Question about Philips 20PT6446 20" TV
I have a philips power vision tv but some transistors were burnt beyond recognition can someone help with a detailed power supply diagram for the tv.chasis no-3139 127 27001 some of the numbers writen on it are .20PT2001/59A. [8239 124 3064.4]
4 Suggested Answers
  • 1153 Answers
SOURCE: philips tp3281c chasis#32d700-7570
I believe this set has a horizontal output that has a damper diode inside. you can check inset or out, most popular is out set. take multimeter and put on ohms or continuity and touch each leg by holding one lead to end and if you are looking for a short then in continuity it will beep or zero or very ohms. And Ohms just the same way. looking for low ohms like 1.0 or 0.9 or anything close. Switching leggs back and forth. If all three legs are shorted then replace. but in this one 2 can be shorted and still be good, just depends on which ones
Posted on Aug 29, 2007
daniel719
  • 240 Answers
SOURCE: transistor lost.
if you are replacing 7402
also replace diode 6404 this diode even thou it test goo will in long term overheat 7404 and caus it to go bad by leakage.
and if 7402 gose bad it is regulating the 15v stanby volts that is 7412 is also going to be bad so replace 7412 also
now
the part numbers are:
7402 = # 932211676682
7412 =# 932210514682
thanks,
daniel.
Posted on Jan 13, 2009
  • 901 Answers
SOURCE: i want to know the
You have to try in Google search.
If the transistor body is not damaged, you can read the type no. Replace it with identical No. Make sure the diodes and capacitors are not damaged. Check with multi- meter
Posted on Sep 29, 2010
Need circuit diagram
We have your question and someone will answer in due course. Stop posting.
Mar 09, 2016 | Televison & Video
RCA Projection television CTC195M I need the transistor number
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Jan 26, 2016 | RCA Televison & Video
Diagram for psu transistor position 7521
Download the repair manual to this set by internet. It has all details.
Apr 27, 2013 | Televison & Video
There are some burnt carbon resistors beyond recognition on a peavey tnt bass combo.so I need the schematic diagram
Try these schematics:
http://elektrotanya.com/peavey_tnt115s_sch.pdf/download.html
http://elektrotanya.com/peavey_tnt_100_1974.pdf/download.html
Scroll down to "Get Manual" at the web page and click on it to download.
Please note that on the first schematic above, the power amp schematic is way down beyond the parts list and layout of the preamp section... keep scrolling. ALSO the powoer amp shows a real WIERD connection where the output transistors drive against ground and the center tap of the power supply transformer for the power amp portion then bounces around with the audio output... that is a wierd connection but it is possible.
May 23, 2011 | Peavey Max 126 10 Watt Combo Bass...
A transistor or resistor burnt beyond recognition i need a wiring diagram to identify the type
You have not mentioned what electronic equipment you are requesting the details.
You will be able to confirm the transistor value from the stage where it has burned which also goes for the resistor. So take tech help than to try with trials to damage the set much further.
Jan 31, 2011 | Car Audio & Video
I want to know the value of transistors. my Philips TV 25PT4473/69T power supply is blown up. If Circuit diagram could I get
Sep 29, 2010 | Philips Televison & Video
No HT, components burnt
You can check out this website for your service information and parts: https://spares.bigwarehouse.com.au/index.php?cPath=24759_24762_24803 Paste the address in to your address bar. That will take you to the website. They had three of the four parts that you needed listed on the website 1.Q706 -Transistor bipolar FJAF5804 (TU) Fairchild $ 49.61 2. C744-Capacitor drawing SM SHR SYE/SWE 160V $ 19.06 3 R809- Resistor fixed small 1 ohm 2W 5% SF. $ 14.27 They also sold the service manual for $ 29.57. I hope this helps you with your problem.
May 12, 2009 | Computers & Internet
HTS3300 Home theater system
It cant be know like that way! you need it to be repaired at service station only so they can trace it out!
Dec 08, 2007 | Audio Players & Recorders
Philips 20PT6446 20" TV Logo
158 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
