Question about Dell 926 All-In-One InkJet Printer
Ubs calbe wont connect to printer computer is good replaced ubs cable printer is working offline
  • 3,153 Answers
Hi usually reading my TIP here fixes most commn USB issues
http://www.fixya.com/support/r4247716-usb_device
Failure after following the advice there is usually related to a broken or worn USB port or on occasion especially with printers you may have installed the same printer more than once.
If it is too many printers installed then just uninstal them one by one until they are ALL gone then shut down and restart and install just the ONE time only..
Bob
Posted on Sep 12, 2010
Printer wont print says its offline
Dear
Click on START-PRINTER AND FAXES-right click on the PRINTER ICON-click on USE PRINTER ON LINE.
If this is not working connect(replace the cable with a known working cable) the usb cable at the back panel usb port(or change the usb port) of the PC.
If this is not working un install the printer driver and reinstall the same.
If this is not working the printer hardware failure may be there you may need assistance of trained personnel.
Thanks.
Feb 25, 2015 | Office Equipment & Supplies
Epson UB-U03II not working
I had huge issues with my TM-U220. It does not play well with a Centronix-to-USB cable or with Windows 64-bit. I played for AGES to try and get it all to work.
I installed the USB device driver[1] I was able to print the Test Page proving that the connection between Windows and the printer sort of worked, but when I tried printing anything from Unicenta POS, it always failed.
I finally bought a new Centronix-to-USB and a new parallel port card, used Windows 32-bit, and problem solved.
They key is to uninstall everything, including searching through the Registry to delete everything.
[1] https://pos.epson.com/developers/techresdetails.htm?ProductPK=545
May 30, 2014 | Epson TM-U220 Matrix Printer
How do I get a Brother HL4040CN printer to be online? All is say now is offline and won't print. Any suggestions?
Offline suggest that is not connected to the computer. Disconnect the power and data cables. Then replug the cables. Check the cable at the back of the computer also. Turn the computer on.
Check the CONTROL PANEL, PRINTERs. Is it "Ready" now? If not, you may have to reinstall you printer software.
Good luck.
Jan 26, 2011 | Computers & Internet
Hp 4650dn printer showing offline. Connected through airlink router. Working fine one day, offline the next. Power cycled and checked all connections, still no luck.
Hello !
You have to self diagnose the printer by your self. Please try this solutions.
1. Usually it is getting offline when the main computer that connects directly to the printer is off and you are only sharing from this computer through a router or a switch hub. Sure it will mention that the printer is offline and cannot print anything. You need that workstation to be open to be able to connect to the printer.
2. If not, check the cable connection connecting from your computer to the switch hub or router. Maybe it is just loosen for some reasons. Remove the cable to the router and plug it again. Turn off your printer and your computer and turn it on again. Try to print test page.
3. If not, try to unplug the printer cable connecting from the computer to the printer and maybe just loose up. Turn off your computer and printer, after turn it on again. Try to print test page.
4. If still not working, it not something to do with the hardware problem. I believe is it software problem, maybe you upgrade software or install software that harms your printer. Uninstall some programs from the computer that corrupted the driver files. If you upgrade the main computer, I suggest to uninstall and reinstall the printer software.
5. If not, try to replace the port (whether usb port) and maybe this is the problem. Try to turn off the unit and turn it on again.
6. If not, replace the cable connection from to the switch hub, close all the PC unit and print and try to print again.
Here is the only diagnostics solution I can give to you. Good Luck and Thank you for using Fixya.
Jan 06, 2011 | HP LaserJet 4650dn Printer
I checked everything, the printer is connected, there's ink, everything is good, but it says it's offline. I clicked "Use printer online", but it's still offline. I tried Refresh, and it's still...
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Dec 31, 2010 | HP Deskjet F335 All-In-One InkJet Printer
Hp deskjet says offline and wont print
data cable connection may be loosen, tight the connection on both side i.e. on computer as well as printer
2. try to replace data cable
Aug 18, 2010 | HP DeskJet F380 All-In-One Printer
It says HP psc1315 printer is offline and won't print. how do i fix? wont change back to online also one document at front of queue wont delete
Reset your printer. To do this, turn off the printer using the power button, remove the cartridges, unplug the power and the usb cables. Press the power button for several times. Connect the power cable and also the wall jack, power on (don't connect the usb cable). While the printer boots up, keep pressing power button several times. Leave it for few minutes and again switch off. Now connect the usb cable as well and insert the cartridges. Shutdown the computer. Power on the printer and also the computer (Note when you power off/on, use only the power button). This will fix your problem. If possible, please reinstall the drivers for your printer before you restart it with the pc. Good luck. Thanks for using FixYa.
Jun 02, 2010 | HP PSC 1315 All-In-One InkJet Printer
Printer has connected but offline.
your printer correctly installed to your pc the printer driver I mean did your install it correctly? The usb cables has correctly attach to the CPU and printer? Thier is no broken wires of your usb cable did you try to replaced it with new one usb cable.
Apr 18, 2009 | HP Deskjet 2360 InkJet Printer
Dell Laser MFP 1815 wont print
The printer status showing offline is more then likely a computer issue then the printer. On the printer, use the menu to select "reports" and then select the printer settings report. If the printer prints the report, then the printer itself is working, and it is a communication issue between the printer and the computer. If you are connecting to the printer with a usb cable, then try moving the usb cable on the computer to another port. If this does not work, try deleting and reinstalling the printer.
Sep 25, 2008 | Dell 1815dn All-In-One Laser Printer
Dell 926 All-In-One InkJet Printer Logo
125 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
