Question about Frigidaire Dryers
I have a loud thumping sound coming from the dryer when it is running. I read to replace the dryer belt. I replaced the belt but unfortunately the dryer make the same noise. Any ideas?
    Habit-Forming:
  • 84 Answers
It sounds like the back bearing or the plstic felts on the front
Posted on Sep 12, 2010
LG DLE5977W THUMP DRUM WAS CRACKED-REPLACED FROM APP.PARTS.COM NEW DRUM OUT OF ROUND.SENT NEW DRUM SAME THUMP.REPLACED ONE ROLLER I SAW WAS BAD-SAME THUMP.REPLACED OTHER THREE ROLLERS-SAME THUMP.HELP
Anything is possible but I doubt 2 drums are bad. Since you replaced all the rollers and I assume you installed the drum on the rollers properly, i would look at the other drive parts. It might be a bad idler pulley and bearing. That is the small pulley that is spring loaded and puts tension on the belt. Check the complete assembly for any unusual free play that might cause a thump. Also look at the belt itself for any cracks or bumps.
Mar 02, 2015 | LG Dryers
LG electric dryer model DLEO332W or DLE0332W
Sounds like the belt broke..."loud thump"
Sep 21, 2013 | Dryers
Thump
The drive belt broke and the thumping was caused by a flatten roller on the belt tensioner. Replace the tensioner pulley and the belt to get it running like new again
May 25, 2010 | Maytag MDE9700AYM Electric Dryer
Clothes dryer makes a ''thumping'' sound
One of your rollers has a flat spot in it or something stuck to it. Every time it rolls round to that spot the drum jumps over the little speed bump in the road. The wheel needs to be replaced.
Mar 11, 2010 | Whirlpool GEW9200L Electric Dryer
When the dryer runs even with nothing in it it , makes a thumping
check the inside of the drumm make sure none of the fins are loose,
but sounds more like the wheel rollers are bad, sometimes is loud when it starts then seems to go away a little after the dyer get hotter, is the heat that makes the metal bearings make less noise. u can replace the wheels,the belt an tensioner at the same time is cheaper to pruchase the kit an have it all done the first time! bad wheels put more stress on belt an eventually will break apart so just order the entire kit
Feb 02, 2010 | Maytag SDE3606A Electric Dryer
Dryer makes a loud internal thumping sound when running
Sounds like a roller. You will need to remove the drum to see which one it is. They usually develop a flat spot which makes the thumping sound. First remove the top. This should give you access to the screws inside for the front panel. Take the front panel off, take the belt off the motor, and remove the drum to check the rollers.
Nov 26, 2009 | Dryers
Dryer won't spin. sounds like belt off tract
Hello there
here is some troubleshooting tips for you ok
The drum of the dryer is usually turned by a motor-and-belt assembly. There are two very clear signs that the belt is malfunctioning: You can easily spin the drum by hand when the dryer is off, or you hear a heavy thumping sound coming from the drum when the dryer is running. Here's how to test and replace the drum belt:
Oct 26, 2009 | Whirlpool GGQ8831L Gas Dryer
Belt and drum turns but with a thumping sound.
check the idler pulley, it could be broken. Also check the inner side of the belt for a chunk missing.
Oct 03, 2009 | Maytag Dryers
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Loud thumping sound
It's probably time for new drum support rollers. There are two rollers the drum rides on and their bearings can fail, which makes them noisy and also makes the drum wobbly while it turns. Replacing the rollers isn't difficult, and you can do it yourself if you feel comfortable working with hand tools and are patient.
Here's a good site with information on belt replacement and other repair tips, and a source for parts:
http://repair2000.com/wpoolbelt.htm
Nov 26, 2008 | Kenmore 63942 Dryer
Dryers Logo
61 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
