Question about Onkyo HT-S3100 Receiver
The reciever seems to be locked out. It is currently on TAPE mode. How do I unlock the reciever and re-set it
  • Onkyo Master
  • 12,061 Answers
Www.intl.onkyo.com/downloads/manuals/.../ht-s3100_manual_e.pdf -
Hi, please find above your user manual, and below your service and repair manual. These will help you to workout what to do, and how to reset your system. Usually simply removing it from the power will reset everything, except fro NVRAM entries, but the Tape is not one of them, so i wonder if you may not have some other sort of problem, use the service manual to check.
http://elektrotanya.com/onkyo_ht-r340_ht-s3100_3105_sm.pdf/download.html
Posted on Sep 12, 2010
My jandy control panel is locked. how do I get it unlocked
About 4,480 results (0.49 seconds) Search Results
    [PDF]AquaLink RS All Button and OneTouch ... - Jandy
    www.jandy.com/~/media/zodiac/global/downloads/0748.../6919.pdf
    Jandy Valve Actuator . .... If power is then interrupted, the controller will lock up. ...process, which can display its current status on the indoor control panel. Use the following steps to get to this "diagnostics" information: ...... lect Device to unlock.
    [PDF]Jandy Legacy WLRZ Control Quick Start Guide
    www.jandy.com/~/media/zodiac/global/downloads/h/h0346600.pdf
    The Legacy WLRZ will heat the pool or spa only when the filtration system is running and the ... DISPLAY LIGHT: Controller lights can be set ON, OFF, or to ... Make sure the control is in the ON mode ... To unlock, press and hold the up and.
    Clock" Mode; Locking/unlocking The Keypad; Remote ...
    www.manualslib.com > ... > LJ > Installation and operation manual
    Jandy LJ Manual Online: Clock'' Mode, Locking/unlocking The Keypad, Remote Control Operation, ... display of the controller will show the time set for the.
    Jandy AQUALINK RS TELELINK KIT Locked - Questions ...
    www.fixya.com > ... > Jandy > Jandy AQUALINK RS TELELINK KIT
Feb 03, 2016 | Jandy Pool & Spa
I cannot hear any sound out of my Polaroid TDX-01930B television.
Hello
First make sure that the "Mute" function is OFF. If it is set to "ON", no volume will be there.
Your TV has a volume lock function included [Global Volume Lock].
The remote comes preset to allow independent volume control of each selected device (Global
Volume Unlock). However, you may change the Volume Lock setting to Global Volume Lock so that
one device's volume will control volume in all other modes. After that, you can perform Individual
Volume Unlock on a selected device to set its volume control for independent operation or Global
Volume Unlock to remove all volume locking.
Locking Volume Control to One Mode (Global Volume Lock)
[1] Press and hold SET UP until the red LED blinks twice; then release.
[2] Enter 9-9-3 and then press the mode key for the device you want to control volume (for
example,TV). The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected
device (for example, TV) will control the volume regardless of the current mode.
Unlocking All Volume Control (Restoring Global Unlock)
[2] Enter 9-9-3 and then press VOL+. The LED blinks four times.
Volume is now independently controlled for all programmed devices.
Unlocking a Single Device's Volume Control
[1] Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
[2] Press and hold SET UP until the red LED blinks twice; then release.
[3] Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
independently controlled for the selected devices.
OK
May 06, 2011 | Polaroid TDX-01930B 19 in. LCD HDTV
My nokia 2690 is asking for enter sequrity code but not recieving the code i set. i remember i m entering exact no, which i set but its not recieving.
To Unlock the Mobile from the Security Lock you can use the Master Reset Code,To get the Master Reset You can reach here
http://www.theunlockspot.com/unlocking-services/rs10wp6/ I unlocked my Nokia 6600 from the Security Lock using the Master Reset Code........I got that Code at reliable Cost at
that site ...So You can check Master Reset Code For Your Mobile there......To Unlock that Mobile from the Security Lock.
Nov 18, 2010 | Nokia 2630 Cell Phone (Unlocked) - Black
Toyota corolla T3 will not lock/unlock from the key fob. Even tried the brand new spare key set which has never been used yet. Can use key to manually unlock and start car. Batteries seem to give a strong...
sounds like send/recieve signall out of sync.try locking car with key.hold lock button down on key for 30 secs.then unlock button for 30 secs.(point key at car from about 6 foot.)you do not need to sync all keys to car.hope this works.did for me.
Feb 17, 2010 | 2005 Toyota Corolla
Passlock
turn key all the way on (not to start) let set for 1 hur cycle key and try it.
Jul 20, 2009 | 1999 GMC Jimmy
Rear automatic door locks
Seems like a faulty switch connection since the front doors apparently work. in other words it is recieving current.
Dec 16, 2008 | 1995 Nissan Maxima
I have sony dcr-hc40
Put the camera in VCR mode not camera mode. Then play the cleaning tape. That should do it.
Dan
Jun 25, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
No Sound
1) First check the mute.
2) Make sure there aren’t headphones plugged in, that will disable the speakers.
3) Check the audio setup
4) Check your Volume lock
Changing Volume Lock
The remote comes preset to allow independent volume control of each selected device (Global Volume Unlock).
However, you may change the Volume Lock setting to Global Volume Lock so that one device’s volume will
control volume in all other modes. After that, you can perform Individual Volume Unlock on a selected device to
set its volume control for independent operation or Global Volume Unlock to remove all volume locking.
1. Press and hold SET until the red LED blinks twice; then release.
2. Enter 9-9-3 and then press the mode key for the device you want to control volume (for example, TV).
The LED blinks twice. Now when you press VOL+, VOL-, or Mute, the selected device (for example,
2. Enter 9-9-3 and then press VOL+. The LED blinks four times. Volume is now
Unlocking a Single Device’s Volume Control
1. Press a device key (TV, VCR/DVD, CBL/ SAT, or AUX).
2. Press and hold SET until the red LED blinks twice; then release.
3. Enter 9-9-3 and then press VOL-. The LED blinks four times. Volume is now
Mar 15, 2008 | Polaroid FLM-2632 Television
Still can't get fax not to pick up when answering machine is connected.
if you have the fax-575 there should be a TAD setting.
This is the setting you would use if you're using an answering machine on the same phone line as your fax machine.
To set the Recieve Mode :
Press Recieve Mode. The LCD display shows your current selection.
Continue to press Recieve Mode until your new selection appears. After 2 seconds the screen returns to the date and time display, along with your new Recieve Mode setting.
The 4 Recieve modes are Fax Only, Fax/Tel, TAD:Answering Machine, Manual.
Hope this helps!!!
Jan 30, 2008 | Brother FAX-575 Plain Paper Thermal
Onkyo HT-S3100 Receiver Logo
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
