Question about Bunn CDBCF 15 APS Coffee Maker
Hot Water Valve Inop
When I purchased the coffee maker (refurbished) it had a fully functional hot water valve. I could make a tea in about 30 seconds. It now is down to only a drip a second and would take ten minutes to fill what it did a year ago. Any ideas?
  • Anonymous Mar 21, 2014
    i put a new fill valve on
Good water pressure to machine but very little water from dispenser
Posted on Nov 04, 2008
Chimbali m1 water
Maybe the machine needs a cleaning. White vinegar usually works pretty well.
Jun 13, 2014 | Espresso RMI La Cimbali Espresso Machine
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
How do i make iced tea with my Keurig coffee maker?
In my experience it is not possible to make good tea with a coffee maker.
Tea needs to soak. 2 minutes for weak tea or if you like it like me 5 minutes for strong tea.
Coffee makers simply run hot water over the bean powder and don't soak it long enough.
L8ers
Sep 12, 2010 | Keurig Elite B40 Coffee Maker
Water is not coming through, though the steamer works fine.
If you mean no hot water through the pipe (for top-up and teas) then its probably the valve itself. However if you mean no water through the portafilter then its either a pipe blockage or, more likely, the pump or the three way valve
Mar 08, 2010 | Gaggia Classic Espresso Machine
Gaggia Titanium Espresso machine problem: steam venting into inside compartment after pulling espresso shots.
Normal, depending on the amount, when the hot water goes through the coffee and the pressure builds up the excess has to go somewhere when it stops, usually the drain tray, so there is a little steam loss.
Mar 04, 2010 | Gaggia Titanium Espresso Machine
We need to increase the hot water temperature, how
Depending on the model, if using a manual knob for the tea valve(same kind of setup as the steam) then you will have to turn up the p.stat. If it has an electronic button then remove the front top panel and look on the side of the solenoid you will notice a knob attached to another solenoid called an economiser valve, there should be a plus and minus sign on the knob. Reducing the amount of cold water being mixed with the hot water will increase the temperature.
Jan 25, 2010 | Astoria Divina SAE-1 Espresso Machine
Water coming out of the hot water dispenser all the time!
Hello>>To explain the repair of the valve via this chat box is too much post your emauil and I will send you the service manual on the unit it will take you step by step thru it.
Aug 19, 2008 | Miele CVA615 Espresso Machine
My coffee machine says decalcify ventilate
For ventilate:
When it says to ventilate, it is asking you to prime the pump. Put acup under the panarello wand ( the steamer/frother) to catch thedischarged water and press the hot water button (upper left button onmy machine). Wait until air stops coming out with the water, usually3-5 ounces, and then press the hot water button again.
You machine is now ventilated (primed) and should be ready to go.
For decalcify:
Recommend downloading and following these directions.
http://www.partsguru.com/user/Safe%20Descaling%20method.pdf
Apr 27, 2008 | Saeco Royal Digital Plus Coffee...
No hot water or steam
Well, I have little exposure to Saeco, but a lot to commercial coffee machines.
Saeco have a lot of custom made components, although these can be purchased, nothing is cheap! Neither is their repair service!
First, is the boiler heating?? If so:
No hot water/ no steam suggests a blockage. Assuming you can hear the pump working when attempting to do a coffee, you will probably find the water flowing back into the water tank via the relief valve. Of course, this valve itself could be the problem, or the pump failing to work through a blocked inlet filter or other problem.
Look now at the group head. Ever cleaned it? The filter and spray block should be removable, do so and clean them carefully. While you have them out, see whether water reaches the head by "making a coffee" into a cup placed under the head. BE CAREFUL OF SCALDING. If water now flows, cleaning the screen and spray block should restore operation.
Beyond that, it's inside the machine! There is a 3- way valve that operates when making a coffee. This can become clogged with coffee. There is another valve to open the steam.
If, like Saecos I have worked on, the boiler does both the hot water and the steam one at a time, look for problems BEFORE the boiler.
Hoe this helps a little....
Jan 19, 2008 | Saeco Vienna SuperAutomatica Coffee...
Bunn CDBCF 15 APS Coffee Maker Logo
200 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Kelley Hopper
Jim Y
Jim Y
pawnpower
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
