Question about StarTech.com StarView SV211K 2-port KVM Switch
I have a Eurovox EX7000hd, i tried to re-scan recently and its asked me for a PIN? Ive never set a PIN and have had no problems over last 6 months. Ive tried 0000,1004,1007 and 1648 plus many random ones. Any ideas anyone?
    President:
  • 2,571 Answers
All eurovox/starview and digivox boxes have been blocked from nagravision encrytped channels, this shows in different ways on different boxes.
Virgin has now switched to nagravision 3 encryption.
All eurovox/starview boxes can now only receive SOME free to air programs.
If you rescan, all the programs are picked up, but all the encrypted channels are blocked.
There is no fix yet, and there will probably be NO fix for your box, or any box without an ethernet connection.
Check afterdawn.com or techkings for more info
Posted on Sep 18, 2010
Ive just bought a sony ericsson xperia mini frommy friend it was on network 3 and ive put my o2 sim in and its asking for sim network unlock pin can i get this free? please help if possible
you can get the unlock code from your service provider itself for free of cost if your phone is within 6 months else you should buy codes from the third party provider. i got my codes from here. you can try one from here. SuperUnlockCodes
Jun 15, 2011 | Sony Ericsson Cell Phones
Does anyone have the codes for eurovox 5a01 please
WATS THE CODES FOR TELEPESR 6TH MAY
TELLS ME TO INSERT SMART CARD
ANY HELP WUD BE APPRECIATED
Feb 03, 2010 | StarTech.com StarView SV211K 2-port KVM...
HOW CAN I RESET THE EX7000HD WITHOUT USING THE
I know that the earlier eurovoxs had a reset button inside the case. Opening the case will invalidate the warranty. Ensure the power has been turned off.
Jan 24, 2010 | Televison & Video
How to insert codes into eurovox ex7000hd
hi mate, i have made a toolbar with a cablebox updates button, this gives access to fully illustrated tuorials, new codes, firmware updates etc etc everything u need to do with ure eurovox is here for you, http://allsportsforus.OurToolbar.com/
my toolbar is clean and safe and 100% legit, it also has many more features, like downloads, music player, movies and much more. I hope this helps.
Dec 04, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Can any tell me how to setup a eurovox its the 2007 version ive scanned the channels theyve all came up but skysports, movies and all the other channels you pay for wnt come on. i used to have a starview...
Dont know if it helps or not but this is the method i used to set up the eurovox max when i first got it - it may work for you.
EUROVOX MAX SETUP
This is the method I use for setting up the eurovox max box but I have been told that it works for versions 1 and 2 as well
PLEASE NOTE : IF YOU ARE USING A SPLITTER IN YOUR SETUP THIS MUST B E REMOVED for the initial POWERSCAN as the box needs to scan from a pure signal- this will ensure all channels being found. – scanning throught a splitter can result in the loss of 50+ channels.
Firstly before you start to scan the box you need to:-
PRESS MENU
GO TO CONFIG
GO TO CLEAR DATA – IF IT ASKSYOU FOR THE PIN PRESS 0000
SELECT – ERASE ALL CHANNELS
Then it will ask you are you sure so press OK
Then wait a few seconds then press EXIT and EXIT again
What you need to do now is a POWERSCAN.
The following is a step by sep method of carrying it out!
Press the MENU button
Go to INSTALLATION and arrow right to USER INSTALLATION
Type in your pin (normally 0000)
Press the YELLOW button for POWERSCAN and change the mode to FULL from Normal by arrowing right to reveal FULL
Now press OK, this will begin the BRUTEFORCE POWERSCAN which can take up to 40 minutes,but it is guaranteed to find every single channel on the network in your area.
Once done the box will switch to a random channel to indicate it has finished !
You will now have around 240 or more channels (in some cases regions can receive up to 330 channels!)
You now need to switch to a non free channel and let the box update the codes – this could take a minute or two, it will indicate on the screen “updating please wait” once finished all channels will now be unlocked.
That’s it you’re all done … HOWEVER …. If you find that you get no channels at all there is a further adjustment you can make to ensure you get the 250 plus channels that your area box will be able to receive and again it’s quite simple to do!
First press MENU
Then go to USER INSTALLATION
Type in your pin (0000)
Press YELLOW button to POWERSCAN
Then change the mode to NORMAL
Then arrow down to the SYMBOL RATE and if its on 6.952 then change it to 6.887 (or vice versa!!)
Then press OK and it will carry out a scan like the powerscan of before.
If after you have tried this and you still are channels short then keep the symbol rate at the new figure but adjust the scan to FULL and try again.
Sep 16, 2009 | StarTech.com StarView SV211K 2-port KVM...
Code for Eurovox EX5000PVR in Ireland
do you realise your missinga couple of numbers from the second line?
Dec 31, 2008 | StarTech.com StarView SV211K 2-port KVM...
Ntl eurovox ireland
go back to the (Menu) screen then (installation) and (OK) on (User Installation) again enter 0000 as your pin, Now press the yellow button for (Power Scan).
Start the search @ 290.00MHz & end it @ 420.00MHz using the symbol rate of 6.887Mbaud then hit (OK) to start the scan. could take a few minutes but should get all your channels back.
Dont suppose you could post the most recent codes up please?
Dec 25, 2008 | StarTech.com StarView SV211K 2-port KVM...
Eurovox Max V 2008 - needs new firmware flash (27 Nov 2008)
go to http://www.bigmaq.co.uk/ download the latest firmware its there ive seen it install that problem solved
Dec 04, 2008 | Audio Players & Recorders
Eurovox problems max
im assuming your talking about the Pin for the Parental Controls? To my knowledge there is no place online that can help us reset your pin, You will need to contact the manufacturer and have them give you instructions on resetting the pin, The only way i would think you would be able to get the skipped channel back is to get the pin, Sorry for your trouble.
Nov 25, 2008 | Televison & Video
StarTech.com StarView SV211K 2-port KVM Switch Logo
109 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
