Question about GE WBSR3140DW Top Load Washer
No cold water.
We just got ahold of a GE washer. For some reason the cold water wont work. The water is on (it has been checked.) But the cold just wont work. Any ideas?
  • 5,911 Answers
If it's not something as simple as cross connected hoses, or a valve not turned on all the way, you probably have a bad water inlet valve (also known as a fill valve or mixing valve). The part is available at searspartsdirect.com under the "Controls and Backsplash" heading as item number 805 in most of the drawings. There are numerous part listings provided. You will need to provide a more complete model number to narrow the search down to identify the correct part. All you have to do is type in your complete model number in the "Search by Model Number" block and follow the links on the next page. There are helpful illustrations to assist you as well. If you need advice on how to replace, please reply to this posting and let me know. I hope this helps.
PS You can attempt to remove the hoses and clean the sediment screens on the valve as well. It may save you from having to purchase a new one.
Posted on May 15, 2008
I have a GE HydroHeater front loading washer and it wont fill with water
First make sure water supply is on. Next try just cold OR hot water fill and feel the hose where it connects to the washer. Do you feel a faint buzzing or humming? If yes, you may have a clog in the line. If not, check that power is good to maxhine. If power is good, then control board is suspect and needs to be tested.
Nov 08, 2013 | GE Washing Machines
Gfwn1100lww ge front loader washer wont fill with
check your water lines could be clogged or not even turned on at the valve behind it, also might be not enough pressure in line to make it work
Sep 25, 2013 | GE GFWN1100LWW Washer
Washer wont fill
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
dhjd
May 20, 2010 | GE WBSE2090A Top Load Washer
Water comes out verryy slowly when using cold wash GE large capcity washer
check the fill hose washer located in the washer cold water fill hose,they get clogged with lime and such,and when you replace the washer run hot water thru the hose to clean it out thoroughly,
Apr 24, 2010 | GE Profile WPRE6100G Top Load Washer
My ge top load washer will not allow cold water through it just drips out slowly. water comes out the water line but for some reason the machine wont let it through
Could be a clogged screen on the back of the inlet valve. If you have hard water and no water softener, especially likely. Turn off the water at the water, remove the cold water hose from the back of the machine and see if there is an accumulation of white crumbly material just inside the body of the valve. If so, carefully remove it, then use a screwdriver to remove the protective screeen inside the valve. It is a press fit and will come out with a little effort. Do not puncture it. Clean and reinstall, hook up the hose and turn on the water. Check for leaks and you should be back in business.
Mar 03, 2010 | Washing Machines
Can I use only cold water with my GE front load washer
Just used the cold water and plugged the hit water tube. It worked.
Mar 18, 2009 | GE Profile WPXH214F
No Cold Water
THE SOLENOID VAVLE IS DEFECTIVE,NEED TO REPLACE IT, ITS WERE THE HOT AND COLD HOSES CONNECT TO BEHIND THE WASHER WERE YOU CLEANED THE SCREEN. NEED TO TAKE IT OUT AND REPLACE. ITS A ONE PIECE IT SHOULD BE RED OR BLUE OR SUMTHIN LIKE THAT.
GET THE MODEL NO AND SERIAL NO AND SOURCE AROUND FOR A REPLACEMENT PART. ALWAYS GO WITH THE ORIGINAL PARTS SO IT WOULD LAST LONGER, THEN TO MODIFY AND COST YOU MORE MONEY, WHEN IT SHOULDNT.
Oct 05, 2008 | GE Profile WPRE6100G Top Load Washer
GE washer
replace the water inlet valve
Jun 10, 2008 | GE WBSR3140DW Top Load Washer
GE Washer wbsr3140d5ww water problem
Hello Chad
Welcome
Sounds like the cold water knob or switch is not switching and may be faulty.
I have a problem with my washer
For some reason when I try to start the washer and I have it set to cold it does not work if I put it to hot then its fine
The cold water does work though because if I change the washer to a later cycle cold water comes out just fine.
So it almost seems like its the timer knob
any ideas?
Thanks
Please remember to leave a rating
Jun 04, 2007 | GE WBSR3140D Top Load Washer
GE WBSR3140DW Top Load Washer Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
