Question about Maytag MER5750 Electric Kitchen Range
My Maytag MER5750AAA electric range does not heat on the cooktop or the oven. The control panel works as far as the digital readout. The oven controls lead me to believe the oven works but neither oven heating element is working. When the oven controls are on, there is occasional "clicking", that is usually apparent as the oven heats up.
  • ajazzyb Sep 12, 2010
    Right before the oven and cooktop stop working, my wife used the oven
    for about 1 1/2 hrs, heating it to 350 degrees. No error message
    appeared on the digital display. Then she went to use 1 burner
    (ceramic top) and nothing................
  • ajazzyb Sep 14, 2010
    Once I took the back panel off, the problem was obvious. The
    power cord apparently overheated. The 1/3 part of it that
    controls the oven / burners actually appeared to have caught fire, as
    that 1/3 part was melted and broken at its connection to the
    stove. Bought a new power cord at Lowe's, problem solved.
    But, what caused the cord to overheat? and could this happen again? (Stove is 10 yrs old.)
    Thanks,
    Jim
  • 1,711 Answers
Can you please what happent before the problem occur and what massage you had or have on the display
Posted on Sep 12, 2010
  • 1 more comment
  • espressonist
    espressonist Sep 12, 2010
    You most probably have a loose wire since from your description everything work fine. So the relay contact connect on but the power is not on from a loose wire in one place. By a good visual check and an electrical tester the loose wire can esily identify and poot together again. This a frequent problem with range and ovens since the heat can make some conection become loose and sometimes completly desconect.
  • espressonist
    espressonist Sep 14, 2010
    Good new that you find so easy the problem.
    As for the wire it was like it burned due to the combination use of the many cooktop and oven at the same time for long periods and also with high ambient temperatures. So as you may understand this may hapent only sometime during the period of 10 years. So in the next 10 year probably you may need a similar service repair the cable even the conector.
    One thing that may help is when using the oven try not to use the cooktop for long preriods.
    Thank you for using Fixya and please remeber to vote thump up for us.
    Take care
  • espressonist
    espressonist Sep 17, 2010
    If you have solve the problem we would apreciate it if you could vote thump up for us, Thanks
I have a Maytag slide in electric range model MES5770AAB.
can not really say what is might be but here is link to diagrams and parts list Parts Model MES5770AAB Sears PartsDirect
Sep 13, 2014 | Maytag Slide-In Electric Range
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
My maytag freestanding stove won't turn on. The clock works but the stove or oven won't turn on.
Need more in fo-gas or electric: If electric,I have seen problem in electrical box over time the screws where wires are connected over heat and get loose or break check both ends and disconnected electrical cord before doing this.Check all wires.
Sep 15, 2012 | Maytag Stove / Oven / Range Cooktop -...
Oven goes to max temp when powered on. shut off with circuit breaker and restsrted, oven goes to max, Control panel not operating correctly
change the oven sensor probe thats mlocated in the upper left corner of the oven chamber and connects to the digital readout control board
Sep 11, 2011 | Maytag MGR5775QD Gas Kitchen Range
Kenmoe Electric Cooktop and started beeping and fan is running
A F1 code is a bad ERC electronic range control.(clock).
The ERC must be replaced.
Mar 18, 2010 | Kenmore Kitchen Ranges
I have a Maytag slide-in range and the touch pad to the oven went dark and doesn't work. The cooktop works! It went out while cooking and we had to turn the breaker off to turn the oven off. What's wrong?
your control board is defective and needs replacement,you can do this by removing the rear cover behind the control board and removing the screws holding the electronics panel
Jan 08, 2010 | Maytag MES5752BAS Stainless Steel Electric...
No heat on the upper oven bake and broil elements
I gather you are measuring voltage with respect to the chassis ground?
http://www.appliancepartspros.com/07-wiring-information-parts-for-maytag-cwe5800acb.html
Shows the internal wiring for the unit. The parts are rather expensive and some are no longer available.
Mar 22, 2017 | Kitchen Ranges
Maytag MER5750 Electric Kitchen Range Logo
103 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
