Question about Mitsubishi Computers & Internet
My Mitsubishi laptop seems to be working but the screen remains dark. I cannot, therefore see anything on the screen. Thanks for your help, Obed
  • 2,567 Answers
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Posted on Sep 18, 2010
Dark screen and flickering on the laptop computer model pcg 61611L
I would check the GPU by connecting an external monitor before booting it, that will allow the external drive to automatically work.
Jan 02, 2014 | Sony VAIO Computers & Internet
Tip
What should be the problem when screen seems dark even after switch on.
my lapto is having a problem of not displaying anything in the screen. it seems dark even after switch it on. please give me a useful suggestion for it. my laptop is acer aspire 4310.<br /> <br /> thank you.
on Nov 12, 2010 | Computers & Internet
Black screen on Elite 8460p
Return the laptop, HP has a history with motherboard issues.
Apr 03, 2012 | HEWLETT-PACKARD Elitebook 8460P
My brightness control does not work just turned on and can not hardly see anything it is up and running what now
Have you tested it with an external monitor?
I would say you either have a damaged inverter board or screen baclight lamp. Usually the inverter board fails in one of the following ways:
1. When you turn on the laptop, the screen lights up for a short period of time and then goes dark. You still can see an image but it is very dark, almost invisible and definitely not usable. When you restart the laptop, the screen lights up and then goes dark again. The laptop works fine with an external monitor.
2. Your laptop turns on but the screen remains dark all the time. You still can see a very dim image outline. The laptop works fine with an external monitor.
3. The laptop screen works fine for hours or even days, but sometimes it goes very dark as it mentioned above. When you restart the laptop, the screen works fine again.
Inverter failure symptoms are very similar to backlight lamp failure symptoms and in most cases you cannot tell which one is causing the problem until you replace either the inverter board or the backlight lamp. From my personal experience, inverter boards fail more often than backlight lamps. If you have to guess, replace the inverter first.
Mar 24, 2010 | Dell Inspiron 1545 Notebook
I have an Acer aspire 1640, the screen remains blank
Try to connect the laptop using and external monitor if the external worked the problem is with the laptop. If not try to reseat the memory module also.
ERNZ
Feb 03, 2010 | Acer Aspire 1640Z Notebook
Screen is dark or dead on my 17" Macbook Pro
This could be a backlight issue, a board issue or an inverter issue. Look at the screen closely, if there is a faint image it's either a backlight issue or inverter issue. To weed out between the two you can just order on inverter, they're 20 bucks on ebay, if that doesn't work, replace the backlight. Backlight repairs are somewhat difficult. As much as I would like to be able to tell you a quickfix that will solve backlight the problem, you'll most likely have to google for guides that show you exactly how to replace the backlight or bring it in for repairs.I work for Mac Repair NYC and i have to fix this problem a lot.
May 21, 2009 | Apple MacBook Pro Notebook
My screen remain dark when my laptop is turned on.
If you can hear the sound of Windows starting up, your blacklight probably died. If you can't hear the Windows start up sound, Windows may need to be re-installed. Most likely though, it's a faulty backlight.
Please rate, Thanks!
Oct 03, 2008 | Aspire Acer 7520-5324 Laptop
Solid Line Across Screen
Suspect the Light Engine part # 939P977010
Feb 21, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Computers & Internet Logo
46 people viewed this question
Top Mitsubishi Computers & Internet Experts
Coss
Shaukat Bhutto
Level 1 Expert
Matthew Spark
Matthew Spark
Are you a Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
