Question about Sennheiser HMEC 25-KA Headphones
Hi, I have to repair the connections of a Sennhaiser HMEC25-KA headphone as all wires have been teared out of the power boxe. Where could I find the wiring distribution to solder the wires back on the board? Best regards Pïerre
4 Suggested Answers
SOURCE: Want to replace PX100 wires
Just be careful, maybe try to find a guide to dissasembling the PX-100's - I had a pair go bad that I tried to open up and I mangled them somewhat - of course I wasn't being super careful, nor were they in great condition at that point. There's a lot of you tube vides about replacing the ear buds with other ear buds - it should be straight forward, minus the extra care for taking the PX-100's apart. Any concerns about impedance matching for the wires? Could this represent a degradation of the PX-100's sound if the wires are diff. impedance?
Posted on Jun 25, 2009
Grubhead
  • 5449 Answers
SOURCE: I am trying to replace
See my tip on headphones jack/cable problems. Also sometimes they put on a special coating on the wires. You have to scrape the wire or file it to remove it. Spit is also good at making the solder stick!
Posted on Aug 23, 2010
SOURCE: Colors of the wires for CX 400 headphones
i think yellow-green are moveable ground of the volume pots, just because they are seperated and twisted to reduce noise. seperating, twisting ground channels, especially connecting them in only one point near source's ground is the basic rule of simple electronics to achieve noise reduction. yellow cable is a high impedance side of volume pot and its hard to get noise when you move pot the yellow side because you're making speakers to generate lower volume. so its not needed to twist yellow wire with others. its the possible scheme below,
http://i55.tinypic.com/s612ko.jpg
Posted on Mar 18, 2011
Headphone some times one of them doesn't work
The wires commonly tear inside the rubber insulation.
Only a handy, experienced cildl-solder technician could spot and repair this, so good luck. Your best and practical solution may be to buy a new set.
Sep 20, 2016 | Beyerdynamic MMX 41 iE Premium In-Ear...
Wont play music
sounds like you have removed them by pulling on the wires, not by the earbuds or plug. not a recommeded practice when unplugging anything as it usually ends in broken wires internally along with tears. You may be able the get somebody to do some faultfinding/repairs if they are of the super expensive variety otherwise replacement may be the only solution. Most in-ear headphones have super delicate wiring and are as such a real pig to resolder
Dec 08, 2012 | Kicker Flow EB72B Personal In Ear Noise...
Kenwood ka 127 volume
• Check to see if the sound on the stereo receiver has been muted.
• If the stereo receiver has a headphone jack, make sure
no headphones are connected.
• Try a different audio setting on the stereo receiver.
• Check the speaker wires to make sure they are
connected securely to the stereo receiver.
• Try connecting different speakers to the stereo receiver
If these have already been done,
Symptoms still persist, service may be required.
hope these helps,
thanks for choosing Fixya for assistance.
Aug 04, 2012 | Audio Players & Recorders
I have mk 650 b ear phone and its right speaker stopped working. I expect speaker wires broken inside but i am unable to open the metal cover of it. If any body knows how to open it please help...
Hi!
At first, be careful, cause you can tear the wire inside the cover.
So, you need a pliers and a small piece of paper(it will protect the metal aganist scratching).
You need to press the end of the cover(only the pink part, see the picture at the top of this page)by the pliers with paper inside it.
Then you have to twist the side with the wire. There is no thread, so the direction is irrelevant.
Be carful, cause the wire can't follow the twist, so too many twist will tear it.
That's all.
Sztyepadzso
Feb 14, 2011 | A4tech MK650 Headphones
Hi! I have a brand new Coby headphones (haven't been a month). I've been keeping good care, but today I found that left ear works perfectly while right one is loose. As I turn the jack at the end around...
try cleaning the connecter
10 Headphone Repair Hacks - Sustainablog
https://sustainablog.org/2015/10/10-headphone-repair-hacks/Oct 19, 2015 - For instance, here's a file for a new jack cover. Reconnect a wire to the lead. If audio is only playing through one side of your headphones, then a loose or disconnected wire is the culprit. Repair the ear cushion. If the cushion wears out or comes off of your headphones, don't worry-that's fixable! Replace the ...
Jan 21, 2018 | Coby CV-190 Consumer Headphones
Have a 1990 era Kenwooed KA -127 that has always worked perfectly, however I just changed out CD players (Sony 5 disc changer that died w/ new CD P-CX355 300 disc changer, also removed taped deck ,...
I would first look for poor solder connections. It is possible that with the moving of the unit, a marginal connection finally broke. This is not unusual for a unit that is 20 years old. Check with a local repair shop for the labor costs, but this unit is definately worth a $100-$150 investment. If you;d like, post your location here and we'll try to provide you with some referrals.
Dan
Sep 06, 2010 | Audio Players & Recorders
Touch screen shows wear and tear
LCD will be replaced as there is no cure for wear and tear on its surface. Required LCD part number is appended below:
A1334748A... FTS BLOCK ASSY (35STMG07)
Available in Sony Parts Store for $154
If you are handy with electronics stuff repair then can replace it easily, remove side and bottom screws and take apart front and rear cabinet of camera. Unlock connector that holds lcd flexible connection wire, remove solder connection of back light source plate from lcd flexible wire, solder back light connections in new lcd flexible wire and insert it in jack on main board of camera.
Local camera repair shop will help you to replace lcd if you feel uncomfortable doing so.
Thanks.
May 19, 2010 | Sony Cyber-shot® DSC-T200 Digital Camera
I connect my Beyerdynamic DT131 wired headphone to my Sony Bravia TV through the cable box, audio volume is extremely low and the headphone's volume control had no effect on the volume. I tried connecting...
The audiolevel is much to low for a headphone.
You really need to use a headphoneoutput ( if its there) or a headphoneamplifier.
You tried to connect your headphone on line-level outputs.
Regards,
Gerard
Apr 23, 2010 | Beyerdynamic DT 100 Professional...
I have had the bose in-ear headphones for a year and they were great at first and then all of a sudden the left earpiece stops working. If I move the part that connects the headphones to the ipod then it...
If your headphones are in warranty (under a year old) Bose will repair or more likely replace them with a new pair. I am now on my forth pair or Bose in-ear headphones and experienced the same problem with an ear piece stop working. I have to say Bose customer service has been fantastic and has replaced each pair. Every new pair is then covered by a new full years warranty. Unfortunately my fourth pair has just gone wrong with the same connector problem. Bose again have said they will replace as they are in warranty. I have been told if they are out of warranty they will offer a new pair at a discount price of £50 instead of £80. However i think that if my new pair go wrong out of warranty i will have no option but to look at alternatives.A Pair of headphones that cost £80 should last more than a year!!!
Mar 29, 2010 | Bose in-ear headphones - Black with...
Only one side of the headphones work
this is usually a problem with the wire "grommet" around the plug. this spot experiences the most wear and tear and more often than not one of the wires shorts with ground thus producing no sound. If you don't think this is the problem, try opening up the ear pieces and checking for solid connections to the speakers
Jul 27, 2009 | HP Able Planet Inc. 602100HP Headphones...
Sennheiser HMEC 25-KA Headphones Logo
59 people viewed this question
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
