The laptop will boot to the log on screen,but I cannot type in my password because the keyboard is frozen also. While booting the Alt F10 does not work either because of the keyboard is frozen. It won't read my back-up disks either and the USB isn't recognized.Question... If I bought the whole new Vista program and tried to load it, will its' disks be recognized?
If it is locking up because of corupt software then booting from a cd should allow you to reload a new os. But this sounds like a harware issue. If you install Visat on anything make sure it can handle it first. Vista take a monster machine minimun requirements are just that at min requiremnts it runs crippled.
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Hope this helps you
which operating system? and which name type/brand of computer?
also
also
which operating system and what type of computer?
also
When
during
there
also
The
on the bottom of the laptop in a compartment such as the memory compartment. Hope this helps
Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that most of us know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing a battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off the battery power, the BIOS/CMOS settings will be erased.
hope this helps
dont forget to vote
When you boot up to the log in screen type in administrator to log in if you cant log in
or
control panel user accounts
on the users tab,click the name of the computer administrator you can change the password there
hope this helps
or
hope this helps
i have a similar problem, right after i log in the screen turns black. i cant do anything besides ctrl-alt-del and try and restart. any solutions please!
