Question about Creda W120VW Front Load Washer
Creda w220vw wiring
Just stripped down and rebuilt to replace element and retrieve element cover. Got two wires left at control panel, one isred with green bands from the heater the other is brown/green from the float switch on lh side. One set of terminals labelled 1 X10 2. Any ideas which cable goes to which terminal.
  • cityracingcl Jul 15, 2008
    I have just found my W120vw has two of the three wires on the door lock detached so need to work out which way round they go.
    The black 'N' wire is still attached to the middle.
    I have a Red and green wire and a brown and green wire
    I have either 'C' or 'N' terminals on teh door lock top attache them to and have no wiring diagram.
    Which way round do I attach them? Cheers, Mike
5 Suggested Answers
  • 3463 Answers
SOURCE: creda 1200 w220vw
Door lock light flashing is not normal, check to see if door is shut properly,another problem could be a track blown on control module, you would need to remove front console to check this.
Posted on Dec 01, 2008
  • 84 Answers
SOURCE: Creda W220VW front loading washing machine leaking
Check water flow rate into soap drawer , if very fast water can overflow and run down back of fascia panel and out underneith
Posted on Nov 01, 2009
  • 1557 Answers
SOURCE: I have just 'acquired' A creda excel 1200 washing
In your browser bar type in:
HOTPOINT USER MANUAL and follow the links.
You will find what you are looking for.Although it says Hotpoint, just type your model in the box, and it will come on screen, then you can save it, or download it to your printer
Plz rate my solution.
Posted on Jul 04, 2010
  • 17130 Answers
SOURCE: how to change door seal
Please find some tips to change the door seal with a demo on a machine:
Tips to replacing the door seal;
Posted on Oct 07, 2011
When replacing fan oven element lost wires down back of oven
Best to turn off oven power at circuit breaker. Grab a strong torch and a wire coat hanger. Straighten the coat hanger and make a small hook on one end. Using the torch light guide the coat hanger loop towards some part of the wire and slowly fish it out.
Hope this helps. Otherwise you will be left with no alternative but to pull oven out (heavy) to access the side cover and remove it. It would be helpful to know the make and model of the oven if you needed more help with getting to the wire itself.
Aug 29, 2014 | Ovens
KitchenAid refrigerator, Model number: KSSO48FTX00 Serial Number: QU2324016 Temperature setting control for fridge is set at 37 degrees, but will only cool down to 46 degrees. Freezer setting is at -2,...
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the advisable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Take care in solving the the problem....
Oct 04, 2010 | KitchenAid Refrigerators
How to fit creda thermostats
It depends on which make and model of tumble dryer you have as to how easy it is to replace the relevant parts. Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious burning out or open circuit. Others though have their heating elements inside, which aren't accessible without stripping the dryer down we will try and cover as many as possible in or video tutorials section. Tumble dryer heating elements are always protected by thermal fuses and thermostats which are usually simple devices with 2 wires connected and have a bimetal strip inside them. They can be tested for continuity with a test meter.
The problem is that if a stat (thermostat) or t.o.c. (thermal overload cut-out) has gone open circuit, it may be for a reason. Overheating could have caused it by not being able to vent the air due to a blockage some ware. Blocked filters or even the machine not being allowed its ten minute cooling down period, Overloading can cause it as well. Sometimes they can go for no apparent reason. A blocked or severely kinked vent hosecan also cause overheating.
You-Tube video "ymXmpyVkxIE" placeholder (do not delete)
Jan 02, 2010 | Dryers
Creda W220VW front loading washing machine leaking from bottom of casing. Hoses seem OK, coluld filter need cleaning? If so, how do I access?
Nov 01, 2009 | Creda W120VW Front Load Washer
Creda Simplicity 1000 Washing Machine not heating water
Make sure that you have not got the energy save button in operation, as this by-passes the heater, and will wash at the incoming water temp. It should not be showing green
If this is not the case, then the heater has probably failed.
To access the heater, you need to remove the top cover, remove the soap dispenser drawer, and undo the 4 screws securing the console panel to the top of the washer.
Pull off the timer knob, noting the position of it, and slide the console panel to the right, support it with something.
Remove wire cllip holding door seal to front of panel, and pull off the seal at the front.
Undo the screws securing the front panel at the top.
Undo 3 screws at bottom of front panel.
Lift front panel clear,and stand it at the right of washer, be careful of the wires still attached to the door lock.
At the bottom, in the center, you should find a black cover, remove that, and you will see the heater element.
You eally need a meter to test it for continuity, and or an earth fault.
Replace if faulty.
Please leave a fixya rating for my suggeted solution.
Feb 09, 2009 | Creda W100FW Front Load Washer
Whirpool electric oven replacing bake element
In addition to what aborcass stated, I just had to fix the same problem. Remeber to turn off the power before you do this. On my stove the element acess is behind the side panel (right side when facing the stove). You remove two screws on the back and one underneath at the bottom, (you need to pull out the drawer). Once screws are out, slide the side panel forward gently about an inch and it should just drop off.
You should see the wires for the element level with the bottom of the stove. The wires will guide you to the element. And you should see that the element is screwed in with two screws to the stove. This is the tricky bit, to remove the element follow the metal piece holding the element to the right until you see a third screw. Remove this screw and the whole thing will come out. Take off the wires, replace the element on the metal strip, slide the element and metal strip back into the stove (take care to ensure the left side of the metal strip slides into the proper position under the metal clasp. Re-attach the screw, plug the wires onto the element and turn the power back on. You should have heat.
Good luck.
Dec 02, 2008 | Whirlpool GY396 Electric Kitchen Range
How to change an oven lamp in a creda concept oven
Got a Creda Europa oven/grill and the control panel will not illuminate at all? Any suggestions as to how i get front panel off to replace strip light in behind would be appreciated email
Aug 09, 2008 | Ovens
Creda 1200 w220vw
Apr 17, 2008 | Creda W120VW Front Load Washer
Creda excel 1200
Yes on these three wires you will see if you look carefully that they have written on them neutral ,, one ,,, two,,
these wires connect to the buttons on the front panel,, So if you find the one that says neutral on it... that one connects to the switch on the left hand side of the switch,, its the side that has a connection to the other switch by a small metal strip usually (but some times a wire connection is used ) the other wires connect to the other side of the switches number one connecte to the top switch and number 2connects to the buttom switch i hope this helps....
any probs let me know...
Jan 17, 2008 | Creda W120VW Front Load Washer
Creda W120VW Front Load Washer Logo
71 people viewed this question
Top Creda Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you a Creda Washing Machine Expert? Answer questions, earn points and help others
