Question about Smith AO Pool Pump Motor
I found silver balls in my pool pump basket - Smith AO Pool Pump Motor
    President:
  • Smith Master
  • 1,378 Answers
Do you have a robotic or automatic pool cleaner? If so, inspect the bearings in them for failure. Otherwise, is it possible they were tossed in by something outside the pool? Your motor bearings would have a very hard time coming apart and allowing the balls from inside the bearings to migrate to the pool.
John
Posted on Sep 12, 2010
Hayward pro series sand filter does not have enough suction to operate pool cleaner. What can cause this?
if you are getting a suction noise at the skimmer then that means you need more water in the pool. Also if you have anything in the skimmer basket like tablets then take out the basket when you are using the vac. the only other thing I can think would be the problem would be the filter is clogged. I know you have back washed it but I would do it again to be sure it is not dirty. good luck
May 26, 2014 | Hayward SAND FILTER, PRO SERIES
Filter has clean hoses and new sand, but water return is still low. valve cover has debris in non-removable housing.
Does not sound like a product failure. But more info would help so I'm making some assumptions. Double check the hose connections going into the filter are in the proper location. The hose from the pump will plug into the highest port and the return to the pool will be the lower port that does not have the sight glass. Make sure you are only vac'ing on the "filter" or "waste" setting. Never vacuum your pool on "backwash". If this is not your problem then look to the pump for an impeller blockage. Lining the pump basket with a nylon stocking will keep debris like cottonwood from making it through the basket and clogging impellers and filters.
Apr 10, 2014 | Blue Wave Sandman Above Ground Sand Filter...
Skimmer basket stuck
turn off pump then you should be able to get the basket loose
Apr 04, 2014 | Pentair "Pentair" In Ground Pool Pump ...
How do I remove air from pool filter lines?
with out seeing your set up not to easy,but lets try
1 your pump room is below surface of pool, make sure your pool level is high enough to return water to pump via the skimmer hole in side of pool at surface level. water should fil pump basket. check that you have a good seal on glass cover. no water in basket check if valve from pool is open still no water close valve fill filter chamber with a hose close glass cover start pump and open valve immediately.
2 pump room above pool level, close inlet valve fill pump filter with water close glass cover securely start pump and open valve.
a good drawing of you equipment and its position relative to pool how and ware u connect vacuuming hose
May 30, 2012 | Hayward Pool & Spa
I've changed o-ring at pump basket lid, cleaned all baskets and filters, had the Hayward pool vac internal parts all replaced and can't get pool pump to **** enough pressure to run pool vac....
If you reach into the hole behind the basket in the pump. You should be able to use a screwdriver to feel around to see if something is clogging the impeller. If so you can work it loose by working it in a counter clockwise direction, than use long nose pliers to pull it out. If that is your problem
Also check all your hoses for leaks.
Sep 09, 2010 | Hayward 1.5 Hp Northstar High Performance...
Water flow seems to restricted and the hose caves in
I FOUND ON MY INTEX POOL WHEN HAVING THE SAME TROUBLE IT HAD BLOCKAGE BETWEEN THE 1 1/4 HOSE ADAPTER ON THE INLET SIDE OF THE CONNECTION SUPPLYING THE PUMP AND THE BLUE FILTER SCREEN BEFORE THE OUTLET VALVE. MIGHT BE WORTH CHECKING THERE AS THE STRAINER BASKET WILL NOT CATCH ALL THE FINE DEBRIS. TAKE YOUR OUTLET HOSE OFF AND OPEN THE VALVE AND SEE IF IT IS RETRICTED.
Jul 01, 2010 | Intex Plunger Valve & Straniner Basket set...
Only one pool return is working, there is no pressure in the skimmer basket and I already ran water into the basket by the pump to prime it. No water shoots out of the top of the filter when it is open...
With the pump off and the basket out reach inside the pump with some needlenose pliers and see if something is clogging the impeller. It will be inside the hole behind the pump basket and will feel spongey when you reach in there. If so work it counter clockwise and when it loostens up pull it out with the pliers. Hope this helps.
Apr 24, 2010 | Pentair 3/4HP Pinnacle High Performance...
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Suction with my pump
First thing to check is the removal of any winterizing plugs in the return lines. Sometimes plugs are fitted inside the lines in the pool making them not obvious. Secondly, check that any valves in return line are open. Many never lube type valve handles are oppositely positioned as compared to ball valves. If the multiport valve hasn't been tampered with, then there really is no other place to look. The flows everywhere but back to pool.
Apr 24, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
How to Clean Pump Strainer basket
Turn the swimming pool pump off and wait for the water to drain from the strainer basket. You want to make sure that the pump is completely off before you proceed. Remove the screws or any items securing the lid of the strainer basket. Open the lid and pull out the strainer basket. Vacuum the strainer basket or scoop out any debris. You may want to run clear water through the basket to ensure you removed all debris. Feel toward the impeller and remove any clogs or obstructions preventing the impeller from working properly. Check the o-ring under the cover of the pump strainer housing. You may need to use a silicon lubricant to ensure a water-tight seal. Put the strainer basket back into the pump strainer housing and pour some water into the basket. Replace the lid and secure it in place. Turn the swimming pool pump on and check for proper pressure. If your pressure doesn't register, you may need to troubleshoot to find the problem.
Aug 27, 2008 | Belle Foret Accessories NBBS2-TB Tumbled...
Smith AO  Pool Pump Motor Logo
117 people viewed this question
Top Smith Pool & Spa Experts
Mike Squire
Jay Finke
Jay Finke
Bill Jordan
Are you a Smith Pool and Spa Expert? Answer questions, earn points and help others
