Canon S300 printer Error light alternately flashes one green and one orange light. Have tried unplugging and replugging the power cord and this does not fix the problem. I need some other suggestions.
  • 1 more comment
  • Anonymous Nov 25, 2008
    Same problem here with a Canon i350
  • joeknee_m Mar 26, 2009
    The error light keeps flashing green and yellow alternately.
  • hinhcuty Dec 12, 2009
    I have 2 Canon S300, they both working good, suddenly one have alternate flashing light, next day the other one got the same problem...cannot reset it...even ask the canon technician...they ofer coupon to buy a new printer ...lol...
The same thing is happening to me. ever found out how to fix it?
Posted on Aug 25, 2008
Will not print
the sequence that the lights flash is how the error codes are given. Please count the sequence of flashes and re-post
Mar 27, 2014 | Canon PIXMA iP90v Printer
Pixma 4500 Alternate green orange lights flashing Green Orange repeats 12 times pause then cycle starts. Tried unplugging power cable and replugging. Rang Canon tech: no use. Couldn't even tell me what...
12 times is listed an AP position error:
Carefully slide and top covers off to reveal the print head. There is a device that slides back n forth and acts like a window cleaner squeegie on the printhead. This mechanism is probably stuck at its full extention rather than being back at home base. Every time you turn it on and off you should see it try to move but it will seem to be stuck. Give it a little assistance and that should release it. It can get glued up with drying ink. The mechanism that drives the sliding squeegee relies on a spring for it to return and the spring isn't strong, so the whole thing jams up...
which is probably what the code means - jammed mechanism.
Mar 08, 2010 | Canon Pixma iP4500 InkJet Printer
Power light (or Alarm and Power lights) alternate(s) between orange and green After long green flash, there are 2 or more alternating orange and green flashes. There may also be a Service Error message on...
Try resetting the printer by unplugging the printer from the power source for 5 mins. and they make sure ink is full and paper is loaded and not jammed. If not resolved carefully remove all ink cart from machine without touching and ink cart metal contacts, reseat the ink cart and reset and the printer.
Feb 21, 2010 | Canon i850 InkJet Photo Printer
Canon i9100 printer with flashing 5 orange lights then green
That error says you need a new printhead,
QY6-0039-000 around $40.00. resetting won't help. You shouldn't need a shop for this replacement.
Sep 16, 2009 | Canon i9100 InkJet Photo Printer
Service Error 5100
Somtimes in order to get the printer to reset properly you must turn it off, unplug the usb (or other data cable), unplug the power cord and wait a bit. (Canon says 10mins.!).
Then reconnect cables and turn it on.
This should reset an alternate orange/green light condition.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Apr 06, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Error 5100
Hello! Try this:
1. Unplug the power cord
2. While pressing the ON button, plug the power cord back in.
The power light should flash an orange/yellow color.
Continue pressing the ON button, and press the RESUME button 4 times. The light changes every time you press it.
3. Release both buttons, and restart the printer.
The printer should now stop blinking and operate as usual.
I hope this works for you. OMS
Apr 05, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Printer does'nt work
You printer is giving you an error code with its flashing coloyr lights. I would consult canons website and write down the exact colours it is flashing as this is a specific error code. Most likely it is a paper jam error or reading error. Before you contact them i would try resetting the printer by powering down, unplugging all cables and cord, replugging and turning on and retry print jobs. If no luck go to plan B, webesite, and find error code. I am sorry i have no deatils for this printer to give you the error code myself.
Aug 31, 2007 | Canon BubbleJet i560 InkJet Printer
575 people viewed this question
jasbo
jasbo
