Question about Hotpoint Aquarius WMA42 Front Load Washer
My hotpoint washing machine wt741 will do nothing except fast spin, LED display is flashing TEST, it will not stop doing this unless i switch if off, what can i do?
    President:
  • 1,932 Answers
To get out of it you need to press start, the display should go daft. Press start again and the display should settle down. Now press the on/off button and the start button at the same time and hold them down for a few seconds until the display shows d-end or d-off.
Your machine should now work.
Unplug your appliance before working on it
Thank You
Posted on Sep 12, 2010
Why is there no power?
Hotpoint red led flashes Washing Machines Questions ...
www.fixya.com > Forum > Tags > red led flashes > Washing Machines
Hotpoint washing machines red led flashes related questions and answers. ... then off When i turn on the washing machine - Hotpoint wf640p - the LED display flashes all the 8s (so ... Question about Aquarius WD640 Front Load Washer/Dryer.
Oct 27, 2015 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint wt741 washing machine and came up error f-05 I cleaned the filter out no joy. Then drained and put washing on fast spin which it did then pumped the washer full of water again help?
YOU COULD TRY CHANGING THE PRESSURE SWITCH.THIS IS A ROUND PLASTIC ITEM WITH A PLASTIC PIPE RUNNING OUT OF THE BOTTOM OF IT.EASILY ACCESSIBLE BY REMOVING THE LID
May 05, 2013 | Washing Machines
I have a hotpoint ultima WT741 flashing F-10 can you tell me the problem please
F10 is a pressure switch not sensing error. Basically its a filling problem.
What you need to do is make sure the fill hose isn't kinked up at the back stopping it from filling fast enough.
If the hose is OK then take off the fill hose and aim it into a bucket and turn the water tap on. Then from there see what the water pressure is like there.
If its weak then you need the water pressure sorting out.
If the pressure is fine then you will need a multimeter and test the water valves on top and see if any of them are faulty.
But the F10 error code is a filling issue.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 01, 2011 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wt741 1400 spin-f-05 flashing on display board not empting or finishing wash?
Error code F05 means pressure switch jammed on full
Remove lower rear cover of washer.
Remove large black hose on bottom of tub.
Remove and clean filter inside hose.
Remove hose onto pump, and check for blockage or obstrucrtion here as well.
This should solve the problem.
PLease rate my solution.
Thankyou.
Jan 17, 2010 | Washing Machines
Hotpoint wf540 stopping on a rinse and spin and
check pump/filter/outlet hose for blockages. if ok, check pressure switch (disc shaped item at top of machine with 4? wires and a tube) by blowing into it gently - should hear clicks, then blow into tube to pressure chamber - should be clear.
Oct 26, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WT741. When power on and 'on' button pressed ALL display lights flash continuously. Sometimes after 2-3 hours they stop and a wash program can be used, but then machine reverts to all light...
Have had this problem on our Hotpoint WT741 washing machine. Fixed it this evening as far as I can tell. Seems it was a loose connection. Took the top off the machine and checked the ribbon connection to the display board at the top front. First, I removed the board (is held in by plastic clips - remove the programme selector knob first) and inspected to see it was okay then refitted it, making sure that the ribbon cable was pushed firmly onto the board. I then removed the rear access panel around the drain hose and checked the connections onto board at the bottom rear of the machine. I gave each connection a good push to check they were properly seated. Having done this, I have been unable to reproduce the fault with repeated switching off/on of the machine. It now appears to be working fine. I suspect the fault arises as a consequence of vibrations from the machine during operation causing one or more connectors to work loose - probably the ribbon cable on the front panel. So the problem should be rectified by checking these are properly seated. If you know what you are doing it's a simple job. Make sure you unplug the machine before accessing the machine and turn off the water supply. Don't attempt this if you aren't sure what you are doing and aren't confident with electronics.
Oct 24, 2009 | Washing Machines
Aquarise + super silent WF 630 1300 spin
to removed test display press and hold start/cancel button for 5 secs. then press on/off and start/cancel together until d-off is displayed then machine will work
Oct 27, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint WT741
turn the machine on while pressing the on annd stat buttons at the same time until dOFF appears.
Apr 20, 2008 | Hotpoint Aquarius WD640 Front Load...
"Test" displays no washing done!
Your test mode is on, maybe accidently. Press "start", "cancel", "on" & "off" together for 10 secs, you will see d/off come on the display. Do the same & the test mode comes on again.
Rate pl.
Dec 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wt741
washing machine WT741 ultima all light are flashing and it won't do anything else
Nov 12, 2007 | Washing Machines
Hotpoint Aquarius WMA42 Front Load Washer Logo
188 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
