Question about Magellan Roadmate 760 GPS Receiver
Roadmate 760 BSOD
Is there any way to get past the BSOD when the 760 looses connection with the PC during software update 6 which is a firm ware and map update?
I can get the BSOD at power up (when I try to perform the software update again). I can only get rid or it when I remove the AC adapter. The power switch will not turn the unit off.
vr
geeknot
    President:
  • 2,712 Answers
Most likely the hard disk was corrupted while upgrading. First thing, download the latest software to your PC. Next try these steps:
- To be safe, insert a CF card (compact flash card) into the Roadmate and turn it on.
- Once it's booted up, turn it off and remove the CF card (all of your saved addresses, etc will be backed up on the card automatically)...these actually don't appear to be saved on the hard disk...they must be saved to flash memory internally, but it never hurts to back it all up and save a lot of typing later!)
This is provided you can get it to boot up..If you cant, follow the steps below:
- Turn on your PC
- Turn on the Roadmate
- Plug the USB cable into the computer, then the Roadmate
- Double Click on My Computer, and then double click on the drive which is the Roadmate (Removable Disk). You should see the files on the Roadmate. Highlight everything and delete it. Say Yes to All Read Only files.
- Once everything is deleted, hit back and right click on the drive letter.
- Select Properties, Tools, and Click on Check Now. Check both boxes...this will correct any problems on the disk in the Roadmate.
- Finally, when it's finished, close the My Computer window, and run the upgrade software. Follow the on-screen instructions to load the upgrade onto the Roadmate.
- When it's done, you should be all set...your user info will still be there...all of your saved addresses etc...but if they aren't, put in the CF card, turn the Roadmate on and navigate to the backup/restore menu under Diagnostics...choose restore...turn the Roadmate off and remove the CF card. (provided you were able to make a backup). Restart and you should be all set.
If you have difficulty with the download, use the original software disk that came with your device. Make sure you have the authorization code as well...
Posted on May 14, 2008
  • Swilin Sampson
    Swilin Sampson May 14, 2008
    If all else fails, you can contact their tech support at:
    USA and Canada:
    Hours: Monday through Friday, 6:00 a.m. to 5:00 p.m. PST/PDT
    Telephone: 800 707 9971
    Response in: English
    Genius:
  • 3,422 Answers
Click HERE to view the manual and also did you try a soft or hard reset?
Waiting for your reply..
    Master:
  • 555 Answers
A manual for your unit with troubleshooting guide can be found here.
  • Matt Jurach
    Matt Jurach May 14, 2008
    Magellan states that all BSOD errors can only be repaired by returning the unit for service. A support case can be opened from Magellan's website.
Where can I go to update the maps on my Roadmate 760 ?
Go to Garmin.com and they will have updates and tell you whether your unit will be able to take it.
Oct 29, 2010 | Magellan Roadmate 760 GPS Receiver
Part number 702142-02 has a loose connection where the power cord plugs in. I need that part and can't seem to find it online.The unit I have is the Magellan Roadmate 760
Have you had any luck with this problem.. I'm having the same issue.. Obviously a product defect... Please let me know, if you have any sollutions.. Futuresportinc@yahoo.com
Thanks in advance...
Aug 02, 2010 | Magellan Roadmate 760 GPS Receiver
Usb cdrom on the on the optiplex 760 keeps disconnecting. how can i correct this problem? Talleys.
Could be Hardware or Software problem, try below suggestions 1 at a time to pinpoint the problem.
Hardware:
  1. Restart Computer with USB CDRom not attached. Then attach.
  2. Make sure power connector to USB CDRom is firmly connected.
  3. Change to diffent power outlet for power supply of CDRom
  4. If connected to USB Hub, disconnect and connect directly to the computer.
  5. Try a different USB port on the computer
  6. Use a different USB cable (if using an extender, disconnect) Cable should be 6 foot cable or shorter.
  7. Try a different external CDRom drive to verify it is not a problem within that unit.
Software:
  1. Do windows update. Also Choose CUSTOM update (3rd option is drivers). Update all drivers available.
  2. Download most recent drivers from manufacturers website and install.
Nov 09, 2009 | Computers & Internet
Magellan RoadMate
The map software has become corrupted..
Please rate my help++++Thanks for using FIXYA
Oct 09, 2009 | Magellan Roadmate 760 GPS Receiver
System Software Missing
well if the system is missing it cannot be detected, contact Garmin support for the fix. This happens time after time in their updaqtes
Jul 19, 2009 | Garmin Nuvi 760 Car GPS Receiver
I'm trying to update a Magellan map update on my 760
plke1691
I think your problem is that you are using XP with SP 3, you cannot use anything more than XP SP2, so find yourself a friend that have an older operating system and update it. I bet you will not have any problem
Auto Nav 2000 aka GPS4ME
Apr 30, 2009 | Magellan GPS
My Magellan Roadmate 760 turns on and brings up the Magellan screen and then it locks. Can anyone help.
Sep 02, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 map update problem
Just push the antenna firmly back into the base; it pivots on a coax connector.
This is typical when you drop it.
The antenna is removable.
May 24, 2008 | Magellan Roadmate 760 GPS Receiver
BSOD
YES there is a way to get past BSOD after the software update fails....
May 02, 2008 | Magellan Roadmate 760 GPS Receiver
Can't update with latest software
You have to purchases the latest software update online from magellan website.So you will receive the software update in the form of 2 DVDs . So purchases the latest software updates by clik on the link below
https://www.magellangps.com/support/product.asp
(OR) Log on to
www.magellangps.com
Jan 29, 2008 | Magellan Roadmate 760 GPS Receiver
Magellan Roadmate 760 GPS Receiver Logo
143 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
