Question about Kohler Plumbing
I have a single handle kohler bath tub faucet I am not getting any cold water out. i have taken this apart and found nothing that i can see that would impede the flow of water ?is the mixer valve at the root of this problem Thank you
    Filmmaker:
    Uploaded 5 video answers.
  • 119 Answers
If the faucet was working before and then just stopped, it is the mixing valve or a clogged supply line.
turn the water off and remove the mixing valve. Turn the water on and see if you have good flow from both hot and cold ports inside the faucet.
Caution- this procedure can get messy, close the shower curtain or door.
Call Kohler and ask for a new mixing valve for free.
Posted on Sep 13, 2010
Why does moentrol bath valve give hot water pointed to "C" and vice versa?
Easy one.
Feel the pipes. The pipe on the right should be cold. If the pipes are correct, turn the cartridge 180 degrees.
Jan 20, 2013 | Moen & One Handle Tub & Shower Faucet
Moen Kingsley Moentrol single handle bath/shower fixture. Had guests use this recently and they only could get hot water. When you turned the handle to cold nothing comes out. Only hot when turned the...
Sounds like the cause of your problem is the pressure balancing spool. Call Moen at
1-800-289-6636
and explain the problem. They will send a repair part to you free of charge. the link below is a "blow up" of your valve.
http://www.moen.com/shared/pdf/t3113pt.pdf
Mar 10, 2011 | Moen & One Handle Tub & Shower Faucet
Disassembled handle and initial pieces under handle to find leak source. Single handle shower assembly. reassembled. Cold water only, no hot water. What did I not assemble correctly?
Take handle back off and see if it has a dial that can be removed and repostioned. take off and move it about 1/4 turn counter clockwise and reinstalled and try to see if mixture is correct.
May 18, 2010 | Kohler K-T10335-4-CP Lyntier Rite-temp...
When turning on the shower faucet there is no hot water.
Can you remove handle , behind handle there should be a dial to move to increase hot or cold supply.
Remember where you start and remove it and replace a 1/8 to 1/4 turn counter clockwise, just put handle on try it and see if it changes and adjust accordingly.
May 14, 2010 | Kohler K-T12007-4s-BV Brushed Bronze...
I have been told there is a way to adjust bath tap temperature under the bath is this true? Thanks
is this a standard bath tub?? if so the answer is no only pressure from hot/cold usually thru the access panel other wise you will have to crank up the water heater unless you have an on-demand water heater located near your access panel. which raises a second question. your faucet? is it a single handle for both hot/cold or two individual handles? if its a single handle try opening up your hot water valve in the access panel to allow for more hot water flow and slightly decresing your cold water valve hope this helps good luck!!!!
Mar 28, 2010 | Home
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Moen - Single lever bath tub faucet - cold water only
moen does not have a ball and washers....sounds like a Delta maybe. Moen uses cartridges. Either way sounds like a balancing spool problem....but you will need to make sure of the right name for the faucet to get the parts.
Aug 17, 2009 | Plumbing
No hot water
http://www.moen.com/contact.cfm?location=TopNavCustomerSupport
You will find a quicker answer and free parts for your bath room faucet at link above . I am sure it is the mixer valve assembly. If you are not a plumber I suggest a pro be called.
John
Mar 15, 2009 | Moen Plumbing
Kohler KT12007 Showerhead
The device which directs the water up or down is called the diverter. Your diverter is not fully up or fully down. Rather forcefully push and pull the diverter a few times and your problem may be solved. good luck.
Jan 24, 2009 | Kohler K-T12007-4s-BV Brushed Bronze...
No cold water from bathtub fixture/Shower won't engage
If you put on the cold and Nothing at all comes out, check the water supply valve to the tub. If it comes out alittle ...the washer probiblly came off and is stuck you will have to remove the valve ,but 1st check that the handle is not stripped ,and that is actually moving the valve to the open position Turn the handle and see if the handle backs out ,like its trying to open.
Please rember to leave me some positive feedback if Ive been Helpful! Thanks !
Dec 15, 2008 | Price Pfister Ashfield Single Control...
Plumbing Logo
698 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
