Question about Frigidaire FRT17G4B Top Freezer Refrigerator
Water in bottom of fridge runs out under door Model FRT 18 DR HWD
SOURCE: leaking fridge
Its probably the defrost circuit either the heater or the timer
Posted on Oct 30, 2007
  • 51 Answers
SOURCE: water under crispers in my fridge
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Posted on Jan 13, 2009
woodchuck789
  • 4059 Answers
SOURCE: Kenmore Model: JSI-23, two door (water/ice)
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Aug 22, 2009
  • 401 Answers
SOURCE: FRT 18 DR HWO the compressor will not work. Fan
This could be for a couple of reasons. The compressor itself could be bad. The relay and/or overload could have burned out. I have seen just simply a wire has come unplugged. You will need to *UNPLUG* the refrigerator from the wall, remove the cover on the bottom rear. Feel the compressor to see if it is warm. If it is, it has been trying to start and could be just the starting relay. If not, the overload could be burned out. BUT with either symptom, the compressor could still be bad. You will need a multimeter to check it for shorted, or open windings. If you are not familiar with these things, please get someone with the expertise to diagnose it.
Posted on Dec 30, 2009
arikrom
  • 528 Answers
SOURCE: Model PTB1953GRO Maytag Refrigerator-Water drips into
you might need to open the freezer wall and clean the drain hole.. it might be cluge... very EZ :)
take all out even the ice maker unit
take back wall out and see if the drain is cluge with ice or something...clean it and out it all back
Posted on Dec 31, 2009
Viking fridge Model DDRB364RSS dripping water unto bottom cooler drawer and later under fridge - once a day or so. Door Gasket is a bit torn.
problem water in a fridge is moisture from the atmosphere--normally from opening the door but in your case from the damaged door seal
any tear regardless, compromises the compartment so have the seal replaced then see if you have a problem
Oct 26, 2016 | Viking Refrigerators
I have a ffa90 futre fridge & bottom frezzer. the fridge is frezzing the food in the door & in the fridge. have tryed water in botles & they get ice on it .in the door the food frezzers so
Find where the supply air is coming into the fridge part. It comes from the freezer and could easily be supplying -18 air direct to the door. This would give you a 2 in the fridge but anything in the direct air path could freeze.
Sep 07, 2012 | Hotpoint FFA90 Bottom Freezer Refrigerator
Refrigerator does not produce ice or water. Kenmore Elite Refrigerator Model Number: 795-775-69600
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Mar 12, 2010 | Kenmore Refrigerators
Dec 30, 2009 | Frigidaire Refrigerators
There is water building up in the bottom of the fridge ( under the crisper drawers). If I leave it there it will freeze. What is causing the water? The fridge is 18 years old.
drain hose is plugged... the freezer it need to drain water when if goes into defrost .the drain from the bottom freezer down to the bottom of the fridge... there is a pan under the fridge that holds the water until it evaporates
Sep 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water coming out the door while it's running.
could be a few differnt problems. first open door and check bottom of dish if it has a gasket down their or around door inspect it. door seals and on some models btm seals are common to go bad. also make sure a long pan is up on the front to close to door causing water to be splashed . should place al pans and plates frt to back not side to side, also lookat btm wash arm, if holes are plugged with food or the wash arm is broken or melted the water will hit the frt of the door too hard and cause it too leak. worse case scenario the door inner may need to be replaced.
Sep 18, 2009 | Kenmore Dishwashers
I have a model FRT 18B5JB1..the area under my crisper continues to fill with water and overflow on my kitchen floor..HELP!!
That is from your defrost drain either being clogged with food, or covered with ice. Behind the back wall in the freezer is a drain that empties underneath the fridge. If that drain gets blocked or froze over then the water will dump into the floor of the freezer and out the door gasket.
Sep 03, 2009 | Frigidaire Refrigerators
Model #FRT 1705CS Water was running down. I
should be under fridge with drain hose in it
thumbs up
Aug 17, 2009 | Refrigerators
Frigidaire FRT17G4B Top Freezer Refrigerator Logo
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
