Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer will run, no heat I think the heating element is out, how do I replace it. Model MD5500
  • Maytag Master
  • 43,501 Answers
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
I have a Maytag Neptune gas dryer, model #MDG4000AWW, Serial #10793672WF. The unti is operating but doesn't heat up. Do you think it is the igniter and/or the heating element? Also, can I replace...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer modell md5500. Electirc dryer, contorl panle lights up, heat comes on but drum does not turn.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 19, 2011 | Maytag Dryers
MAYTAG GAS DRYER MD5500 DOES NOT HEAT
heatman101
Nov 29, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Hello . i have no heat in my maytag neptune model md5500 dryer how can i fix it the gas is ok. Z.z.
check your burner make sure it is clean, if it is dirty either blow it out or vacuum it out. If it still don't ignite it may be the thermo copuler. Hope this helped Tim
Sep 03, 2010 | Maytag Neptune MDG5500AW Gas Dryer
The heating element went out and the machines are not old enough for that, I wouldn't think but it isn't heating up or drying.
Before replacing the heating element, I would check the sensors that are attached to the heating chamber. They can be disk shaped with two wires connected to it. Also there may be a thermal fuse in that same area with two wires connected. Check those parts with a continuity tester or ohm meter after the wires have been disconnected and with the dryer unplugged. The thermal fuse runs about $20.00 dollars or so depending on the model.
Jun 11, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer does not heat up.
Hello there:
normally on these units if the dryer was working ok and then suyddenly stopped heating your heating element or the ignitor (excitor ) has failed and is need of replacement
so i would start by having these things checked first by contacting a local repair man to do a evaluation on the unit and if kyou still have a valid warranty i would use it ok
I hope that this is very helpful for you
Best regards Richard
Nov 16, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Neptune dryer does not produce heat md5500
Did you cheak for dead short by touching one end of the element and one end on the heater housing?if there is continuity then you have a dead short .The lint is normal just clean it out.You may have a bad insultor that the element runs true in the heater housing.Also cheak the wires for dead short very carfully with flash light hope this helped:)
May 19, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Heating Element
your dryer is a 220 plug check the circuit breaker first
one 110 runs the heating element and the other 110 runs motor and dials
this is usually the cause of dryer malfunctions
heating elements are simple big mesh of curled metal wire like a toaster but more of it
it would take alot to knock out the heating element
check the dials too these could be sticking or worn dials you dont have to run dryer to check dials
Jun 27, 2008 | Maytag Neptune MDG5500AW Gas Dryer
could be the heater element, check for circuit with a test meter if it does not heat up in the minute it runs this is almost certainly your problem
Oct 06, 2007 | Maytag MDE2400AYW Neptune Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
633 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
