Question about Samsung Cameras
Camera flash flash stopped working on camera
  • ickymc May 15, 2008
    wher do i get bulb and are they easy to fit as flash looks built in thanks ickymc
    President:
  • 2,712 Answers
You may need to get the bulb replaced..
Posted on May 14, 2008
Flash will not work
Before you give up on the camera:
There are many setting that can affect whether the flash works or not.
You may have inadvertently set something that is stopping the flash from working.
Get out your User Manuals and use the index at the back of the book.
Look for something about "Resetting the camera".
This will reset the camera to factory specifications.
Then see if the flash works.
If that does not work ... recharge the battery and try again.
If that does not work, the flash is likely dead.
May 30, 2010 | Canon PowerShot A590 IS Digital Camera
Flash stopped working
Jan 05, 2010 | Canon PowerShot A590 IS Digital Camera
Have you tried to reset the camera to its factory defaults to see if it is a setting that is causing the flash not to fire? To reset the camera go to the menu left arrow to reset - highlight yes and press ok. This will set the camera back to factory settings. See if the flash fires now. If it does then, good. If not, then it is a repair issue with the flash assembly internally in the camera.
Mar 23, 2009 | Olympus FE-210 Digital Camera
Fujifilm FinePix 3800 flash will not work
Normally when the flash stops working it is because the capacitor the camera uses to store the flash power ( that is what charges..not the bulb) burns out. This is a very difficult repair and should only be completed by a camera technician.
If the repair is over 10 dollars I would suggest a new camera.
Jan 28, 2009 | Fuji FinePix 3800 Digital Camera
Flash on camera has stopped working
Have you checked the flash settings, quite often the flash accidently gets turned off, on most cameras the buttton looks like a lightning bolt. Toggle through the settings if it is not on a button on the camera.
Jan 16, 2009 | Fuji Rod Repair Kit
Flash not working
Hey influenza,
Nearly dropping the camera should not affect the operation of the flash unless the flash was extended and you caught the camera by the flash and it is somehow physically damaged. What is more likely is the camera is either set to a mode that doesn't allow the flash to operate, or the flash is set to auto off. Directions on how to turn the flash on or off start on page 34 of your camera manual. I have included a link to a PDF download of your camera manual in case you need it. I hope this helps!
http://www.nikonusa.com/pdf/manuals/noprint/D40_noprint.pdf
Sincerely,
Allan
Go Ahead. Use Us.
Jul 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Flash
Flash board is located on the top of the camera and it contains your shutter and video buttons. It also contains a 330 V capacitor that stays charged. If there is no charge, then the camera will say flash charging. If the camera persistently says flash charging, then the flash on your camera stopped working.
I found a flash board on ebay for 10 bucks plus shipping. To repair the flash involves in taking the camera apart. It is can be tedious but it is rather easy to do. If you are interested, I send you detail instructions.
May 09, 2008 | HP Photosmart M407 Digital Camera
Flash stopped working after 1 month
I had the exact same problem,on the back of the camera there is a 3 position slide switch make sure its in the position that works with flash mine is in the middle spot I think the switch is/was a bit dicky try playing with the switch a bit,anyway mine now works 100%.Try it anyway.John Leigh.
Apr 15, 2008 | Nikon COOLPIX L10 Digital Camera
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Jan 19, 2008 | Sony Cyber-Shot DSC-T33 Digital Camera
Cameras Logo
73 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
