Question about Sony PlayStation® 2 Console
PlayStation 2 I tray to unlock the parental control whit 7444 code but it did not work... it say wrong password... what can i do ??
  • ps2fanatic Nov 16, 2008
    i got a used ps2 and 7444 wont work
  • 333 Answers
Whic model do you have? Please clarify.
Posted on Sep 14, 2009
How do I reset the password for parental control
Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
When the screen asks for the code, press the SELECT button, then enter in the code "7444".
The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Good Luck,
Rodrick
Apr 22, 2011 | Sony PlayStation 2 Slimline Console
My Sony Playstation 2 (SCPH-79001), and I am trying to reset the password for rating access
Here is the procedure to reset the parental lock code. It's important to note that this RESETS the parental lock. This is not a master password or anything to that extent.
Oct 24, 2009 | Sony PlayStation Portable (PSP) Console
Need master pass code to a ps2 to play movies
There is no master pass code, but there is a code to reset the parental settings. It's important to note that 7444 is NOT the password. You have to hit SELECT when asked for the password. That is where you enter 7444 to clear the code.
Here is the procedure to reset the parental lock code:
Oct 14, 2009 | Sony PlayStation 2 (PS2) Console
I was given a playstation 2 and I don't know the parental code so how do I reset it with out the code
  • Power on the PS2
  • Press the Reset button
  • Inset an R-rated DVD and wait until the board comes up telling you that Parental Control is on
  • Hit the Select button
  • At the enter password prompt, hit the Select button
  • At the Delete password prompt, enter in your password
  • Hit the X button
  • You can try 1111 or 7444 those are known default codes or leave the playstation unplugged for at least 72 hours and that should clear the password.
    Sep 13, 2009 | Sony PlayStation 2 (PS2) Console
    Bought a used playstation 2-need to get parental
    1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under custom setup.
    2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
    3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
    4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
    If this does not work, the other code is usually 0000. However if they change the default password, then it will be hard to find out.
    Sep 10, 2009 | Sony PlayStation 2 (PS2) Console
    I bought a used playstation2 andit had a parental password.How do I get the password off so it will play dvds?
    -power on
    -reset
    -inset DVD R rated..(18 up only) when board comes up telling you parental control is on
    -hit select
    -it will say enter password
    -hit select
    -it will say delete password
    -enter in 7444
    -hit X
    supply one you will remember, or write it down.
    If this doesn't work only unplugging the playstation for 48-72 hours will clear this...
    Aug 08, 2009 | Sony PlayStation Portable (PSP) Console
    My nephew put a code for movies, he forgot the code
    1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under GA_googleFillSlot("TL-IMU-Article"); custom setup.
    A note for parents: If you're wondering what is stopping your child from using the above procedure to circumvent your rules, you can verify that they haven't reset the parental control very easily. Since the above procedure eliminates the old password entirely, all you need to do is see if your original password still works. If it does, they did not use the above procedure to break the rules. If it doesn't, they might be trying to pull the wool over your eyes.
    http://www.techlore.com/article/10505/Resetting-Parental-Lock-Code-on-Playstation-2/
    Jan 04, 2009 | Sony PlayStation 2 (PS2) Console
    Parental password?
    Jun 06, 2008 | Sony PlayStation 2 (PS2) Console
    Remove parental password on ps2
    Enter the password 7444, it will delete the old code and let you watch the movie you want
    Feb 17, 2008 | Sony PlayStation 2 (PS2) Console
    How do you reset password for ps2 if you forgot???
    all you need to do is go to the screen where it asks for your password while your there press select on you controller and then type in 7444 it will reset your password and let you make a new one
    Jan 27, 2008 | Sony PlayStation 2 Slimline Console
    Sony PlayStation® 2 Console Logo
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    juanmireles1
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
