Question about Singer 7462 Mechanical Sewing Machine
When I try to push on the pedal, I get only a beeping sound and no action. Can you advise on this situation?
    Genius:
  • 1,788 Answers
Make sure that your bobbin is full, not empty or wound uneven. Go to singerco.com and see if it is listed in the frequently asked question or in the manual.
Posted on Sep 12, 2010
  • Mary Dunn Sep 12, 2010
    check your bobbin and make sure that it is threaded right and not near empty, plus threaded right.
Euro pro sewing machine 9106
try changing the needle--make sure it's the right type for the fabric being sewed
try rethreading the machine make sure to use every thread guide
make sure the power cord and the foot pedal are securely plugged into the machine
clean under the needle plate for lint and also in the bobbin area
also make sure the bobbin winder spindle is not pushed over to
wind a bobbin
if these suggestions don't help then it would be a good idea to have the machine checked..
Sep 11, 2013 | Sewing Machines
The needle does not move when the foot pedal is used.
Make sure that you pushed the bobbin winder all the way to the left.
Jimmy
Apr 01, 2012 | Singer 7444 Mechanical Sewing Machine
My machine beeps and will not sew when the foot peddle is pushed. i checked the BH lever inside the light cover and the small black switch appears to be in the up position. any other ideas?
make sure the foot pedal cord is pushed in correctly
rethread the machine top & bobbin
clean under the needle plate where the feed dogs are for lint
also clean the bobbin are for lint or loose threads
change needles
but also the foot pedal could have gone out
Nov 19, 2010 | Singer 7422
Push on pedal, hear the motor, no motion, arggg
it sounds like the belt might have come off the handwheel
Feb 02, 2009 | Brother XL-5130 Mechanical Sewing Machine
Beeping Sewing Machine
Your problem is most certainly with the buttonhole switch. Firstly: Look if the buttonhole lever, left back of machine, is push up in position. The beeping sound is a warning message. Secondly Remove the light cover, left of the machine, loosen back screw and remove left hand screw completely. Check for a small black electric switch, follow the brown and green elecrtic wire, just back of the light. If you push the BH lever up and down the switch finger should also move up and down. If it stays down, the machine will not work and give a beeping sound. If the switch finger is stuck, push it up with the BH in top position. Hope this will help you
Oct 31, 2008 | Singer 7422
Beeps several times and stops sewing.
I had the same problem. Through trial and error, I found the problem was with the thread tension. Usually the thread became wrapped around the spool holder as it was coming off the spool. As you continue to press the pedal, tension is created. When you release the pedal, some slack develops in the threading process and you are able to sew a few more stitches before the beeping starts again. If the thread is caught on the spool holder, simple re-thread the machine.That generally works for me. Also you can try to push to spool holder in as close as possible to the spool pin to alleviate any gaps. If the beeping continues to happen, place you thread in a cup behind the machine and thread as usual. You can also purchase an inexpensive thread holder. I made one out of a wood block and other odds and ends found around the house. Good Luck!
Apr 27, 2008 | Kenmore 19233 Computerized Sewing Machine
Singer 744 beeps
Jan 06, 2008 | Singer 7444 Mechanical Sewing Machine
Singer 7462 Mechanical Sewing Machine Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
