Hoptpoint Ultima Digit Washing machine is flashing the error message F-01 how do I fix this?
  • 15,935 Answers
The first thing to attempt for the F01 error is...
Reset it : hold the 'start' button until all lights displayed, then press 'start' again.
Hold the 'start' and 'on/off' button together until it reads d-end or d-off.
It doesnt always work 1st time so keep trying.
F 01 is actually a shorted motor triac. You'll need a new pcb. (Primary Control Board)
Your machine may not have been the cheapest but all Hotpoint electronics hold much the same quality...questionable at best.
A few more things to do before trashing it....
- unplug the washer power supply, close the water valves.
- unscrew two screws that hold the control panel.
- remove the panel - you need the lid to be semi-opened.
- Disconnect and re-connect all connectors to fix any possible oxidation or loosensess - then try the washer
- On the right panel - unscrew the right screw (when standing in front of the washer)
- unscrew all four screws hidden under the bottom cover in the front of the washer that hides also the filter (those still hold the side cover)
- unscrew two more screws at the top back of the washer - they hold the circuit board to the washer body - it needs to be loose
- by pulling the top side of the washer up by the lid and pushing the side cover away "to the back" (with a screwdriver), see how the side cover is held by the top, remove the side cover
- observed the motor and immediately saw heavy corrosion at the ground connection (yellow-green wire) at the motor board and possible slight oxidation at one other connetion of the black wire
- using sand paper and screwdriver clean the contact together with the connector and try the washer
- clean the black wire connection with the same way
- try the washer (spinning program) and hope it works!!
- Empty the drain pipe out - if there is an obstruction... it may cause the motor to overheat and throw you this code.
- try unplugging the black wire and running the spinning program - both the motor AND the pump shouldnt start.
The problem may be in an oxidation of the black wire connection - that is apparently a power supply for both the pump and the motor.
That will cause insufficient voltage and thus a power for the motor but probably still enough for the pump.
The randomness of the problem is probably caused by humidity in the room and maybe some more factors.
The washer is actually opened from the bottom so when you test the washer more times and find a solution, it may be best to cover the connetors with silicon to avoid corrosion or oxidation in the future.
Here are also some tips for putting all together:
When removing the side cover something fell from it inside.
It was a plastic lath that is placed on the nearer edge of the cover and fits both onto the edge of the cover and the adjacent edge of the washer.
It's a bit tricky to put it all back plus there is a plastic piece at the bottom of the side cover that is fixed there also very loosely and keeps falling inside when srewing the filter side screws - but this can be fixed with pliers adjusting the edge of the side cover to make the plastic to fit there tightly.
I'm optimistic one of these solutions will do the trick - try unplugging/re-plugging first.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Error message f01
F-01 Motor triac short circuit this means that there is something wrong with the main board. but there is a thing to try 1st try unplugging the machine for 5 mins and plugging it back in and switch it on and try again. if it still dose not work after some attempts then it looks like you need to get the engineer out to fix it, hope this helps.
Nov 01, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code on washing machine wf640
have you checked you have turned on the water back on???? check but red and blue, or just blue it must be 90degree left or right.
Mar 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
I have a wf860 Hoptpoint washing machine and it was quiet until I washed some cushions in it. Now it moves around when it's on a spin and it's very noisy. Can this be fixed?
You might need to check if it is level also that if all the feet are stable on the floor. if all this is fine it is probably the suspension witch is on the way out and needs replacing. hope this helps
Oct 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
My machine is flashing F-01 Hotpoint ultima WT960
so is mine 3rd August 20:20. I hope it is ok because sods law my warranty has just expired!!!! What does F-01 mean?
Jul 20, 2009 | Hotpoint Ultima WF860 Front Load Washer
Machine wont work and flashes f12 on function display
F12 is classed as a communiction error.
Either faulty connections or electronic panel
May 27, 2009 | Hotpoint Ultima WD72 Front Load...
Daughter has ultima wt940 error f-01 comes up any ideas
This refers to motor error, check motor wire connections & brushes. If these are ok it is its a pcb fault which requires replacing & programming.
Feb 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Dec 15, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint ultima
the code on my hitpoint wf840 this code keep flashing f-01 i dont what this means could you help me please.
Feb 13, 2008 | Hotpoint Ultima WF840 Front Load Washer /...
Hotpoint wf860
I've the same problem with my Hotpoint washing machine WF860P giving F01 flashing on screen ,machine not working, how could over come this and make the machine work again?
Please if you know the solution let me know
Shiya
Aug 15, 2007 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
147 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
