Question about Kenmore 74602 Gas Dryer
The gas comes on and heats up for about 30sec than shuts off
    Problem Solver:
  • 6 Answers
Check for obstructions and heavy lint build up, then clean it out with a vacuum. If this does not cure the problem you will need to take the front off the unit and check the components that regulate the gas. They are the flame detector, high limit switch, and coils. Each should be checked for continuity with an ohm meter. It is not hard to do any of these repairs if you are handy. parts are readily available.
Posted on Sep 13, 2010
I have a White Rodgers 50E47-843 Ignition control, my gas furnace gets the call for heat and the exhaust fan starts and runs for 1 min before the LED lights yellow for 2 seconds and then starts the hot...
A certain sequence of events has to occur to start normal operation. My furnace would start the stack blower which would then run forever without the furnace starting up. The service tech replaced the stack blower controller and the ignitor to get things running right again. Remember that some stages of startup are temperature dependent. For example, the burner has to heat the bonnet enough to close a thermal switch and turn on the main.blower.
Oct 26, 2013 | Heating & Cooling
The engine has recently started to idle very fast when the car is in park, and tapping the gas pedal doesn't help.
Examine all the vacuum hoses as one most likely has cracked, usually at a bend or
has come completely off. This will cause very high idle.Hope this helps.
Apr 01, 2011 | 1988 Plymouth Sundance
Genreator k runs for 5 min than shuts off seem to be starving for gas yet gas is good and is comming down from the tank, start it back up and it runs for 30sec and shuts off and so on and so on
look for a restriction in the fuel line (input to carb as well), also check oil level.
If those are good, then remove the carburetor bowl (dont damage gasket), and dump out anything that is in there. Your float may be sticking, or the needle seat has trash in it.
May 17, 2010 | Coleman Powermate Premium Plus 6250W...
2 YEARS OLD - WILL NOT STAY ON. COMES ON 30SEC TO MIN THEN OFF.
I cant fix your install problem ... If this is still under warranty, demand from the manufacturer that it be resolved.
Here are my thoughts ...
If your boiler comes on and goes off before temp is reached there may be a problem with the gas supply (not enough to keep it going properly) or there may be a problem with combustion air supply or water pressure.
To heat, you must have sufficient gas, sufficient air and the pump must be running. If the water pressure goes down, the boiler goes off. Check the gas supply line vs the BTU rating of the boiler.
I hope this helps you a little
Thanks for your interest in FixYa.com
May 16, 2010 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
No heat..revolves, blows ok...is there a fuse that shuts off gas?
Theres a fuse that shuts off the igniter. It can be the igniter or thermal fuse. If you see the igniter glowing but no gas coming out replace the coils on the gas valve. If that fails replace gas valve
Feb 13, 2010 | Kenmore Dryers
Heat shuts off after few minuets of running
Normal 0 Hi, You need to change the coils on the top of the gas valve. This is a very common problem with the newer gas dryers. We have them for $29.95 on out web site www.whilpoolpartssurplus.com
If I can assist you further on how to replace them, please let me know.
Thanks
Vic
May 24, 2009 | Dryers
Kenmore 74602 Gas Dryer Logo
32 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
