Question about Adobe Computers & Internet
Find the 2002nd decimal digit when 1/14 is express in decimal form.
How do I tell wether a number is rational or irrational?
If a number can be expressed as a ratio of two whole numbers then it's rational.
Alternatively, if a number can be expressed in decimal with a finite number of digits or as a repeating decimal then it's rational.
Oct 12, 2014 | Computers & Internet
Radical coversion
To obtain non integer results into a fraction form you must insert at the end of the command line the key sequence [MATH][1:>Frac][ENTER].
The calculator cannot give you results expressed as radicals; at least not natively. You will have to look for a program that does that. Search the education.ti.com or the ticalc.org sites for such program.
Sep 01, 2013 | Texas Instruments TI-84 Plus Calculator
Marla drives her car to school each day. If it takes her 12 minutes to drive one way, how many hours a week does Marla spend driving? (Express the answer in decimal form.)
Nov 26, 2012 | Texas Instruments TI-89 Calculator
I am trying to approximate square roots and need it to come out in a decimal but it won't allow me too.
In MathIO Mode
When you get a result as a radical (root) or a fraction, you can always convert it to its decimal approximate by pressing the [S-D] key. Pressing the [S-D] key a second time usually gives you back the fraction/radical form, but not always.
In LineIO Mode all results are expressed as decimals.
Aug 27, 2011 | Casio FX-115ES Scientific Calculator
I need the sine of 5 degrees sin(5) in decimal form, how do I get the answer? when I hit enter it just gives me Sin(5).
Assuming you're in degrees mode instead of radians, press diamond then ENTER to convert a symbolic result to decimal.
This can be done in one step by using diamond ENTER instead of ENTER when first calculating the expression. For example:
2ND [SIN] 5 ) diamond ENTER
Sep 20, 2010 | Texas Instruments TI-89 Calculator
When i add 12.3 + 12.3 I get the anwser in fraction form instead of decimal form.
If the result is already calculated and displayed, press the [S<=>D] key It will convert a fraction or radical to decimal. This is always possible. If the result is decimal it may be converted to a fraction or a radical (Not always possible).
If the expression to be evaluated is still in the command line and you have not pressed the [=] key, you can force the result to be displayed in decimal format by pressing [SHIFT][=] instead of just [=].
More permanently. If you do n o care for fractions and radicals, set the Input/Output mode to LineIO. To do do press [SHIFT][MODE] to access the (SETUP) screen and select [2:LineIO]
Jun 16, 2010 | Casio FX-115ES Scientific Calculator
How do I change from radical form to decimal form
If a result is still displayed in radical format, just press the [S<=>D] key ito convert it to decimal.
If a radical expression is still on the command line, press [SHIFT][=] instead of just [=] to have the result displayed in decimal format.
If you do not want radicals or fractions , set the IO mode to lineIO.
To do so, press [SHIFT][MODE] to access the (SETUP) and select [2:LineIO].
May 26, 2010 | Casio FX-115ES Scientific Calculator
When I divide, I get a fraction. How do I get a decimal
If your calculator is configured to be in MthIO, the fraction that is displayed is always reduced to its simplest form. (The denominator is the smallest possible.)
If you are adding fractions, the result is also a fraction in its reduced form.
If you want to convert a fraction to a decimal number, press the [S<=>D] key.
To set MthIO: Press [SHIFT][MODE] (SetUp) and select [1:MthIO]
To set LineIO: Press [SHIFT][MODE](SetUp) and select [2:LineIO]
In LineIO, all results are expressed in decimal format.
Jan 26, 2010 | Casio FX-115ES Scientific Calculator
I want the answer to be in decimal form.
Press "MODE"
then scroll down to "Exact/Approx"
select "approximate"
this will have your answers in decimal as default
Oct 16, 2007 | Texas Instruments TI-89 Calculator
Everything fraction?
Values are displayed in decimal form automatically whenever the total number of digits of a fractional value exceed 10. Otherwise you will have to press the d/c key each time to make it a decimal.
Aug 23, 2006 | Casio FX-115MS Plus Calculator
Computers & Internet Logo
112 people viewed this question
Top Adobe Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
