I just changed the batteries in my wireless mouse, and although it is lit up, it does not seem to connect to the laptop- there is no control from it. What have I done wrong?
  • 140 Answers
Hi, plz clarify what type of mice u r using in laptop? If it is bluetooth plz reconfigure in bluetooth dock installed in your laptop. Or if is is PS/2 / USB check the dongle connectivity and functioning.
Posted on Sep 12, 2010
How can I get my pointer to click on as it used to
Which operating system you could use the system restore but f its a hrdware fault the fault might return or not be fixed.
I have found that the best way to adjust your mouse settings is to create a control panel in your bottom toolbar scroll to the bottom of your screen right click you will see an array of options select the toolbar option then select desktop
then you will see the desktop in the bottom toolbar select the 2 >>arrow heads then all control panel items then select mouse this is in WINDOWS 7
in XP you will have to select the new toolbar option once you have that a browse option select my computer then control panel then a control panel option will be in the bottom toolbar
Click start right click on my computer select properties device manager control scroll to mice and pointing devices you might see a yellow question mark? right update driver
Click on >> control panel all control panel items mouse you should see 4 tabs buttons pointers pointer options and hardware under hardware you have options to troubleshoot also you can select properties under driver you will have the options update driver rollback driver or uninstall in xp.
In windows 7 click start control panel hardware and sound mouse you will see the same tabs and options as with xp
Change Touchpad Settings
Nearly every modern laptop computer comes with a touchpad for on-screen interaction. Depending on your operating system and touchpad driver versions, you can update the speed, sensitivity, tap speed and clicking functions of your computer's touch pad.
Accessing these settings and updating them to meet your needs is a quick and easy process with both the Microsoft Windows and Apple OS X operating systems.
Open the Control Panel by clicking the Windows Start button and selecting "Control Panel." Depending on your Windows configuration, this option may be located within the Start Menu's "Settings" sub-folder.
Double-click the Control Panel's "Mouse" icon.
Click the Touchpad tab.
This tab can have one of several names, depending on your computer manufacturer, your operating system version and your device drivers.
However, the most common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see any option resembling these, you may not be able adjust your laptop's touchpad settings.
Refer to the "Warnings" section if this applies to your computer. Locate the "Scrolling Settings" area within the touchpad properties tab.
Adjust the settings to meet your needs and then click "OK" to close the dialog boxes and confirm your changes. Change touchpad settings in Mac OS X
Click the Apple menu and then select "Preferences."
Click the "Keyboard & Mouse" icon.
Select the "Trackpad" option from the top of the Keyboard & Mouse dialog box.
Adjust the trackpad settings to meet your needs, and then close the dialog box to confirm your changes.
Enable a Mouse for a Laptop
Without the ability to drag and drop and point and click, a laptop computer is merely a desk ornament.
Most laptops are manufactured with a built-in mouse in the form of a touchpad.
If the touchpad fails or if you just prefer working with a mouse, it is easy to enable a mouse for use with your laptop.
Purchase a mouse that is compatible with your laptop.
You can find compatibility information on the manufacturer's website.
If the mouse is wireless, make sure that the USB receiver is included, or purchase it separately. The mouse will not function without the receiver.
Insert the batteries in the mouse if you are installing a wireless mouse.
The battery compartment is generally located on the bottom of the mouse.
Connect the USB mouse to the USB port on the computer.
If you are using a wireless mouse, connect the USB wireless receiver to the USB port.
Turn the computer off and then on again if you are enabling a standard mouse with a wire.
This will instruct the computer to run the "new hardware" wizard, which will walk you through the installation of the mouse, and your mouse will be enabled.
Turn the wireless mouse over, and locate a small indentation with a button.
You may need to use the tip of a pencil or pen to depress this button.
Simultaneously press the button on the mouse and the small button on the USB receiver.
This will initiate communication between the mouse and the receiver.
Hold the buttons down for about 5 to 10 seconds until the light on the mouse comes on.
Test the connection by moving the mouse.
If the cursor moves, you have successfully enabled the mouse.
If not, check that you have the batteries installed.
Try pressing the buttons independently of one another.
Press the button on the receiver until the light blinks and release it.
Press the button on the bottom of the mouse until the light on the mouse is lit.
This should enable your wireless mouse.
sign up
http://ftp.pisd.edu/guide/wireless-keyboard/wireless-keyboard.pdf
Nov 19, 2013 | eMachines E Machines E525 Laptop Computers
After not using my laptop for several months (it was plugged in however) my USB mouse will not work now when I boot up my Toshiba Satellite laptop.
Here are some trouble shooting steps you can try relatively easily....
If the mouse connects via a USB cable, try connecting it on another USB port while the laptop is on.
If it is an optical mouse, check to see if the LED(s) underneath are lit. Change ports until LED lights.
If you have another computer also with a USB mouse and it is working, try a mouse exchange. If the non-working mouse also does not work on the other computer and the mouse from the other computer works on your Toshiba Satellite laptop, the problem is likely with the non-working mouse.
Finally, If the non-working mouse is a wireless one, its battery may be dead. Try a new battery in it.
Feb 14, 2011 | Computers & Internet
Wireless EX110 Logitech mouse not connecting.
Try the mouse on a different computer. If it can't work on there then you may have a defective mouse. Contact logitech about warranty info.
Feb 01, 2010 | Logitech EX110 Mouse
My mouse was just working and all of a sudden it stopped, I changed the batteries, reset the small button on the bottom and also pushed the button on the plug in portion. Help Allen
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still not working. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the battery opening appeared to be bent down away from the contact on the battery tray. So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Dec 08, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Microsoft wireless notebook laser mouse 6000 not working
I have a miscrosoft wireless laser mouse 6000, and it also stopped working on my laptop. I changed the battery, still no workie. I tested the battery in another device, and it was good. I moved the mouse to another computer, and it did not work. The light on the usb connector was lit. [No changes at all to my laptop.]. It seemed like there was no power to the mouse, and I looked at the contacts inside the mouse. The contact just inside the mouse's opening for the battery appeared to be bent down (away from the contact on the battery tray). So, I pulled it up a little so it would connect when the battery drawer closed, and (after tweaking it a couple of times), it finally worked!
Jun 26, 2009 | Microsoft Wireless Laser Mouse 6000 v2.0
Resetting a wireless mouse
the usb connection and the mouse should have a button both need to be pushed usually the usb connector first then the mouse, or shut down the computer then restart. let me know if this helps.
Mar 31, 2009 | Logitech Cordless Mouse
Wireless mouse goes in and out
Clean the contacts where the battery connects. My wireless mouse was doing the same thing even with new batteries. I had to use a toothpick with a piece of Pencil eraser on its tip to clean the contacts in my mouse.
Dec 26, 2008 | Computers & Internet
Wireless mouse intermittent
try going into your control panel, go mouse/ settings change your mouse settings and get some air for computers clean everything on the mouse
May 18, 2017 | HP Wireless Optical Mouse
Wireless mouse and keyboard
Push the connect button on the wireless base, then push the connect button on the keyboard or mouse, that is supposed to reconnect the device. Make sure the wireless base is close enough to the keyboard.mouse, and nothing metal is blocking the path between the keyboard/mouse and the base.
Jan 25, 2008 | Labtec Wireless Desktop Keyboard/Mouse...
Wireless mouse for laptop
Make sure the batteries are good.
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch.
Hope this helps you. Bud
Nov 25, 2007 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
