Question about Dell Optiplex GX280 (99301) Motherboard
Sir i have dell GX280 system 3.0 GHz optiplex. 1gb ddr2 ram with 80gb sata hard drive. Sir, my problem is this first i brought a system it runs fine but sometimes a day it hangs up. i return this system to my shopkeeper then he gave me new machine with same specifications. now it dosn't start and beep several times. but when i remove my ram and put it in same socket then it runs ok. when i runs my system even 24 hours daily it runs fine. but when i shut down it even after 2 hours. and then restart again it beeps several times and do not start. but when i put my same ram in same socket it runs ok. please tell me what happens to my computer.
  • 140 Answers
Plz check your memory with memtest. It can be downloaded from http://www.memtest.org/download/4.10/memtest86+-4.10.iso.zip .
Unzip the downloaded file and burn the ISO file to a CD and boot your system from the CD. It will check the memory of your system and it will indicate any error replace the memory.
Also check your memory slot is clean .. you can clean your system memory slot using a anti-static brush (you can use a tooth brush if anti-static is not available) and IPA
Posted on Sep 12, 2010
Schematic
Here you go:
http://support.dell.com/support/edocs/systems/opgx280/en/ug/memory02.htm
http://support.dell.com/support/edocs/systems/opgx280/en/ug/dindex.htm
May 14, 2012 | Famous Brand Dell Optiplex GX280 Intel...
Sir please help me.i have a dell optiplex gx280 system.and i have dell drivers of sound and graphics but they are only installable on win xp.please can you tell me where can i download dell optiplex gx280...
You can download drivers for your PC from Dell's professional website. Click on free drivers download, enter your model number and operating system. Download all drivers you want.
Jul 30, 2010 | Dell Optiplex GX280 Intel Desktop PC -...
Enquiries on maximum supported hard disk capacity and memory
Dell Optiplex 760 Vista
Max CPU Intel Q9550
Max RAM 8GB RAM
Largest HDD Shipped 1TB (Will likely Support 2TB)
Optiplex GX260
Max Intel Northwood 2.53 GHz - 533
Max RAM 2GB
Largest HDD Shipped was 200GB (Will likely support 500GB)
Dell Dimension XPS D300
Max CPU 333 Pentium II
Max RAM 384MB
Largest HDD Shipped 16GB (Will likely Support up to 80GB)
Dell Dimension XPS M
Max CPU 166S
Max RAM 64 MB
Largest HDD Shipped 4.3 GB (Max HDD likely 20GB)
Feb 09, 2010 | Dell OptiPlex GX260 PC Desktop
I just installed a 1gb ddr2 ram in my system and even though it detected the ram , the windows restarts all by itself and the message appears saying windows wasn't able to start properly and the usual text...
you may have incompatible ram. You can try running Memtest on the application that will test the PC ablility to read and write to all the channel and sectors of memory. Also did you try both slots?
Jan 03, 2010 | Famous Brand Dell Optiplex GX280 Intel...
Installation of IDE and Sata Hard Drives at a time
set your computer's BIO settings to default through the F2 button then connect the IDE fast and make sure its the master with an Operating system on it then connect the SATA after the IDE has been detected.
Nov 09, 2009 | Dell Optiplex GX280 (99301) Motherboard
Fan is sometimes noisey
Good day sir, hello, there are several option you may try, spray a little contact cleaner on your fan motor, just make sure its safe for electricity, second you either replace the fan, need to disassemble it, and reassemble the unit again, or check if the air ducks on desktop PC is not restricted. Hope this helps.
Sep 24, 2009 | Famous Brand Dell Optiplex GX280 Intel...
I have a Dell Optiplex GX270 running on windows XP pro. It has 2MB RAM and 80GB hard disc drive. When I checked to see if I could run Windows Vista Ultimate, the checker said I could, but might need to...
You'll need to have at least the following specs to run vista comfortable; 1 or 2 Ghz processor 1 or 2 GB RAM Video : AGP with 256mb or more cache Yoy might also have to consider changing your power supply.
Aug 13, 2009 | Dell Optiplex GX270
Computer saying error loading operating system
You can configure your boot setup from your bios screen (for dell, either F11 or F12) then set up your optical drive as your 1st priority then, save settings. After that, you need to insert your windows XP cd in order for it to boot.
inform me of what happened after you have done this.
Mar 16, 2009 | Famous Brand Dell Optiplex GX280 Intel...
Dell optiplex 280 ddr2 memory information
You cannot use drr667 on this computer since it only supportr ddr533, and it will be better if you use one stick of 1GIG RAM since your motherboard supports up to 2 GIG of RAM...
Dec 02, 2008 | Dell OptiPlex GX280 PC Desktop
Computers & Internet Logo
75 people viewed this question
Alun Cox
