Question about Leviton 6230M Decora Four Preset Electronic Timer White
How do i hook this switch up to my exsisting 2 wire (black-power, and white to light) box
  • 56 Answers
This switch reqiures that you need a neutral. From what you have described you do not have a neutral in the box only a hot and a switch leg. You will have to pull a new wire into box in addition to what you have now.
Posted on Sep 30, 2010
I'm looking for help. Installing a Woods 59007 timer. It has 4 wires, red, black, green, white. My current electrical setup is a black, white, and ground wire in the box. How do I hook this up? T
Hook all the white wires together.
Hook all the greens or bare copper wires together.
Hook your hot black to the timer black.
Hook your black wire that goes to your light to the red switch wire.
then try the switch if the light doesn't work switch the red and black switch wires around black to light red to black power.
Oct 19, 2014 | Woods In-Wall Digital 5-10-15-30-Minute...
How do I connect a switch wuth 2 blacks wires and a green wire to the old wall box that has one black wire and one white wire
hook a black to a black and the white to the other black. What they did there is called reverse feed, they pulled power from light box down to switch on one wire and send it back on the other wire. hook it up like that and it should work
Aug 31, 2014 | Leviton Trimatron Rotary Dimmer 6602-i Lot...
How to wire light switch?
ok! only hook up the switch to the black wires and cap the 2 whites together. just run 12/2 wiring with ground to switch, hook the black to switch in and black to switch out to light.. cap the white wires to and from switch! you can either hook ground wire to switch or the steel switch box. hope this helps, im not very good with words.
May 04, 2012 | Cars & Trucks
Have dual light switches - one for fan one for lights on fan. incoming to box is white (neutral) black(hot) then out to switches two sets of w/b. fan has one each of the white, black blue(lights). How do...
From your switch box to your fan run a 14/3 wire. Take the incoming 14/2 white wire,and connect to white of the 14/3 wire to fan lite combo ,and hook both white wires from fan and lite. Hook the fan black wire to the black wire from the 14/3 Hook the black wire from the fan to the red wire from the 14/3. Then go back to the switches, and add a black and red pigtail about 4"long to the black wire from the 14/2, now connect the red wire to one side of switch, and the other red wire from the 14/3 to the other side of switch. Do the same to the black wire on the other switch.
Sep 17, 2011 | Garden
The Casablanca 88U33M Scandia Ceiling Fan only has three wires, a black, a white, and a green wire (ground). How do you wire the fan and light on seperate switches?
If you want to control both the light and the fan using 3-ways, then just wire 2 sets of the 3-way circuits. For this you need two sets of 3-wire between the switches, and one 3-wire cable from the switch location to the fan/light box.
At box #1 (a 2 gang box), you will run a power cable (marked cable #1) into it. From there you run 2 sets of 3-wire cables (identified as cable #2 & cable #3) to the other switch location, which will also be a 2-gang box (box #2).
Also from box #1, you will run a 3-wire cable (cable #4) to the fan/light box (box #3).
Hook up is as follows:
Box #3: connect black of cable #4 to black (fan), connect red of cable #4 to blue (light), connect white of cable #4 to white (fan/light), and connect the bare to the green.
Box #2: Connect white of cable #2 to identified terminal on 1st 3-way switch (#3). Connect red & black of cable #2 to the remaining screws of 3-way switch #3. Next connect white of cable #3 to identified terminal of 2nd 3-way switch (#4), and connect black and red to remaining screws. Tie all grounds together and terminate to both switches.
At box #1, connect black from cable #1 to whites in cables #2 & #3, using a wirenut. Connect white in cable #1 to white in cable #4. Connect black and red in cable #2 to 3rd 3-way switch (#1) and connect black and red in cable #3 to 4th 3-way switch (#2). Connect black in cable #4 to identified terminal of 3-way switch #1, and connect red in cable #4 to identified terminal on 3-way switch #2. Tie all grounds together and to the switches
Jul 04, 2011 | Casablanca Fan (88U33M) Ceiling
Purchased utilitech 0192773 self adjusting wall timer. planning on installing in garage wall switch box for outside lamp posts, 3 total. the wiring in switch box consists of grounds tied together, 2 whites...
you got the wires you need. add switch's white to the white bundle in the back; green to grounds, red to the black going to the light; black to the other black. worked for me!
Jan 29, 2011 | Computers & Internet
I have power in 14/2 and 14/2 out to light. how do I wire the switch. I tried putting whites together and blacks to switch but it doesn't work.
Your breaker is not tripped.
Your light bulb is working.
You have a working on-off switch that has two brass screws and a green ground screw.
That is a single pole switch. Black wires go on either brass-colored screw, and whites are twisted together.
If switch has 3 screws and ground screw, connect black wires to dark-screw and one of the brass screws.
First you should test your wires.
You have 2 cables.
Both cables have black, white, and bare copper ground wires.
One cable goes to light.
Other cable comes from breaker box.
Cable from breaker box has black-hot wire and white-neutral wire.
Turn on power and test black wire to white, and then test black wire to ground.
Tester should light up with both tests.
If tester does not light up, then breaker is suspect, or there is a short in nearby box.
Track back the short towards breaker, going one box at a time, each time testing black to white and black to ground.
Next, inside the switch box, remove the switch and connect both cables without the switch.
Black to black
White to white
Turn on power, does light turn on.
If light turns on, your switch is suspect. Connect new switch. One black wire to each brass screw, and then tie white wires togethr.
If light does not turn on, your light is suspect. Open light fixture and test black to white and black to ground again.
If light tests with power, then check your bulb
If light has no power, then wire between switch box and light is suspect.
Dec 06, 2010 | Electrical Supplies
Trying to hook up 2 lights to a light switch. Power is coming through one light then to wecond light and switch. How do I get the 1st light to work on the switch?
OK I asked for better info but, lets try this... If there is only one set of wires going to the switch, this is called a switch leg. Both wires,no matter what color they really are, are treated as black. so then in the first light box you connect one leg of the switch leg to the hot black incoming wire. the other leg connects to all other black wires in that box.Including the light. the white wires all hook together.( not the switch leg white, remember its really black)Including the light All Bare ground wires hook together. In the other box just match up colors and connect the wires together.Its as simple as that. Larry
Nov 14, 2009 | Electrical Supplies
Need a basic diagram to wire a ceiling fan.
Depending on how your place is wired will dictate the solution here.
The light box in your ceiling should have two or three wires. Black and White, or Red, Black and White.
If you have two wires (one switch to control everything):
Black is power - hook this to the fan's power wire (and the fan's light wire if applicable)
White is neutral - hook this to the fan's neutral wire.
If you have three wires (two separate switches):
Red is power for the light - hook this to the fan's light wire if applicable
Black is for the fan - hook this to the fan's motor
Sep 18, 2009 | Hunter 52" Ceiling Fan With Light And...
WIRING DIAGRAM
Sep 18, 2009 | Panasonic FV-08VQL4 Fan
Leviton 6230M Decora Four Preset Electronic Timer White Logo
88 people viewed this question
Top Leviton Electrical Supplies Experts
Steve
Hippy_dd
jdthefixer
Are you a Leviton Electrical Supply Expert? Answer questions, earn points and help others
