Question about Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw
How to put the chain back on a 14" Poulan electric chain saw
    President:
  • 1,627 Answers
Remove the cover that cover the rear of the chain bar.Now,loosen the nuts that attach the bar and slide the bar reward.Now set the chain in the slotted part of the bar,pull it forward until there is abut 3/8 of an inch slack in the chain an tighten the nuts.Re-install the cover.
Posted on Sep 12, 2010
4 Suggested Answers
dontbother10
  • 2220 Answers
SOURCE: need a chain for 14in
Hello Jennifer;
The number of drive links, pitch and gauge of the chain need to be determined to answer your question. If you take your saw or just the chain to a local chain saw outlet a new chain can be fabricated in a very few minutes. This will save shipping and handling fees as well. While there get the numbers mentioned above. Once you have these you can likely find a low kickback chain in a local home center the next time the chain needs replacement.
The FAQs here can likely answer all your questions.
http://www.oregonchain.com/pro/service/faq.htm
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Aug 10, 2010
dontbother10
  • 2220 Answers
SOURCE: what is distance from coil to stator 14 in. poulan chain saw
I think you are asking for gap between the fly wheel and the ignition module. A business or index card works great. 0.1 - 0.3 mm. GL
Lou
Posted on Oct 09, 2009
  • 2239 Answers
SOURCE: I borrowed a friend's POULAN 14" ELECTRIC
Remove the side cover nuts and the cover, wind the bar adjuster screw fully back, it may be in the cover, or on the front of the saw, push the guide bar fully back toward the sprocket, loop the chain ocer the sprocket and lay it around the the guide bar, make sure the cutters on the top of the bar rail are facing away from the saw, this will make sure it is the correct way round make sure the bar adjuster pawl is engaged into the hole in the bar, if the adjuster pawl is in the cover, replace the cover making sure the pawl engages into the hole in the bar, refit the cover nur finger tight, adjust the adjuster screw so as the chain fits snug fully around the bar, loft the nose of the bar and fully tighten the cover nut, with a gloved hand pull the chain manualy around the bar to make sure it is fitting in the rails and the sprocket correctly.
Posted on Sep 01, 2011
New poulan 14
Hi, it is meant to work this way, dont push it full forward to use the saw. Regards Phil.
Jul 09, 2012 | Poulan 14" Electric Chainsaw
Aug 31, 2011 | Poulan 14" Chainsaw
Poulan 14" electric, model# PLN1514
Hi there, a couple of features come to mind that may be the cause of your problem.
Firstly, make sure that the saw is unplugged from the power supply.
  • The chain brake is active and wont allow sprocket movement and hence the chain. If necessary, pull the front guard (in front of the front handle) back until it clicks.
  • Electric saws generally have an additional motor-stop feature built into the trigger mechanism which is deactivated when the trigger is squeezed. So, in order to move the chain along the bar the trigger needs to be squeezed releasing the motor-stop. A tip - wear gloves when handling chains and move the chain towards the bar tip ie in the direction of the cutters - if the chain suddenly stops you wont remove several layers of skin in the process ! better still use a screwdriver against the back of one of the cutters and move it forwards - there should be some resistance and there should be no slack chain on the underside of the bar. Hope this helps.
Nov 06, 2010 | Poulan 14" Chainsaw
Need a chain for 14in electric poulan chain saw the normal 14 in chain does not list the electric saw as one it will fit
Hello Jennifer;
Lou
Aug 10, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
I have a 14 inch WEN/Wagner electric chain saw in good condition with the exception of the trigger switch. I have not been able to find a replacement for that small part. Can you help?
Jim it is so long out of production about the only thing available is the OM. If you can get a pn off the original switch Allied or Newark is an option. Maybe a trigger switch from a saw in current production can be modified to fit.
Different model Poulan electric saws follow:
1. http://www.ordertree.com/modelinfo/PWE/1220-Electric-Saw/75.1220-Electric-Saw.1.59.1.html
2. http://www.ordertree.com/modelinfo/PWE/1420-Electric-Saw-Type-2/75.1420-Electric-Saw-Type-2.1.59.1.html
3. http://www.ordertree.com/modelinfo/PWE/1625-Electric-Saw-Type-2/75.1625-Electric-Saw-Type-2.1.59.1.html
“EL-14“ through “ES400” here (5±):
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
A length of spring steel and almost any micro switch might also be an option. Beyond that I am out of ideas.
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Apr 22, 2010 | Remington Electric Chain Saw
I replaced the chain on the poulan el 14 and when I would tighten the aft bolt this caused the chain to begin to stick when I would manually move the chain
Poulan "1420 Electric Saw Type 2" (may not be your saw)http://www.ordertree.com/modelinfo/PWE/1420-Electric-Saw-Type-2/75.1420-Electric-Saw-Type-2.1.59.1.html
Open the link; Click "View the illustrated parts list [GO]" link; open the "Illustrated Parts Lists" folder; Click "Chain Saw Assembly Type 2". Compare items 20 and 21 with your saw, the flared portion of 20 should be toward the clutch cover not the engine and on the clutch side of the bar. The only other thing that comes to mind is item 23 should fit into the hole on the bar (the bar should be tight against the oiler channel; engine side of the case.). HTH
Lou
If these are correct please add comments below and we will continue.
Dec 29, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Electric switch works intermitantly, having problem ordering switch -DEFOND DGH 0415B listed on switch. help '
You dont give us the model number of the saw. A quick check found more than 8 electric saws here:
Poulan.com
An inspection should find somethig that matches.
I opened one of them, item 15, pnPWE530071533, $7.34 each. GL
Lou
Oct 02, 2009 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Poulan model p3314 recoil spring won't go in correctly
You need to pretension it. Remove the pull handle, rotate the spool about 2 revolutions against the spring, rethread the cord and reinstall the handle.
Lou
Sep 04, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Poulan 14 in. 2.0 Peak Horsepower Electric Chain Saw Logo
735 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
