Question about Philips LX3000D System
Hola tengo Home tuiter de Philips Lx300d y no como conectar en que ordenlos parlantes.
ThaMp3Doctor
  • 8596 Answers
SOURCE: no funciona mi mp3 Philips GoGear SA178
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
FARADIO
  • 17 Answers
SOURCE: problema de imagen en tv philips
hola,
checate los ics de convergencia,pero que te ayude un tecnico por que estan un poco dificil de cambiar,son los stk 392-120 son dos,ok.
Posted on Feb 16, 2008
SOURCE: No sale driver en la lista
Hola!
Se puede descargar el driver de algún lado? No aparece en la lista de controladores disponibles en el equipo. Mil gracias
Anton F.
Posted on Oct 07, 2008
  • 8 Answers
SOURCE: no reconoce la placa de tv
Windows 7 aun tiene algunos problemas con la compatibilidad de controladores, lo mas seguro es que tengas que esperar a que el fabricante de esa placa actualize el controlador pra win 7, que no creo que tarde mucho o la otra opcipon es regresar a vista o xp
Posted on Jul 28, 2009
  • 10865 Answers
SOURCE: tv philips 42pf7320. prende ,peroluego
Hola! El calentamiento podr?a valer la pena el electrolytics ups con un secador de pelo antes de encenderlo. Tenido un problema similar en un plasma Philips causada por una duff condensador.
Jose'
Posted on Oct 14, 2010
Hola tengo un unitech ht680-9560UADG como me conecto a mi red local mi correo es naiky10k@gmail.com
naiky10k: Para que puedas conectarte a tu red local debes de tener access points o routers inalambricos para tener la cobertura inalambrica. En la terminal debes de habilitar la tarjeta wifi, automaticamente reconocera las redes disponibles o entra en Start - Settings - Connections - Network cards y selecciona la red a la que te quieras conectar habilitando los parametros de tu red. Para transferir archivos puedes instalar un servidor ftp de Mochasoft que es gratuito. O en su defecto, desarrolles la aplicacion que necesites. Si necesitas un desarrollador de software, quedo a tus ordenes. Roberto Martinez padrino99@prodigy.net.mx
Aug 08, 2011 | Unitech HT680 Handheld Mobile Computer PN...
Como programar un control nuevo a la caja de dish.
hola, tengo un problema con mi control remoto de dish es un 3.4 IR le cambie las pilas y ahora no logro que responda, como apagar la caja o cambiar canales, no responden todas las funciones, si puedo apagar la tv y el volumen.
May 12, 2011 | DISH Network IR Remote Control
Hola el problema es que son dos telefonos registrados en una base pero el 2 que seria el movil no funciona no da linea suena como si estuviera ocupado,ya lo intente con el manual y nada ha es nuevo gracias...
Hola, el procedimiento sujerido del fabricante en este caso es el siguiente:
  1. Retire y vuelva a colocar las baterias
    del terminal.
  2. Intentelo de nuevo desconectando la
    alimentacion de la base y volviendola a
    conectar y siga el procedimiento de
    registro de un telefono.
Registro de un auricular.
  1. Inserte la bateria para encender el
    auricular. En la pantalla LCD
    aparecera "PULS TECLA OK
    PARA REGISTAR".
  2. Pulse pantalla LCD aparecera "PULSE
    PAGE DURANTE 5 SEGS".
    Antes de que transcurran cinco
    minutos, pulse la tecla de
    localizacion (PAGE) que se encuentra en la
    estacion base para iniciar el proceso
    de registro.
  3. Si el registro se realiza con exito, el
    auricular volvera al modo en espera.
    Si el registro no se realiza
    correctamente, en la pantalla LCD
    aparecera "PULS TECLA OK PARA
    REGISTAR". Repita el proceso de
    nuevo.
Feb 28, 2011 | Philips CD1503B/17 Phone
Hola me sale un cartel que dice dns NO disponible continuamente en mi celular, samsung b3410
hola yo tengo un celulat gt-b3410 y cada tanto me pone unos carteles de usuario y contraseña no validos y otro cartel de error de DNS y demas carteles, quisiera saber como como hago para poder arreglarlo muchas grax
Sep 27, 2010 | Samsung B3410 Cell Phone
Como conectar las dos bobinas
Hola angel1781,
Las bobinas se pueden conectar en serie, que los resultados en dos veces la impedancia de una bobina, o paralelamente, que parte en dos la impedancia.
Vea los esquemas eléctricos aquí. Seleccione el cableado de la bobina que da lugar a una impedancia por lo menos tan arriba como sus ayudas del amperio. Más arriba es ACEPTABLE, más bajo no está.
http://www.kicker.com/dvc_wiring
Espere que esto ayude.
Aug 04, 2009 | AudioBahn DUB200 Car Subwoofer
Problemas de transmision automatica
hola que tal, tengo un saab 9000 1988 y tengo problemas con la transmicion aveses me hace los cambios y abeses no, si abansa para atras y para adelante pero me abienta los cambios cada que quiere,,, alguin tiene idea de que pueda ser?? nesesito ayuda ya estoy desesperado...
Aug 02, 2009 | 2001 Hyundai Accent
Compre en Miami en el a?o 2005 un teatro en casa Panasonic, modelo No SA· HT680 y en el 2008 me lo traje para Colombia y en la transportadora extraviarion 4 parlantes de este. que puedo hacer para volver a...
hola mendez eso pasa en las aerolineas puedes adquirir unas bocinas que no sobrepasen la carga que dice tu aparato normalmente son de 6 ohms y las pequeñas de 4 ohms un tecnico te puede decir en donde y cuanto cuestan aqui en mexico cuestan como 600 o 700 pesos el juego para el homethater panasonic saludos por alla hermano es la primera que me dicen que en español saludos
Jan 17, 2009 | Audio Players & Recorders
Problema
hola tengo 1 ilo-32hd pero no me responde el control ni puedo cabiar de canal gracias
Oct 28, 2008 | iLO 3200 32 in. LCD Television
Scanner Mustek mod. 600 III EP -[ Plus
Hola Julian: Eso que comentas es el power de tu scanner, puede ser conectado a cualquier toma corriente de tu casa con el adaptador adecuado y no necesariamente a tu computadora.
Pasa que algunas computadoras como la tuya tiene entrada de power para conectar este tipo de devices para darle corriente a los scanner, parlantes o cualquier device externo que necesite power.
Ese cable lo conseguis en cualquier store de electronica, es un bridge. (un puente de corriente entre tu compu y el scanner)
Sino la otra alternativa es conseguir un power supply para tu scanner. Eso es todo.
Aca tenes el power supply:
http://cgi.ebay.com/15HB-power-supply-ADAPTER-15v-1A-HP-Mustek-UMAX-scanner_W0QQitemZ370092779651QQcmdZViewItem?hash=item370092779651&_trkparms=72%3A1156%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
Oct 04, 2008 | Mustek TwainScan 600 III EP Plus Flatbed...
Philips LX3000D System Logo
181 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
