Question about Ovens
Philips 90 series oven guide for AKB490/P/02
How do I turn off the timer on my gaffers & sattler wall oven?
Try rebooting the oven; unplug it for 90 seconds, or flip the circuit breaker off for 90 seconds, then back on.
Apr 17, 2016 | Ovens
Blodgett gas oven 60-90 sec main b urner goes out
After burner on did you hear any spark ignitor if that your flame sensor is dirty or need to replace....good luck
Dec 11, 2013 | Blodgett DFG-100 Gas Single Oven
Wall oven is not baking properly
Look in your Owner's Guide to see if the unit you own has a way to configure or calibrate the temperature yourself before contacting a professional.
Jul 18, 2012 | Frigidaire Ovens
Takes an extremely long time to cook in oven, but elements seem to be working
If your oven has a digital timer then it is capable of being calibrated. Usually the oven is pretty close to accurate but can vary sometimes. In your user guide it may explain how to adjust the setting. You need to purchase a thermometer that you can put in your stove. Set it to 300 degrees and time how long it takes to stabilize. It is possible your stove will not get to 300 but to 270 or 280. If this is the case then the thermostat needs calibration. You can find out how to do this out of your guide or in the tech sheet that you should be able to find on line.
Jan 13, 2012 | Frigidaire 30 in. Electric Gallery Series...
I have an alaska micro wave oven series MW 1000 GC and I need the users guide of this appliance.
i need alaskar mw 1000g electrical diagrame and how find out to trouble shooting... thanks very much..
Feb 01, 2011 | Ovens
How does one rmove the oven door of a jenn air oven. I can not find instructions in the owners manual or installation guides/instructions. Do I need to remove the hinges or is there a release mechanism?
Look at the hinge, their is like a slider bar to move or you remove the little cover plate, with the Philips screw..then lift the door up and out while pulling...
I WARN YOU, if you really don't need to remove the door don't, it is very hard to put back on unless you have had practice....
Dec 19, 2010 | Jenn-Air Electric Double Oven
Kitchen Aid Oven - Superba Selectra- receive
Here is what Kitchen Aid says about F4:
F4 Meat probe shorted
1. Disconnect meat probe and measure probe resistance (78kω at 60° F [15.6° C],
37kω at 90° F [32.2° C]).
2. If resistance is not valid replace probe.
3. Insert probe and check for a firm connection between probe and jack (in oven cavity).
4. Check connection between jack and harness (in rear of oven).
It sounds like the probe jack may be bad or the wiring between the jack and the control board above.
May 10, 2010 | KitchenAid Architect Series KEMC308KSS...
The self cleaning instructions for my Frigidaire Gallery Pro Series Model FEB798WCCH do not inform how long to set timer. Any instructions would be helpful as I've never operated a self cleaning oven...
Hello- The function is automatic when clean button is pushed. Oven will lock, and turn on at full power for about 90 mins. This 'feature' can, and usually does eventually burn out circuits in the control board. Techs call this the 'self-destruct' option, cheerfully promoted by the salesman. Avoid using 'self clean'!  Scrape and clean with light soap/water. Turn on to 450deg. for about 30 min. This is about half the temp. of a 900deg. 'clean' cycle and a lot less expensive in the long run. Please acknowledge this post if info is helpful- have more if needed.- Thanks- Ed
Mar 19, 2010 | Frigidaire 30 in. Electric Gallery Series...
F-90 error...nothing will turn on
shut the power off for 30 mins at circuit breaker and then it worked after that.
Jun 05, 2009 | Frigidaire 30 in. Electric Gallery Series...
Ovens Logo
214 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
