Question about Ducane 30400040 Stainless Steel Grill
I have a 3 burner ducane model #30400040/30400041. The 3 main burner knobs can be pushed in but will not turn at all. The rotisserie and side burner knobs work fine .
4 Suggested Answers
SOURCE: burner replacement on Ducane 30400040
Remove the 2 grill wire cooking racks by lifting them out of the top of the grill, next lift out to remove the 3 heat deflector panels which exposes the 3 burner tubes. Remove the 4 screws located on the outside flanks (2 on each side) of the 5-knob control panel assembly - then gently slide the knob control assembly outward and away from the grill just about an inch or two. You can now remove the old burner tubes and replace them with the new units. Then simply slide the control assembly back into the grill frame and replace/tighten the 4 screws. Voila`
Posted on Oct 26, 2008
  • 494 Answers
SOURCE: Does conversion from LP gs to Natural gas on
Did the conversion kit give you an LP orifice for every new gas valve? LP gas orifices have smaller holes than Nat gas orifices. Can you smell gas when you turn on the IR burner by itself? Some burners styles have an air adjustment on the end that fits over the orifice. Make sure it's getting enough air. Also make sure your ignitor sparker is positioned where the spark can ark against the top of the burner. Ducane grills have rotary ignitors, so turn it (with gas off) and see if you can actually see where it's sparking. If it's not sparking in the right place, it will be difficult to light.
Posted on May 15, 2010
Testimonial: "As I expected - conversion kit did not include a new orofice for the IR burner. Conversation with Ducane indicated no conversion is available - interesting in that I purchased the kit from Ducane two years ago. Thanks for your help"
blueextc3221
  • 15935 Answers
SOURCE: Installation instructions for Main burner on Ducane
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Where is the ignite button located
Hi phillzy21
If the main grilling burners don't ignite, try lighting them several times using the snap ignition. If that doesn't work, try using a match. In humid and windy conditions, sometimes the snap ignitions do not work properly. Make sure that the hood is fully open. Also, ensure that your gas is turned on and that the valve is fully open. Next, take out both the heat distribution plates and cooking grate. Turn the grill backwards, and hit the snap igniter a few times and look for a spark. If you see a spark, the igniter is working properly.
Bud
Oct 02, 2012 | Ducane Meridian 32 Inch 5 Burner Gas Grill...
Have a home depot ducane 5 burner. just replaced burner tubes. have never used the rotisserie burner on it before. it lights but won't stay lite after releasing knob...any suggestions? Thanks
Infrared burners requite that the gas control knob be held in for 2 minutes or so, to allow the thermocouple on the infrared burner to heat up completely. If it's windy were you are, the wind can blow the burner out, while trying to light it. That's why it has a thermocouple on it, to stop the gas if the burner goes out. All cooking on the rotisserie is doon with the lid/hood closed, at temperatures around 250 degrees F. Once the infrared burner turns bright red, release the control knob.
Hope this helped you to get it lit. Thanks for choosing FixYa.
Aug 24, 2011 | Ducane 30400040 Stainless Steel Grill
When using rotissery should main burner also be on?
NO, the grill will overheat with the lid closed. Besides, you will probably have to remove the cooking grates under the rotisserie , because a disposable drip pan should be placed under whatever your cooking.
Hope this helps and thanks for choosing FixYa.
Jul 29, 2011 | Ducane 30400040 Stainless Steel Grill
I have a stainless steel Ducane BBQ with five burners plus side burner and a rottisserie burner , which does not work. It is approx 5 years old and I have never used the rottisserie till last week. I have...
Since you've never used it. It may simply be a case that the infrared rotisserie burner is dirty and clogged with grease from cooking on the main burners. In addition, the Thermocouple and the igniter for that burner may also have a grease build up. In which case it won't allow the burner to light.
The electronic igniter that lights the main burners, also ignites the the rotisserie burner. Are you geting the click noise on the main burner igniters? If not, the battery in the igniter button needs to be replaced. Be sure to take note of the way the old battery is facing, when you unscrew the igniter cap. Because, that's the way the new battery should face.
Also, try match lighting the rotisserie burner. To do this, turn the Rotisserie Burner's Control Knob to the ON position and push it in, as you touch the lit match to the burner. If the burner lights continue to hold the burner knob in for a couple of minutes. This allows the Thermocouple and the ceramic plaques to heat up completely. Then slowly release the burner knob and the burner should remain lit.
If it doesn't stay lit, clean the burner and the Thermocouple ,in the manner that is described in your Owner's Manual.
Hope this helps you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 15, 2011 | Ducane 30400040 Stainless Steel Grill
I have a stainless steel grill. The Rotisserie will light, but the burners will not. I purchased the grill in 2005.I have taken the grill apart and the tubes are clear. There is NO spark going to them. I...
The ignitor wire to the burners my have come loose or has lost full contact. Trace the wiring from the Ignitor Button to the main burners. Note if it loose or has come completely off. Also, check inside the grill at each burner to see if the ingnitors are covered with grease. If that's the case, clean them with alcohol and either a rag or a cotton ball. If all this fails to solve your problem, change the battery in the Ignitor Button with a brand new Alkaline type battery.
Hope this helps solve your problem. Happy Grilling!
Feb 12, 2011 | Ducane 30400040 Stainless Steel Grill
I was given a ducane 20002301 2 burner with rotisserie and when I ignite and have on high there is not much flame. I know very little about gas grills
Could be two things, the first is a bad regulator, easy to replace and not very expensive. The other is a blockage in the burner orifices. For this you have to take the burners out and check inside the burner venturis and then see if you can unscrew the orifices on the valves and clean out any blockage.
Nov 16, 2009 | Ducane 455 inch 2 - 3 Burner with...
I can't get the rotissorie burner to light. I have gas, all of the other burners light, the igniter sparks. Just can't get it to fire.
first turn your rotisserie knob on and then push it in, hold it down and push your starter while you hold it when it lights keep the knob down for about 15 to 20 seconds it should do the trick
Jul 12, 2009 | Ducane 30400042 (LP)
Need to replace burner tubes on a Ducane grill. How do you do this? How do you get the old one off? I don't have a manual anymore.
First call Weber to receive the Warrenty burners for free. Have model and serial numbers ready. They can be found on one of the doors. Here is what I did for my Ducane model 30400042.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Jun 07, 2009 | Ducane 30400042 (LP)
Ducane 3400042 lighting problems
Good answer... but remember (if you have the regular burners on... The Rotisserie will not light.) 1. Cut all knobs off... Then push and hold in Rotisserie button as you turn to high.
2. Press ignition button, until you hear rotisserie ignite. 3. Keep holding in the rotisserie button until the thermostat realizes the gas is on and burning. (IT must get hot enough to keep gas flowing.) Hope that helps, Dave
Apr 08, 2008 | Ducane 30400040 Stainless Steel Grill
Ducane 30400040 Stainless Steel Grill Logo
115 people viewed this question
Top Ducane Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Are you a Ducane Grilling Expert? Answer questions, earn points and help others
