Question about Proview PS 776 Monitor
My monitor is to dark and the brightness adjustment cannot fix it.what can i do?
At start up my viewsonic va1912wb display blinks several times then i can see the picture but it is dark almost unreadable. Today it went darker than yesterday. HELP!
If it is dark due to brightness adjustment, get that adjusted. Usually when you adjust the brightness by pressing the menu button, the menu screen would not be dark. If everything is dark dark dark and you can only see some display but in very pitch darkness, then your monitor is a goner, backlit for the monitor is dead, and your monitor will need to be replaced. You can fix the backlit tubing, however it is risky, and expensive, and would cost less if you bought a replacement.
Jan 30, 2011 | Computers & Internet
My monitor has gotten really dark. How to fix?
Try another monitor on your computer. If the other monitor works fine, then you know the video card is good and the monitor is definitely bad.
If the monitor is the culprit then the only option is to replace it because that would mean the screen itself is going bad and there is no replacement screen for that monitor.
Jul 05, 2010 | E-Machines eMachines Monitor E15T4
Dark, horizontal lines after text and dark images.
This implies that your monitor had gone bad. you need to take it to a computer repair shop.
Apr 10, 2010 | HP w1907 LCD Monitor
The auto-darken feature(monitor goes dark on dark
In your monitor panel you'll find 4 buttons. Press the menu button and get into Magic Bright. There you can choose the one that best suits you. You can even set to Dynamic contract where the monitor adjusts the brightness according to the elements on the screen
Jun 20, 2009 | Computers & Internet
Colors are very dark
you can download a utility like rivatuner to adjust the videocards gamma up to the brightness your looking for if the monitor will not adjust brighter with the controls on the front of your monitor. rivatuner can be downloaded free (just google or yahoo "rivatuner downlaod".
To be honest with you, I would replace this with a 17 inch LCD monitor, which you can found at tigerdirect.com for 89 bucks.
If you do have issues with this older monitor, it would be less expensive to replace it than fix it..
May 18, 2009 | LG Studioworks 57I 15" CRT Monitor
Adjusting brightess on monitor
take the cover off the monitor and adjust the screw on the fly back to adjust the brightness it will be in the shape of a little knob
Apr 16, 2009 | Mr. Coffee HCLF
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
My computer monitor has somehow turned its brightness all the way down, possibly due to me choosing a new screensaver which was already installed on my computer. Sadly, my monitor, an Emprex LM-1704...
Find yourself a dark room or wait for the night to come. The darkest monitor adjustment could somehow reveal some light when there are no other light source available.
You may also hook a conventional CRT monitor and make your changes (such as bringing your computer back to its original settings). The darkest adjustment in CRT monitor could still render discernible displays.
Sep 09, 2008 | Computers & Internet
Proview PS 776 Monitor Logo
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Frank Russell
Frank Russell
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
