press [Power] to turn on the washer.
Step 3: Do not choose a washing cycle. Press the [Spin Speed] key until "No Spin" is selected.
Step 4: Press [Start/Pause] to begin a drain only cycle.
Step 5: After the drain only cycle has completed, remove the clothing items from the machine. Turn the power back on and select [Rinse and Spin] and then press [Start/Pause]. This will remove excess soap suds and light residue from the drum. Repeat this step until no visible suds are in the drum of the washer.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
  • 18 Answers
If the code is le then the problem has to do with the water supply. Check that the water valves are open completely and that there is no kink in the water supply lines or blockage at the supply hose filter.
Posted on Nov 01, 2010
What does LE mean on display panel of my Samsung vrt front load washer?
Le means there's a problem with filling. Check to be sure inlet hoses aren't kinked, and no blockage at the inlet, as well as water turned on.
Feb 23, 2015 | Samsung 3.7 CuFT VRT Front Load Washer
New Hall Sensor & Rotor and code LE with some ringing noise
The LE code is displayed when the motor goes into an overload situation, if you have changed the Hall sensor and rotor, the only other problem is the stator overheating which will bring on the LE display.
Check the stator assembly, replace is faulty.
Dec 18, 2013 | LG WM2801HWA 4.5 cu. ft. Front Load Steam...
My 7 year old LG Front Load Washer Model # WM1812CW displayed ERROR CODE LE(Overload in motor): how can I fix this problem ? The rinse cycle begins, shortly thereafter, the machine stops and the LE code...
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Aug 29, 2011 | Washing Machines
F35 error
D?FAILLANCE DU CONTACTEUR MANOM?TRIQUE
If after 30 seconds the control does not detect water
entering machine, the valves will be turned off and the
error code will be displayed. OR If the control has
turned the water valves on and after 8 minutes the flow
sensor has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip,
the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
Si apr?s 30 secondes le syst?me de commande n’a pas d?tect? l’entr?e d’eau
dans la machine, le syst?me ferme les ?lectrovannes et commande l’affichage du
code d’erreur. OU Si le syst?me a command? l’ouverture des ?lectrovannes
d’entr?e d’eau et si apr?s 8 minutes le capteur de d?bit a d?tect? le passage de
10,5 gallons d’eau, tandis qu’aucune manoeuvre du manocontacteur n’a ?t?
d?tect?e, le syst?me commande la fermeture des ?lectrovannes et l’affichage du
code d’erreur clignote.
Appuyer deux fois sur la touche PAUSE/CANCEL pour commander l’effacement de
l’affichage.
Possible Causes / Procedure
1. Unplug washer or disconnect power.
2. Check to verify that the pressure switch is
operational.
3. Replace pressure switch.
This is for an F32...there is no F35 fault code on your model according to the service manual....
Sep 11, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LE in display
Hello,http://136.166.4.200/contents/Laundry/WM2277/WM2277xx_Service_Manual.pdf page 18 of this service manual elaborates on the LE error code and what to check.. Hope this helps you..
Thanks
May 30, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Code "LE"
Here is a tip that will help you understand the LE code...
http://www.fixya.com/support/r4348161-lg_washing_machine_le_error_code_or
heatman101
Apr 21, 2010 | LG WM0642H Front Load
Samsung washing machine LE error
Press "end of cycle". Plug off the wall. Code can be an indication of several issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire, see that all wires are tightened.
(that information taken from a link).
Good Luck!!
Thanks
Jul 12, 2009 | Samsung WF203ANW Front Load Washer
LG Tromm washer WM2077CW reading code LE
LE means "Overload in Motor" Unplug the washer, remove clothes, wait 15 minutes for motor to cool down. try again. If problem persists you'll need a certified technician.
May 31, 2009 | LG WM-2077C Front Load Washer
LE trouble code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. Good luck!
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
Washing Machines Logo
166 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
