Question about Tappan TGF364AS Gas Kitchen Range
I just moved in to a home and the tappan oven screen went blank during self cleaning and the door is locked. It is an oven unit only - I'm guessing from the 80's or 90's. The directions were on the door for self cleaning. I pushed the self cleaning button, rotated the knob to 2 hour cleaning. The unit turned on the door lock button came on. Somewhere around an hour left I noticed the screen went blank. The only button that now functions on the unit is the oven light button. I'm guessing the control panel went out but is there any other options to check?
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
Master_Tech
  • 770 Answers
SOURCE: tappan tgf355 oven door won't unlock and has code f3
open the back and manually spin the motor for the latch arm it may need to be replaced
Posted on Jan 25, 2008
heatman101
  • 43501 Answers
SOURCE: Need Instructions on Self-cleaning for my Tappan Electric Range
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Posted on Apr 28, 2010
SOURCE: I have a tappan self cleaning oven KMT-2893-87A
call Sears for they took over Montgomery Wards services and we have the same stove
Posted on Aug 21, 2010
SOURCE: Tappan Millenia - oven door locked can't open
how do i open my tappan computerized over when close and won't open
Posted on Sep 07, 2010
I have a tappan self cleaning stove. I push the clean button and nothing happens. What am I doing wrong
Some have a "lock" switch that locks the door from opening. Most are located on the front of the oven door top. Moves over in the lock position, then hit the button. Hope that works
Sep 29, 2014 | Kitchen Ranges
I need to get my oven unlocked. The cleaning cycle went haywire
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Oct 25, 2009 | Whirlpool RBD305PD Electric Double Oven
Oven door locked will not open
try putting the stove in self clean when it goes in for about 1 minute cancel the self clean see if it opens.
Nov 30, 2008 | Tappan 30IN ELEC IGNa Oven
Tappan self-clean oven door locked shut, fan keeps running
Did you give it time to cool down? If so, probably a control issue.
Sep 01, 2017 | Tappan TGF320 Gas Kitchen Range
Locked door on self cleaning oven
try unplugging the stove for some minutes and plug back in.
Aug 20, 2008 | Tappan MEF500 Electric Kitchen Range
Oven door during self cleaning mode
hi there sounds like a faulty door interlock!!!!
have you tried just leaving the cooker on self clean as some models will lock them selfs.
Feb 29, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchenaid kgri801pbs
there is a thermal fuse in the back of the oven that more than likely has tripped during self clean poor air flow around can cause this power surges during self clean can too you have to pull the oven out and remove back panel to find it
Jan 10, 2008 | KitchenAid KGRI801PBS Gas Kitchen Range
Kitchen aid model# kgri801pbs
On most models, the door stays locked during a self clean, until the temperature returns to normal for safety reasons.
It sounds like your unit may have tripped a breaker during this self clean event. Check your panel for a tripped breaker. If the oven has cooled down, and the lock is still engaged, then we may have a different problem.
Let me know what you find out!
Tappan electric stove designer series
the cleaning light and the lock door light doesn't go on when I set them to self cleaning and lock the door what should I do
Nov 17, 2007 | Tappan 30IN ELEC IGNa Oven
Oven shut down during Self-cleaning
tde, sounds like your thermal fuse (TC0) opened on the back side of the oven. If this opens, it will shut the oven down. This happens alot during self cleaning on built ins. Sometimes I have to re-route the tco to a different area to prevent this from happening. Your part number is 4451442. You will have to pull the oven out far enough to remove the back paneling and replace the fuse....Catriver..post back.
Oct 24, 2006 | Whirlpool RBD275PDS Electric Double Oven
Kitchen Ranges Logo
46 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal DeAngelo
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
