Question about Stairmaster 4600 Cl Cordless Freeclimber
Where in the world is the battery for the Stairmaster 4200 PT? I have read the manual multiple times and taken the cover off and still can not find it. Help!
  • Stairmaster Master
  • 918 Answers
There is not a battery in this unit. Stairmaster steppers that require a battery are labeled as CL for cordless. The PT machines have a power supply that plugs into the wall.
Stairmaster Stepper 4200PT Parts Eccentric Hub Pedal Arm SPORTSMITH net
Posted on May 21, 2014
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: stairmaster climber model 4600 pt pedals go all
Unplug dc power connection then remove right side panel check for loose connections on on alternator, check distance of speed sensor to speed sensor disc you should no more than 3 credit card distance between them. Next remove the black wire from the B+ terminal on the alternator, then remove the brown wire from the field terminal on the alternator.Place a short wire with alligator clips between B+ and field terminals start stepping for about 10 to 15 second you should full resistance in that case its the upper console that if not replace alternator
Posted on Mar 14, 2010
Resets after begin
My Stairmaster unit seems to work in manual mode, but resets when I select a program. What is wrong? It is possible that the console on your Stairmaster unit may not be configured for the appropriate machine. This can result in the console accepting and allowing a manual workout but not accepting or allowing a program. Stairmaster Units Works in Manual Mode but Not in Program
Feb 24, 2014 | Stairmaster Stepmill 7000 Pt
My stairmaster 7000 pt has no resistance
I would suggest checking the brushes in your alternator. The alternator is the component that provides the resistance in this unit.
Repair Parts for Stairmaster Equipment Batteries Springs Belts Chains...
Nov 29, 2012 | Stairmaster Stepmill 7000 Pt
Stairmaster won't have a continuous workout
Nov 01, 2012 | Stairmaster Exercise & Fitness
My stairmaster 4400 PT shows "config rqrd" How do
Display reads CONFIG RQRD or NTM CONFIG RQD on Stairmaster Equipment Probable Cause The message CONFIG RQRD or NTM CONFIG RQD appears when the console needs to be configured for the machine type it is installed. This message is common when the console has been replaced or if the settings have been changed. Message is commonly seen on various Stairmaster equipment such as bike models 3000CE, 3300CE, 3400CE, 3600RC, 3800RC and 3900RC; stepper models 4400PT, 4600PT, 4400CL, 4600CL and SC916; stepmill models 7000PT and SM916; elliptical model ClubStride 5100.
Corrective Action
  • Make sure the unit is in an "idle" state. "Idle" state means the console is not displaying an error or any message that requires data input. The display should basically be freshly powered up, scrolling the EKG or welcome message
  • Configure the console for the proper machine type by pressing Level UP, 80, ENTER
  • Using the Level UP or Level DOWN keys, scroll through to the proper machine type (Bike, Elliptical, Stairclimber or Stepmill)
  • Once the proper machine type is shown on the display select the machine type by pressing ENTER
  • This completes the steps necessary when your Stairmaster display reads CONFIG RQRD or NTM CONFIG RQD
Stairmaster Console Message CONFIG RQRD or NTM CONFIG RQD
Oct 14, 2011 | Stairmaster 4400 PT Stair Stepper
My Stairmaster 4000 PT pedals have no resistance. I have replace the brushes on the alternator. Any ideas ?
have diode on the alternator checked , check all wiring connections to be tight, is the battery ok (6 volts ) and last check the motor control board for damage and/or electrical burn
Jan 17, 2011 | Stairmaster 4400 PT Stair Stepper
Pedals going all the way to the floor
Remove the covers inspect all connections need to test ( remove red and black leads ) the battery with a multi meter to see if you have 6.1v if not replace the battery. If battery is good then check the alternator, unplug the unit and also leave battery unplug .
Locate and remove the black wire from the B+ terminal on the alternator ( larger nut then the others across from the brown lead) . Remove brown lead from the field terminal on the alternator. Place a short with alligator clips on the B+ and field terminals of the alternator.
Step on the machine for approximately 10 to 15 seconds, if the full resistance , if not then replace alternator. if alternator is good then check the load resistor with a multi meter resistance needs to read 2.5 ohms if not replace resistor.
May 24, 2010 | Stairmaster 4400 PT Stair Stepper
Looking for a manual for stairmaster 4600 free
Hi, I just purchased a used StairMaster 4600CL last week, and found a link for an owner's manual that covers the StairMaster FreeClimber 4200 PT, 4400 PT/CL, and 4600 PT/CL. This is a free, .pdf download:
http://gymstore.info/manuals/upload/StairMaster/stairmaster_freeclimber_4200_4400_4600pt_cl_c40_om.pdf
Vanessa
Jan 23, 2010 | Stairmaster 4600 Cl Cordless Freeclimber
Open Questions:
Stairmaster 4600 Cl Cordless Freeclimber Logo
134 people viewed this question
Top Stairmaster Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Matt Olenzek
Matt Olenzek
fordexpert
Are you a Stairmaster Exercise and Fitnes Expert? Answer questions, earn points and help others
