Question about GE JGRP17 Gas Single Oven
I have a GE Spectra XL44, model #JGBP40BEC4WH gas oven. The 4 burners on top work but the oven will not. I replaced the oven safety valve (dual type 1), thinking that it was stuck and not directing gas to the oven. I still have the same problem, no gas, no flame in the oven. The red light comes on at the dial, but it never ignights. I checker the electrical connections at the safety valve and they are ok.
  • 494 Answers
Most likely, you're oven igniter is not getting hot enough to open the gas valve to ignite the burner. It glows like normal, but does not reach the temperature required to open the gas valve. Replace the igniter. Before you replace that, make sure that the small shutoff lever on the appliance regulator was not accidentally closed, which would turn off the gas to the oven, while still allowing gas to the stovetop. The silver lever should be sticking straight out or up. Douglas
Posted on Sep 12, 2010
GE XL44 Gas Stove and Oven. Everything works normal except the oven which stopped working suddenly (no flame). Couldn't find the manual to check troubleshooting guide.
The oven uses a silicone carbide ignitor which requires 3.6 amps or better to open the gas safety valve.
If you don't see any glow from it then it is either blown or the gas valve has gone bad. If it is glowing but not real bright it probably is weak.
How it works: Silicone Carbide Ignition
XL44 gas stove manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 25, 2011 | GE Ovens
GE Spectra XL44 Oven Overheating
It is a thermistore problem, if you replace the faulty thermic switch inside oven, it should work fine a gain
May 25, 2008 | Ovens
Gas oven is not working but broiler is working
The problem usually is the ignitor. Even if it glows it may not be pulling enough current to open the gas valve. They also are very fragile and break easily.
This tip will help you also.
Oven not Working or Oven not Heating http://ping.fm/mEg1i
Heatman101
Jan 27, 2010 | GE Ovens
Oven won't light.
Make sure your oven timer is not set for automatic cooking
Dec 06, 2009 | GE Ovens
Where is the pilotlight on a ge xl44 gas stove I belive it is in the door under the oven well I turned the gas on and stuck a flame down there and nothen took off is there a certian place to put the flame....
In general lets be clear. The OVEN pilot is located under the oven door at the top of the Broiler.It is a small piece of metal just before the GAS safety Valve which acts on temperature so gas won't flow unless Pilot is lit,That's the OVEN PILOT.The stove's RANGE is the top burners where you heat Pots and Pans.It has either 2 Pilot lights that connect the burners to the Flame they are under the Range Top.Newer Models use electronic ignitions no flame.Please note if you had your stove/oven disconected or Gas off when you turn it back on there will be air in the line that needs to escape before you light.This is why in NYC when Utility Co.works on steet main the MUST re-light your appliances.Be Careful with Gas.Good Luck.
Sep 19, 2009 | Ovens
Oven wont light
Check the amp draw on the ignitor. If 2.9 amps or less, replace the ignitor. If 2.9 amps or more, replace the gas safety valve.
Aug 02, 2009 | GE Ovens
Replaced gas safety valve, burner flame now too hot
Take a 1/2 inch open end wrench and tighten the orifice on top of the safety valve.Probably about 2 turns. Then adjust the air shutter to mostly open.
Mar 26, 2009 | GE Ovens
GE XL44 gas oven
hi thanks for the question just because the igniter lights up doesn't mean its good, the gas will not light, if igniter isn,t hot enough. and a very common problem is that the igniter does come on, but not hot enough to ignite the gas . replace the igniter thanks the appliance doc
Jun 25, 2008 | GE JGRP17 Gas Single Oven
Xl44 gas
two things either hte clock(control ) assy not sending powerdown to the igiotr, or hte valve that the ignitor is connected to onst nay good, unplugh the unit andwitha meter try testing the 2 wire connections on the top of the safety valve( i wire goes to the ignitor nad the other is a neutral wire htt hooks downt to under the valve for the broiler, you should show continuity across those to leads, if not your valve is no good and will need replacing
Mar 20, 2008 | GE JGRP17 Gas Single Oven
Electric starter gas oven model jgrp17 won't heat
more than likely your glow bar ignitor has stopped working or at least pulling enough amps to open the safety valve. The floor of the ovens come out may have a couple screws toward the back. take the floor out if a diffuser is on top of the burner remove it. the glow bar ignitor is mounted on the burner turn the oven on and watch it should glow bright red and in about 30 secs open the gas safety valve. If it does not glow you may want to verify power to the ignitor, more than likely the ignitor is the problem. If it glows but does not open the safety valev still replace the ignitor not pulling the required amps to open the safety valve. just put a little dish soap on the screws to the ignitor to help from srtripping them out
Nov 13, 2007 | GE JGRP17 Gas Single Oven
GE JGRP17 Gas Single Oven Logo
535 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
