Question about Compaq Presario 700 470024-192 Notebook
When i push the power button nothing happens even on the mains plug in
  • mrb201 Sep 12, 2010
    When i push the power button nothing happens , even when i plug in the mains surply,but on the bottom left hand corner is a flash simblewhich flashes when you push the power button
  • 2,567 Answers
1. Take the battery out of the laptop & try to turn on the laptop using power adapter only. If the computer turns on, then the battery is defective & needs to be replaced.
2. Make sure the power adapter is not defective. Test the output voltage of the power adapter using a voltmeter. Compare the voltmeter reading to the nominal value written on the adapter or the laptop.
3. Make sure the DC jack is not loose or broken. A loose DC jack will need to be re-soldered. A broken one will need to be replaced.
4. If you have another processor which is compatible with your laptop's model, try swapping processors & test to see if the laptop will work.
5. The power button could be bad.
6. The motherboard could be defective & needs to be replaced.
Posted on Sep 18, 2010
LC-42LB261U. Why does nothing happen when power button is pushed?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Sep 19, 2015 | Sharp Televison & Video
When power button is pushed the red light comes on but nothing happens. I also have to hold the power button down for 5 seconds before it will turn off. Also when you plug it in it will click once.
Without model number it's hard to even advise. But in general when that happens on anything there is a problem with the board, either power or main.
Sep 03, 2015 | Televison & Video
Sharp aquos tv, model no. lc-70c-6500u, no audio, visual at power up, standby/power light flashes 2 times long, 5 times short, nothing else happens, what is this mean?
Sounds like main board fault. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jul 28, 2015 | Sharp Televison & Video
Lenovo thinkpad t400 laptop wont open
try changing the keyboard because switch is on keyboard and use adapter to plug and test
Mar 25, 2014 | Computers & Internet
When plugged in to mains nothing happens
plugged into mains as in plugged into power in wall? since we don't have a model number can you check to see if there's a power switch or button on the back of that drive?
May 21, 2012 | Computers & Internet
Nothing happens when you push the power button
i could be static build up . this is common. Try taking the battery out and unplug the power adapter. now with both removed press the power button on the laptop for approx 20 secs. then plug it in and see if it boots up.
Dec 02, 2009 | Compaq Presario 700 470024-192 Notebook
TV shut off Sony Trinitron KV-32S20
I believe this uit has a fuse on the AC input on the main PCB. Yu probably blew that fuse.
Jan 16, 2009 | Sony KV-32S26 32" TV
Compaq Presario 700 470024-192 Notebook Logo
29 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
