Question about Hotpoint Washing Machines
Where is the filter on hotpoint aquarius wml760
  • 6277 Answers
SOURCE: where is the filter on the hotpoint wml760
Here are my complete, general pre-typed guidance notes for checking filters and motors ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 13, 2011
  • 15 Answers
SOURCE: Where are the filters in Hotpoint Aquarius WF340 washing machine
if you dont have one in the front under the lid your model comes with a slip on filter that goes on top of the aggitator you schouldnt run it without it because ge pumps have a tendacy to freeze up with the lint from your clothes especcially levis hope this helps
Posted on Dec 18, 2008
  • 135 Answers
SOURCE: i cant find my filter
It is either behind the kick plate at the front or in the pipe on the bottom of the drum which runs to the pump.
This is acessed by removing the panel at the back.
Hope this helps & thankyou for using Fixya.
Posted on Jan 19, 2009
  • 16 Answers
SOURCE: hotpoint aquarius extra filter
Normally in front of machine.Remove down plastic cover and then you see pump/filter,open and clean and make sure pump rotor is free to run.Jan
Posted on Feb 15, 2009
SOURCE: hotpoint aquarius wd440 drum sticking when rotate by hand
The drum on my hoover washing machine is sticking / grinding, can anyone advise what it may be? Thanks
Posted on Dec 30, 2009
Where is the filter on the on the Hotpoint Aquarius washing machine
The filter is inside the machine accessed from the back, see /www.youtube.com/watch?v=R__JTUX9nk4 . Hope this helps
Jun 19, 2016 | Hotpoint Washing Machines
Changing filter
Where is filter on Hotpoint Aquarius WD420
Oct 14, 2012 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius wml760 noisey when spinning with stuff in but ok empty
more than likely the rear bearing has gone bad and when a load is applied the difference in weight distribution causes the knocking.
Jun 15, 2012 | Hotpoint Washing Machines
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Where do I find the filter on my Hotpoint Aquarius WM22? Or does it not have one?
Both the Hotpoint WD63 (wash dryer) and the Hotpoint WM22 (washing machine) have a drain filter in the sump hose at the bottom of the tank.
This filter is a last line protection for the pump and is not designed to be cleaned on regular intervals by the user.
Jan 31, 2011 | Hotpoint Aquarius WD63 Front Load...
The Large black hose on the bottom of the tub houses the Filter ..Undo the Nylon clip at the top and you will see the filter within, note which way it comes out so that you refit it the correct way, with the holes lined up at the inlet/outlet.......
Jan 22, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Where is the filter located on a Hotpoint Aquarius WM63 washing machine?
Remove lower rear panel of washer.
Locate and remove the large black hose from bottom of drum, remove and clean the filter inside the hose.
Oct 21, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Where is the filter on a hotpoint aquarius 1000 washing machine
The filter is underneath the machine,tilt it backwards look underneath and
you will see a rubber pipe with a plastic inner with a clip on the end.
Undo the clip and slide the filter out.
Apr 06, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Where is the filter on hotpoint aquarius extra wwm39
Remove lower rear cover of washer, you should see a large black hose attached to bottom of drum.
Remove hose and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Sep 11, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint aquarius extra filter
Feb 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
345 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
