Question about Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120
Aces Aspire M1640 desktop-pc starts but the monitor says NO SIGNAL. Tried various monitors and videocards without result. Can't find what mainbord is in it to have it changed. Regards, Toine
    Scholar:
  • 181 Answers
Black out can be caused by series of things. Power supply is one. Second is the motherboard, memory and the processor aside from the video card. Motherboard and processor can be isolated,first is to remove the rest of the devices such as hard disk and cards and memory. Beep sound means your board is still doing fine. Re install all the devices and power on again. Good luck
Posted on Sep 13, 2010
My acer aspire m3641 just shows black screen
Is the computer booting? Fans spin? LED's blink? Sound? Have you tried another monitor? If so, check and reseat ALL cables. The specs indicate you have Integrated NVidia 7050 Graphics Adapter. You may need a aftermarket PCIe x16 Graphics Card to install in a open slot. Verify the cables are good and the monitor works on another computer first.
Mar 19, 2013 | Acer Aspire M1640 Refurbished Intel...
I got an acer asprine M1640 but when i start it its keeps beeping short beeps and it wont start a friend of me said it was something with the videocard when i replaced it it stayed the same it kept beeping...
Bad Power Supply
Weak voltage power rail
Do you, or your friend have access to a multimeter? An economical unit can be purchased for as little as $8 to $12. Available in a multitude of stores. An auto parts store is but one example. Analog or digital is fine.
This way you can test the 3 main voltages coming from the Power Supply.
A) 3.3 Volt power rail
B) 5 Volt power rail
C) 12 Volt power rail
(All DC voltages. In comparison, two D cell flashlight batteries store
3 Volts DC. { 1.5 Volts each )
OR; do you have a KNOWN to be good, Compatible power supply you can borrow for a test unit?
Compatible: Has to have at least the same Wattage, or more, and has to have the correct power cables, and number of power cables needed.
Primer:
1) If ALL of the LED lights were on at once, they would use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts of power.
3) A typical Processor can use 51 to 125 Watts of power. Just depends on what Processor it is.
Your Power Supply doesn't have enough power to 'b-low it's nose'.
Nothing shows on monitor? It isn't going to. No Signal. No video signal.
This is because the computer isn't sending one. Why? Because the computer isn't working.
Let's start with this. Post back in a Comment as to your results.
Regards,
joecoolvette
Jul 23, 2012 | Acer Aspire M1640 Refurbished Intel...
Acer M1640 Desktop Acer monitor come up no signal . Have put other monitor it comes up the same
Reset the cmos usualy a jumper, or remove the batery for 10 min, it might be a videocard problem, try another videocard. It might be a memoryproblem.
If you hear bleeds google for biosbeebs and that will show you wich bleeb is what error.
If all else fails change processor and powersuply or finaly the motherboard.
May 02, 2012 | Computers & Internet
My acer aspire m1640 crashed and now when i turn it on nothing happens the monitor says no signal
Sound like a bad motherboard.You are getting the error because no signal is been sent to the monitor. Make sure the memory is inserted properly and firmly. Check all other cards and plugs are all inserted and firmly sitted. and try to boot the system, if nothing stll happen, you may have a bad motherboard
Apr 12, 2011 | Acer Aspire M1640 Refurbished Intel...
Acer Aspire M1640 has no signal to monitor ? I try to star up with out the ram card , I can hear the beep .. Any idea what is the problem ? Thanks.
I have the same problem, i have tried everything and some people say its because the graphics chip on the motherboard has burnt out due to improper cpu pasting
Jan 15, 2011 | Acer Aspire M1640 Refurbished Intel...
No signal display on monitor. Checked another monitor. Purchased a new graphics card, but still have same problem. Cannot install software for new graphics card because of no signal. How can I delete or...
Yes you need to disable the integrated card in DEVICE MANAGER---go to START> right click on MY COMPUTER>PROPERTIES>HARDWARE>DEVICE MANAGER then choose display adapters and double click the device and at the bottomchoose "Disable this device"
Dec 31, 2010 | Acer Aspire M1640 Refurbished Intel...
When I start up my PC there is an error no signal i cannot start the PC i hve tried replacing the memory and also the videocard. but it doesnt work.. whats the problem ?
no signal means either lead to monitor loose or adrift..contacts on memory dirty,the processor not kicking in,try resetting the bios button on motherboard,on some motherboard theres a lcd readout which shows a code if any problems
Jul 05, 2010 | Acer Aspire M1641-U1521A PC Desktop
Acer Aspire M1640 PC monitor 'no signal', tower non-responsive.
i found the same problem (can't load BioS) but we are not alone as you can see on web about M1640 and M1641 it's very popular defect
I made various test:
cpu (pentiun e2180) pass the test mounted on another PC.
I removed the two ram and replace with other ,result nothing (Pc power on but can't load the BIoS).
Some of this Acer model have this motherboard crash
look also here
http://www.tomshw.it/forum/schede-madre-e-ram/129267-scheda-madre-non-da-segnali-di-vita-microstar-n1996.html
http://www.tomshardware.co.uk/forum/271665-12-motherboard-problems-m1640
http://www.fixya.com/search/p954810-acer_aspire_m1640_refurbished_intel_desk/acer_aspire_m1640_fast_ddr2
http://www.tomshardware.co.uk/forum/270660-12-acer-motherboard-sak09-replacement
Change the MotheBoard
Mar 10, 2010 | Acer Aspire M1640 Refurbished Intel...
We have an acer aspire M1640. won't respond
unplug everything for a few hours and let it drain. then go into bios and turn off all power save settings.
Aug 23, 2009 | Acer Aspire M1640 Refurbished Intel...
Get NO SIGNAL on Acer M1640~Monitor is Fine~Is CPU
Try removing the system memory and clean the brass contacts and the slots it goes into, then reseat the memory and try to boot again, the memory looks like this >>>>>>>
Good luck
Jun 28, 2009 | Acer Aspire M1640 Refurbished Intel...
Acer Aspire M1640 Refurbished Intel Desktop PC - Intel Pentium Dual Core E2160 1.8GHZ, 1GB DDR2, 120  Logo
1,470 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
