posted by amazed24 on May 14, 2008
So, I changed the drum in this copier, since the following message appeared after every copy I made: Replace Drum soon (or "Change" drum soon). After changing it, sure enough the error message continued to display after every copy. I went through and did everything they told me to. I even powered it off, unplugged it, etc., and nothing worked. I went into the set-up, and followed it to "drum life" and it said 0% remaining! This i a brand new (and quite expensive) drum. How can I get this error message to stop??
Solution #1
posted on May 14, 2008
I was responsible for a brother machine simular to this. A button or two had to be pushed on the control panel while the machine was open to change the drum. Consult owners manual if you have it.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Brother DCP-8040 Copier
Email this problem
Email this problem
Can you Help with these Copiers problems?
Repair Service
Find Copier Repairman Near You:
