Question about Brother MFC 420CN All-In-One InkJet Printer
Unable to turn on
My printer is always on but the other day it shut off somehow and now it will not turn on at all. any suggestions?
  • 832 Answers
Common error on older brother printers:
defective capacitor! The whole main printer board needs replacing. Its cheaper to buy a new mfc!
Posted on May 14, 2008
  • Brother Master
  • 5,568 Answers
If the printer shows no LEDs at all, it is likely that the power supply has failed.
About the only thing you can do is to disconnect it from your system and AC too.
Let it sit for at least hours, days would be better if you can sacrifice it that long.
If it comes back after a long rest and then drops out again without cause, then (if it is a 'nonlinear' or switching supply, most are now) a relatively cheap part in the supply (a capacitor) has failed.
Unfortunately, while the part is cheap, the labor will probably make the repair more costly than a replacement would be.
Locating the capacitor requires some knowledge of the innards of the unit and a meter capable of measuring the two critical parameters of the capacitor.
I have an Olympus IS21 35MM camera. ...Battery Drains with a day or two of putting a new one in.
I don't think your camera is running anything when it is shut off, unless you have a phantom power mic that is taking power somehow. If you leave any battery in extreme heat or cold ( like in your car all day) it could drain the battery, but I would suggest leaving the battery unattached to your camera until you need to use it. If your using an older battery that may be the issue as well, batteries build up little issues like that sometimes and you could always just buy a new one and see if that fixes it.
Feb 28, 2012 | Photography
I am unable to close the front cover on my ip4650 printer. How can I fix the problem, please.
Canon printers are always going wrong. It makes you doubt their cameras as well. Buy something else, though I can't suggest what!
Mar 13, 2011 | Canon Office Equipment & Supplies
Problem for Samsung SCX-4300 Monochrome Laser Multifunction Printer Alway showing as Toner Exhausted unable to
Good day Sir,
In Samsung scx-4300 display Toner exhausted the machine will stop to prevent serious pollution or breakdown of the machine.
Replace the toner cartridge with a new one and make sure it is genuine to prevent toner errors.
have a nice day!
May 03, 2010 | Samsung SCX-4300 Monochrome Laser...
Replaced printer head and now have carriage error HP 7130 printer
Well If You Have Tried to reset the Divice but unable to clear message i would beleve it is a fault. My Suggestion is to Exchange it or Buy a new one.. A good printer is HP DESKJET F2180.
Under £50 and NEVER EVER has a fault
Feb 13, 2010 | HP Officejet 7130 All-In-One InkJet...
HP Phototsmart C8180 Ink system failure
The printer should have its own ON/OFF switch (or button).
Always use that control to turn-off the printer.
The printer reacts to the 'OFF' signal by properly shutting itself down, and then cutting the power to itself.
Sep 14, 2009 | HP Photosmart C8180 InkJet Printer
Hp all in one C6180 can not print ink system has failed unable to copy receive faxes or print
the registry got messed up somehow try uninstalling all hp software related to this item and reinstall using the disc, be patient it will take time, good luck and have a nice day.
Mar 26, 2009 | HP Photosmart 3210 Printer
My Printer won't print and theres no error message.
I had the same problem (I've had the printer for 3 days). I checked my print queue and found that a file from the previous day was too large (1.1MB) I couldn't delete the file so went to HP website. I downloaded a utility file and voila....fixed the issue.
Mar 18, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Workcentre c2424 Scan - Won't find me so I can scan to personal images
It seems somehow your address was deleted. Recreate the box on the machine and it should be ok.
Mar 29, 2008 | Xerox WorkCentre C2424DN All-In-One Laser...
AL 1916 Monitor Green Light Flashes
I think you have loose cabling somewhere. Try to unplug (and untangle) the video cables and then plug them all back together firmly. If this does not work and you know your machine is booting up properly, you might have damaged the monitor somehow accidentally.
Nov 16, 2007 | Gateway FPD2275W LCD Monitor
Brother MFC 420CN All-In-One InkJet Printer Logo
41 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
