Question about SanDisk 1GB microSD Memory Card
Where could i take my memory card to get repaired
  • 2,460 Answers
I don't have a clue where you live, but a 1GB memory card from anybody is designed to be thrown away, unless you think you can find anybody to "repair" or even look at it for less than $15.
Just **** it up and get another.
Carl
Posted on Sep 12, 2010
  • Carl Navarro
    Carl Navarro Sep 20, 2010
    Is this only "somewhat helpful" because theere's no magic fix? Hey, send it here with $25 and I'll take care of it.
How can i repair corrupted memory card?
Test yuor memory card in other cellphone,,
or plug it in on computer to see if the memory card is
still good or it was totaly corrupted.
if you mmc is real corupted,,you can use this to recover your files
download this and install it on your computer
memory card recovery tool
Nov 03, 2012 | Cell Phones
Tip
How to repair memory card
  1. Download and install a data recovery program. The first thing you want to do when you encounter a memory card error is to attempt to recover important files. There are a number of programs available to accomplish this. Photo Rec is a powerful, free option for most operating systems, but lacks a graphical user interface, which can be intimidating for less advanced users. Find the data recovery program you are most comfortable with in terms of price and features.
    Insert the memory card into your computer's memory card reader. Use a USB card reader or connect your device to your computer via USB if your computer does not have a card reader.
    • Some devices require that you enable disk use via USB through its settings before your computer will recognize it.
  3. 3
    Run your data recovery program. Follow the procedure to recover files for your data recovery program and recover what you can from your damaged memory card.
  • 2
    Go to Computer. Open the Start menu and click Computer. Type Computer into the search box if you cannot find it.
    • In Windows 8, Computer is called This PC, and can be found by searching forComputer from the Start screen.
  • 3
    Find your memory card. Your memory card will be listed under Devices with Removable Storage (Devices and drives in Windows 8). It should be named something like "Removable Disk (M:)". Make note of the drive letter, as it will be needed later.
    • If you cannot tell which disk is your memory card, remove your card with this window open and note the drive that disappears. Remember to reinsert you card before continuing.
  • 4
    Open Command Prompt. From your desktop, press ? Win+R to open the Run dialog. Enter cmd and click OK.
  • 5
    Run Check Disk fix and recover. On Command Prompt, type chkdsk m: /r, where m: is the drive letter of your memory card, then press ? Enter to begin.
    • Depending on the errors found during this process, Check Disk may ask for your input in regards to what action it can take. When this occurs, answer "Yes" and press enter to continue.
    Part 3 of 3: Repairing a Memory Card on Mac
    1. 1
    2. 2
      Run Disk Utility on your Mac. Disk Utility is a Mac operating system utility that can perform disk-related tasks. Select Go from your Finder menu and select Utilities or press ? Shift+? Command+U from the Finder to open your Utilities folder. Open Disk Utility from your Utilities folder.
    3. 3
      Select your memory card. Find your memory card on the list of connected drives. If you do not know which drive is your memory card, remove it and reinsert it to determine which drive it is.
    4. 4
      Repair your memory card. In the First Aid tab, check the "Show details" box, then click Repair Disk. If Disk Utility reports any errors, repeat the repair process until it finishes and reports "The volume appears to be OK".
    on Aug 24, 2015 | Philips SAC2530 - CD/DVD repair kit...
    Memory card will not initialize
    there r two reasons this..may b memory card is not working to test the memory card,use the memory card in other source.if t works in other source then the memoery ard if fine .so there vl b a problem within ur camera..may b the gold coated pin which the memory card must not b working..to them repaired u need to change them..u can change at some local repair shops or in aurthorised service center of fuji film.
    Jun 04, 2012 | Fujifilm FinePix JV300 Digital Camera -...
    Where can i find a repair center in el paso tx for a memory card
    Memory cards are a throw away items, the memory chip cannot be repaired.
    Dec 05, 2011 | Electronics - Others
    I gave my nokia7210 for display replacement and its memory card was removed. But after getting it repaired when I inserted the mem card and tried to access data. I get memory card not formatted error...
    The tech who repaired your phone may spoil the memory card.Because,Before we unscrew the gadget we should remove all the hardware attetched. Besides,this problem occur only when The chip inside the memory Card was damage.So we could not repair this during this time.
    Mar 29, 2011 | Nokia 7210
    I acidentally dropped my camera memory card and stepped on it. Now the metal piece (the reader) is missing and the card won't read.
    Compare the damaged memory-card with a non-damaged memory-card.
    If you've broken-off the gold-coloured contacts from the edge of the memory-card, then your memory-card is broken beyond repair.
    Tough luck.
    Jan 04, 2010 | SanDisk 2GB microSD Memory Card
    Same memory card been using but now indicates no memory card when i turn on
    Take a look inside your camera's CF card slot. I suspect that you may have a bent pin in there. If so, don't fret. Although professional repair would be more costly than the value of the camera, there is a very good chance that you can repair this yourself. Please see the following:
    http://camerarepair.blogspot.com/2009/06/fixing-compact-flash-memory-card-error.html
    May 16, 2009 | Canon PowerShot A70 Digital Camera
    Sd card error on canon powershot s3
    I get a memory card error everytime I insert a memory card. They are not locked and I have tried 4 different memory cards and nothing works. How can this problem be fixed?
    Jul 28, 2008 | Canon PowerShot S3 IS Digital Camera
    Memory card repair
    how to enable my memory reader because i choose to disable it, thats why it is malfunctioning
    Jul 08, 2008 | Nokia N-Gage Console
    SanDisk 1GB microSD Memory Card Logo
    46 people viewed this question
    Top SanDisk Electronics - Others Experts
    k24674
    Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
