How to construct venn diagram using quadrilaterals?using the rhombus,square,rectangle,parallelogram,trapezoid?
3 Suggested Answers
  • 19 Answers
SOURCE: about solving problems in venn
Venn diagram is used to compare and contrast to things. To make a Venn diagram, think of two things you want to compare. Draw two circles side by side overlapping them. the overlapping can be as big or as small as you want. this area will be where you list the things that are the same. label the item on the top of each circle (e.g "Apple" on the upper Right cicle and "orange" on the upper LEft circle) then write the distinct things of the first item on the area that is not overlapping.. do it on the other side that is not overlapping for the second item.
hope this helps.
Posted on Jul 08, 2011
virtual_a
  • 531 Answers
SOURCE: compare intended curriculum,implemented curriculum and
Hi
I hope this helps you.
If my answer helps you, please take the time to rate it. This helps anaswerers to better understand the asker's point of view and helps us explore fresh way to provide and maintain high quality answers.
Posted on Aug 30, 2011
What would the area of the rhombus be
I don't think you can figure out the area of this rhombus/parallelogram.
The area of a parallelogram is base, which we have, times height.
Picture the parallelogram with all the angles being 90 degrees. The area would be 54 square centimetres. Now imagine you can slide the top part of the parallelogram to the right, with the bottom fixed and all the corners on hinges. In theory, you can nearly slide the top down until it is just above the base. The area would approach zero, as the height of the parallelogram decreases.
Good luck,
Paul
Apr 14, 2016 | Office Equipment & Supplies
What is a parallelogram could you give me a shape please or a example or maybe directions or what a shape it is...
Take a square or a rectangle and push the top to one side . That is a parallelogram. But so are the square and the rectangle.
Mar 27, 2015 | Microwave Ovens
What shape has 4 sides
Quadrilaterals, including squares, rhombuses, and trapezoids.
Mar 18, 2014 | Computers & Internet
A parallelogram with 4 equal sides
A rhombus (and in a special case, a square).
Dec 16, 2013 | Office Equipment & Supplies
Subwoofer box specs for single 12" 2500 xtc
Magnat does not post the specs on any speakers! The construction of a speaker box means that you need to know what the following:
1. Diameter of the speaker
2. The tuning or resonant frequency of the speaker
3. The depth of the speaker
4. How much space the speaker frame displaces.
5. The thickness of the wood.
6. The bracing
7. The port (if you port it) needs specs for its displacement
8. The ports volume transmission factor.
9. Whether you want it rectangle, square or trapezoid.
May 06, 2013 | Car Audio & Video
What is the math definition for area?
Area - The size of a surface
Specific
Square
Area = Side x Side
Rectangle
Area = Length x Width
Triangle
Area = Base x Height (cut the answer in half and that is your area)
Parallelogram
Circle
Area = Radius x Radius x 3.14
Aug 30, 2011 | Computers & Internet
About solving problems in venn diagram and how to make venn diagram
hope this helps.
Jul 07, 2011 | Computers & Internet
I have a lot tha is 152.95' X 119.88' X 130.00' X 50.00'. What part of an acre is this.
  1. This lot does not have the form or a regular quadrilateral (rectangle, square, parallelogram, etc.)
  2. So you cannot calculate its area, you have to know exactly the shape it has.
  3. With polygons, one usually cuts them into triangles.
  4. You have to cut it into two triangles,
  5. measure the base and the height of each triangle,
  6. use the area formula for the triangle ( area = heightX base/2)
  7. After you calculate the areas of both triangles, you add them to get the area of the the whole lot in ft^2.
  8. Using the conversion formula between acres and ft^2 which is 1 acre=43560 ft^2, you divide the area of the lot in square feet by the number 43560 ft^2 and express the result as a percentage or a fraction .
Hope it helps.
Thanks for using FixYa.
Nov 19, 2009 | Calculated Industries Pocket Real Estate...
Is a rectangle squared or cubed
Some wires got crossed here. A cube is a solid (a 3D object), whereas a rectangle and a square are 2D figures. You cannot compare a 2D figure with a 3D figure any more than you can compare say a parking lot and a highrise building.
A rectangle is a quadrilateral (closed polygon with 4 sides). In a rectangle, opposite sides are parallel and equal in length. In a rectangle all 4 angles are equal, each measuring 90 degrees.
All this is true for a square, except that all sides are now equal. So you can say that a square is a special kind of rectangle, namely, a rectangle with equal sides.
Hope it helps.
Oct 08, 2009 | The Learning Company Achieve! Math &...
How do you find the area of an irregular rectangle or parallelogram?
There is no such thing as an irregular rectangle. This being said, I believe that the area of a parallelogram is still equal to the product of the base by the height.
Draw your parallelogram with one side horizontal. From the next corner, draw a line perpendicular to the base. The length of the segment you just drew is h. If b is the length of the base the area is b*h.
Hope it helps.
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
